2000-2004 Ford Focus Rear Tire Wear - Page 2 - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Wheels & Tires - Sponsored By Tire Rack
Wheels & Tires - Sponsored By Tire Rack The place to go for answers on wheel types, tire sizes, offset, wheel patterns and more.
Sponsored By:
Tire Rack
Old 09-28-2006, 08:55 AM   #11
Neep
Fan#: 39242
What I Drive: 2000 Silver LX
FF Reputation: 1 Neep Good Standing Member
I doubt it. You can feel the rear end's weight swing when driving. Something is wrong in how the suspension travels, it's not just the noise.
Besides the awful camber is evident on both wheels, not just on one side... although I guess there could be two pebbles, but still...
Neep is offline
Old 09-28-2006, 09:09 AM   #12
b16sir1991
Focused Focus
b16sir1991's Avatar
Fan#: 16612
What I Drive: 2004 SVT Focus, Sonic Blue
FF Reputation: 175 b16sir1991 Excellent Standing Memberb16sir1991 Excellent Standing Member
Buy-Sell-Trade Rating: (116)
TSB:
FORD: 2000-2004 FOCUS
ISSUE:
Some vehicles may exhibit rear tire inner edge wear.
ACTION:
If a vehicle exhibits rear inner edge tire wear, and the rear camber reading is beyond the negative end of the specification (max. -2.2 Wagon, -2.3 Sedan & ZX3/5), then install revised +1.0 degree rear Upper Control Arm(s). Refer to the following Service Procedure for details.
SERVICE PROCEDURE
Removal
Remove the rear wheel and tire. For additional information, refer to Workshop Manual Section 204-04.
Remove the outboard upper control arm bolt, and detach the upper control arm from the wheel knuckle.
NOTE: MAKE A NOTE OF THE POSITION OF THE UPPER CONTROL ARM TO AID IN INSTALLATION.
For Wagons only. Remove the lower shock bolt and position the shock aside.
Remove the inboard upper control arm bolt, and remove the arm.
Installation
NOTE: FINAL TORQUING OF THE REAR SUSPENSION COMPONENTS SHOULD BE CARRIED OUT AT OR NEAR THE CURB HEIGHT SETTING. TO ACHIEVE THIS LOAD THE SUSPENSION.
Install upper control arm and a new inboard upper control arm bolt.
For Wagons only. Reposition shock and reinstall the lower shock bolt.
Position the upper control arm in the wheel knuckle and install a new outboard upper control arm bolt.
Reinstall rear wheel and tire.
Recheck alignment to verify camber change, and set toe if necessary.
LABOR OPERATION CLAIMING CHART
Operation Labor Description Vehicle Time
031305A Check Alignment, Replace One Rear Upper Control Arm, And Recheck Alignment (Includes Time To Set Toe If Necessary) Sedan, ZX3/5 1.1 Hrs.
Wagon 1.1 Hrs.
031305B Check Alignment, Replace Both Rear Upper Control Arms, And Recheck Alignment (Includes Time To Set Toe If Necessary) Sedan, ZX3/5 1.4 Hrs.
Wagon 1.5 Hrs.
PART NUMBER PART NAME
3S4Z-1A154-AA Kit - Rear Suspension Upper Arm - Contains Arm And 2 Bolts
"The right driver can work magic"
Oct 2005 Ride of the month.
SVT Squad #25
Call me Mike......
Give rep points and feedback when you appreciate someone on here!
b16sir1991 is offline
Old 09-28-2006, 09:35 AM   #13
Neep
Fan#: 39242
Originally posted by b16sir1991
... and the rear camber reading is beyond the negative end of the specification (max. -2.2 Wagon, -2.3 Sedan & ZX3/5), then install revised +1.0 degree rear Upper Control Arm(s). Refer to the following Service Procedure for details.
What's weird to me is I took in my Focus for a four wheel alignment at Sear's and the rear end came back as within tolerance (actualy it came back perfect) Is there any alignment machine that could get that wrong because components were bent? It's strange to me that the rear camber is so obviously bad as to be visualy evident, but the machine says it's fine. I was thinking that if the part was faulty, maybe the readings would be too, but if this particular failure reads on a rear alignment machine, maybe it's not?
What does an alignment machine base it's readings off of? How could it get a perfect reading for something so obviously fubared?
Neep is offline
Old 09-28-2006, 05:10 PM   #14
WD40
The Librarian
WD40's Avatar
Fan#: 5157
FF Reputation: 138 WD40 Excellent Standing MemberWD40 Excellent Standing Member
^^^Because a "perfect" reading shop-wise is a reading within spec.
As you can plainly see, that spec is allowed to go a long ways towards the negative side.
And, -2.3° is a boatload of camber out back, yet is "perfect" because it's within spec.
Did they give you a print out after the alignment so you can tell where you're at?
Really, unless you're racing, -1° in the back is as much as you'll ever need, and will certainly help with the inner tire wear problems.
WD40 is offline
Old 09-28-2006, 05:37 PM   #15
Geezer
Fan#: 1427
What I Drive: 99 miata, 05Mazda6, 09GTI, 12Imprez
FF Reputation: 141 Geezer Excellent Standing MemberGeezer Excellent Standing Member
WD40 is right on. Even if ford could get the camber as low as -1.8* you will still experience inside tread wear. Ford's alignments specs are the problem! They're far too generous (+0.3 to -2.3 for the rear for example....that's a 2.6 degree window!). We got ours down to -1.6*and wear has pretty much been even. Our camber was at -1.9* and we experienced significant treadwear (inside edge). We are currently using Eibach camber bolts which is a MUCH cheaper solution than the control arms and you get some adjustment to boot.
It's not hard to get the rear within factory camber specs, Ford knows that, and you're still s.o.l. I doubt anyone has received the new control arms for free. Word of warning...being within spec means NOTHING especially with regards to the rear camber recommendations. Do not accept anything more than -1.5 (even lower if possible). If it can't be adjusted to get down to that spec get camber bolts and take it to someone who has worked with them and knows how to adjust them.
Geezer is offline
Old 10-04-2007, 09:04 AM   #16
F.O.R.D.
Fan#: 50406
What I Drive: 2005 zx4 ses
FF Reputation: 1 F.O.R.D. Good Standing Member
Originally Posted by Jake View Post
FYI
I own a 2005 Focus. Is this still an ongoing problem? I just put new tires and a 4 wheel alignment and my back tires are bald 1/3 of the way in. The dealer says it must have been ramped and damaged somehow.
Please help with any known issues so I can shove this paper up &&%$$##. THANK YOU. Second focus owner.
F.O.R.D. is offline
Old 10-04-2007, 12:13 PM   #17
Geezer
Fan#: 1427
The number one complaint on this site for both modified and unmodified foci is inside edge tirewear (alignment) issues. It's not tied to any particular year of focus either. I have to believe Ford is aware of this issue by now. They introduced a new rear upper control arm to reduce rear camber. The catch is that to get them you had to show that the rear camber could not be set within spec. The rear factory spec simply allows for too much camber to begin with so its not hard to get it within spec! Combine that with any toe over the allowed minimum and lots of tread wear can occur. My current advise is to get front and rear toe as close to the minimums as possible. Then get rear camber down to -1.5 degrees or less. This may require camber bolts if the car has been lowered.
Geezer is offline
Old 10-09-2007, 03:48 PM   #18
F.O.R.D.
Fan#: 50406
Alignment issues
Update on the alignment problem I was having. Make sure you get a service tech that knows what they are doing. I went to 3 alignment shops including the dealer and none of them could see that the toe in was not set to spec. It didnt seem like rocket science after showing me what it should be.
We will see if this solves the problems of wearing out tires in 2000 miles.
F.O.R.D. is offline
Old 06-15-2008, 05:47 PM   #19
Ryedale
Fan#: 56885
What I Drive: 2002
FF Reputation: 1 Ryedale Good Standing Member
Replaced my Rear Upper Control Arms
I have recently purchased a 2002 ZX5.
My car rear wheels had noticeable negative camber. After reading hear about either the aftermarket bolts, or the Ford replacement kit, I opted for the more expensive kit. I am replacing the factory 16 in wheels for some older Focus 15's as I'm trying to improve the ride quality. Picked up four new wheels for $200, and now I'm shopping for some nice Michelin Harmony's to quiet the ride.
This weekend I jacked it up, and removed the two bolts on each side, (using some heat from a regular propane torch helped immensely) and replaced the rear upper control arms. I noticed a remarkable difference already in how the car rolls and even after these new parts the car still displays some negative camber, but the ride quality has already improved.
One of the contributors to this upgrade, was based on my trip to my Fedex store shortly after buying the car. I felt the rear tires after the short trip, and found noticible heating on the rear tires on the inner 2 inches that engage the road. This was after a 6 mile round trip. I know the Eibach bolts would have been cheaper, but I feel better about having the factory replacement control arms.
I compared the two arms, old to new, and noticed about an 1/8 to 3/16 inch difference between the lengths from bolt hole to bolt hole. I torqued the bolts with weight on them (holding the weight of the car with the floor jack on the rear sway bar by the brake drum. Not having a spec I torqued them to 100 ft lbs.
I did not notice a place to adjust tow in on the rears, is there such a thing?
I'll update after the tires/wheels are replace and I get a 4 wheel alignment.
Thanks to all who contribute here.
Ryedale is offline
Old 08-24-2008, 07:17 PM   #20
Mahaney
Fan#: 58729
What I Drive: 2000, red, focus
FF Reputation: 1 Mahaney Good Standing Member
I just had a severe front tire blow out on my 2000 focus (ripped the side panel off!). after getting towed to the station for a replacement they discovered severe wear on my rear passenger tire only. it was worn THROUGH the metal on the very inside edge only. this was a new tire with less than 8 months of road time. I had quickly checked my tires the day before and failed to detect it. judging by the tire alone, i would have assumed that it had been riding on a 45 degree negative camber - it was that extreme.
this is not the first time i've had to prematurely replace tires on this car due to excessive wear, but by far the worst instance.
Mahaney is offline
Similar Threads
Ford debuts Focus Coupe-Cabriolet Kneel Ford Focus & General Car Chat 50 10-02-2011 07:04 PM
Even this fOCUS!!!! Jeezzzz!!!! TORQUERULES Ford Focus & General Car Chat 22 02-11-2007 10:47 PM
Interesting Read on Ford Platforms on Wikipedia igor Ford Focus & General Car Chat 2 02-28-2006 02:45 AM
in my ford focus 2004 automatic....is ther any way to turn off the day running lights chevy6128 Ford Focus & General Car Chat 3 09-17-2005 08:40 PM
2005 Economy Sedan Comparison Test Kneel Ford Focus & General Car Chat 4 08-24-2005 10:02 AM
