Sponsored by Tire Rack
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack
Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, suspension issues and more.
Sponsored By:
Tire Rack
Old 12-29-2003, 12:10 PM   #1
goodtremere
Fan#: 2217
What I Drive: '03 Liquid Grey Metallic ZX5
FF Reputation: 1 goodtremere Good Standing Member
Question Stupid Inflation Pressure Question
Hey all,
Just got my ZX5 and I have a stupid question. At what pressure should I keep my tires at? My Focus has the stock 17" wheel and Pirelli tires that came with it.
Thanks for your help.
2003 Liquid Grey Metallic ZX5
goodtremere is offline
Fan#: 1
Old 12-29-2003, 12:15 PM   #2
SVT4ME
Fan#: 61
FF Reputation: 4 SVT4ME Good Standing Member
I don't know the number offhand, but it should tell you in several places:
(a) the owner's manual
(b) if you don't have a manual, check the inside of the gas filler door - that's where it's at on my Focus
Hope this helps...
SVT4ME is offline
Old 12-29-2003, 12:23 PM   #3
hotfocus
Fan#: 12
What I Drive: OLD: '00 Black ZX3, New: Pontiac G6
FF Reputation: 1 hotfocus Good Standing Member
I usually put in around 35psi. But yeah it should be in your manual.
Add yourself to the FF map
hotfocus is offline
Old 12-29-2003, 12:29 PM   #4
SVT4ME
Fan#: 61
Ah, yes... if you meant "is the number in the manual good, or has someone out there discovered a better psi" then I dunno exactly. But it seems that with most modern cars, the recommended setting is desirable. In the old days a little "playing" around with the tire pressure could result in improvements, but for the Focus (for just plain old everyday driving, anyway) there should be no reason to vary too much from what Ford recommends.
SVT4ME is offline
Old 12-29-2003, 12:29 PM   #5
GonFishin
Fan#: 262
What I Drive: 2000 ZX3 / 2006 Mustang GT
FF Reputation: 1 GonFishin Good Standing Member
I think it's 35 "maximum" psi. It says on the tire, and it may be different with your next set of tires so be sure to look before filling and use a tire guage (not the guage on your gas station's air pump...it's not reliable). There's some room for error too (around 3-5 psi). Any further than that and you'll notice odd tire wear. Also, the "max psi" is at cold temperature, so don't drive for a while and then expect accurate pressure readings.
2000 ZX3 / Stage 1 + Gears / Intake / Exhaust / Tune
128whp @ 5000rpm and 135wtq @ 3800rpm
2006 Mustang GT / Intake / Exhaust / Tune
roughly 290rwhp & 315rwtq
GonFishin is offline
Old 12-29-2003, 02:23 PM   #6
Hockeyman
Fan#: 955
What I Drive: 02 Focus Wagon
FF Reputation: 1 Hockeyman Good Standing Member
I usually run anywhere from 28-32 psi... thats our range that we use at the dealership.
Hockeyman is offline
Old 12-29-2003, 02:36 PM   #7
rcpilot
rcpilot's Avatar
Fan#: 1891
What I Drive: 2003 Red ZX3
FF Reputation: 1 rcpilot Good Standing Member
Check your pressure when the tire is cold, ie: setting all night, drive it about 10 miles or so, enough to get the tires warm, then check it again, your pressure should have increased by more than 10% of what you started with (ie: 35 cold, should be no more than 38 when hot) This will ensure your tires are properly inflated under the current load. If you load up you vehicle for say a trip or a bunch of buddies for a long trip then you need to increase your pressures. The max press on the side wall of the tire is the max for that tire not the recommend for the particular vehicle, ie: weight etc.
rcpilot is offline
Old 12-29-2003, 02:42 PM   #8
Focusedat50
It's been fun.......
Focusedat50's Avatar
Fan#: 1409
What I Drive: Boosted ZX5 ATX - 179WHP/158TQ
FF Reputation: 2 Focusedat50 Good Standing Member
Buy-Sell-Trade Rating: (30)
You can also check the sticker on the inside jamb of the drivers door where they have all the other little goodies listed like paint code, etc.
You see what you want to see and you hear what you want to hear.........
Focusedat50 is offline
Old 12-29-2003, 03:09 PM   #9
vanace
Fan#: 350
What I Drive: 2005 ST
FF Reputation: 1 vanace Good Standing Member
i don't think 17's are availible from ford on the focus.. so they are aftermarket tires, and the info in the owners manual won't be accurate for your tires. In my history of driving, tires at the recommended pressures have caused the tires to wear on the center of the tread faster than the rest of the tire, so the pressure was a little high. Higher pressure will give you better fuel milage, but if it wears the tire improperly, and you have to get new tires sooner, then it wasn't worth the savings in fuel. Most radials run from 32-35 psi cold.. start there and monitor your tires for wear, and adjust acordingly
ST crew #18
vanace is offline
Old 12-29-2003, 03:25 PM   #10
CowsGoMoo
CowsGoMoo's Avatar
Fan#: 324
What I Drive: VW GLI 1.8Turbo
FF Reputation: 1 CowsGoMoo Good Standing Member
i run at 32psi on my 215/40-zr17's i also live out in the country a bit and make a drive to civilization every day and potholes are a hazard. A softer tire is my friend.
Moo Like You Gotta
My ZX5 Focus!
CowsGoMoo is offline
Similar Threads
tire pressure question shooga Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 7 06-08-2006 12:59 PM
stupid question? im_focused_man Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 5 05-19-2006 06:41 PM
Stupid Question miles105 General Forced Induction 5 10-04-2004 12:28 AM
stupid stupid question about side markers sublime053 MK1 Focus 7 09-29-2004 07:59 PM
stupid question blazealm ZETEC Performance (2000-2004) 5 08-30-2004 09:10 AM
