Need help with Remote Start Alarm install - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-20-2005, 01:02 PM   #11
briandg510
briandg510's Avatar
Fan#: 3966
What I Drive: 2001 Fort Knox Gold ZTS
Points 1,374, Level 20
Points: 1,374, Level: 20 Points: 1,374, Level: 20 Points: 1,374, Level: 20
Level Up 74% Completed
FF Reputation: 118 briandg510 Excellent Standing Member briandg510 Excellent Standing Member
Buy-Sell-Trade Rating: (13)
I did diode isolate them as you instructed me. Thanks for the professional help you gave me(& to others who have read this thread). I'll post (more) question when any problem arises.
briandg510 is offline
Old 05-28-2005, 01:07 AM   #12
briandg510
briandg510's Avatar
Fan#: 3966
The alarm is now working except for the Remote Starter...
I got the Transponder keys cut. I was trying to program it but failed.
I did this :
1) put key #1 in the ignition, and turn the key forward (do not start vehicle) wait for (!) light
to go off. remove key
2) put key #2 in the ignition, turn key, wait for (!) to go off. remove key.
3) put the new cut key in the ignition and turn it on.
I think my third step is wrong. Do I have to just insert it without turning it on and wait a few seconds and take it out?
Or maybe I wired my Bypass Module wrong. This is what I did...
I connected the Blue/Black of the 9 pin connector to the White/Green of the Bypass Module and I connected the Yellow/Green of the B/M to the 12V constant(RED WIRE). Now, is my wiring correct for B/M?
I also have question about my wiring for the starter disable. I followed this diagram...
I connected everything as shown, but I am uncertain to where the blue wire goes. I did connect the blue wire of the relay to the Green/Yellow(Ignition1) of the Ignition switch harness. Did I do the wiring correctly?
Old 05-28-2005, 12:18 PM   #13
SQFocusZTS
Fan#: 4729
What I Drive: 2000 Focus ZTS
FF Reputation: 2 SQFocusZTS Good Standing Member
try programming the key using the ignition key cylinder....
so, put key 1 in, turn it to 'on', wait for light to go off, shut car off (you have a 10 second window between keys)
put key 2 in, turn it to 'on', wait for light to go off, shut car off (same 10 second window)
put freshly cut key in, and START the vehicle.
if you purchased the correct key, the car should start and stay running. you have successfully programmed a 3rd key.
now, if you want to make sure youre remote start works w/o using the bypass module, do this trick ---
stick a GOOD key in the ignition but do not turn the cylinder... just stick it in. then, activate the remote start. if your wiring is correct, the vehicle WILL remote start. deactivate the remote start. take a key and put it in the bypass module.
if you're having trouble getting it started reliably, my suggestion is to make sure the antenna 'ring' is closer to the ignition key hole than the factory ring
the bypass module wiring looks good.
re: starter kill...
the blue wire gets connected to the ignition wire of the vehicle. what happens is, when you ARM the alarm. the ORANGE ['connect to orange wire of alarm'] wire goes to ground. currently, the starter wire is still connected through the pins 87a and 30 on the relay. the blue wire on the relay goes to the ignition wire for this simple reason:
lets say the thief gains acess to your interior, and tries (and successfully) gets a screwdriver to turn your ignition to the ON position. well, when the ignition wire gets energized, the relay also energizes BREAKING the contact between 87a and 30, thus not allowing the starter to crank... this is true even if you have the ignition key. once the key is turned back from off (or screwdriver or whatever), the relay will click 'off' and teh starter wire will be reconnected. you follow this ?
-john
SQF
John
SQFocusZTS
Certified MASTER Installer
one of 72 in the world...
SQFocusZTS is offline
Old 05-28-2005, 09:16 PM   #14
briandg510
briandg510's Avatar
Fan#: 3966
Captain(brain): Start the car soldier.
Soldier(thumb): Yes, captain. Press the start button.
Car: Cranks and vroom.
Soldier: Car is ready captain.
Captain: Good work, soldier.
I'm just happy. Everything is working! Thanks for the help of everyone especially John.
There is a how to program a key in the owner's manual. It is page 76.
Old 07-29-2007, 03:36 PM   #15
ukscarface
Fan#: 46765
What I Drive: 2000 Moondust Silver 2.0 Focus
FF Reputation: 1 ukscarface Good Standing Member
Help Help Help!!
I am in desperate need of help. when i wired in my alarm i am trying to get the system to unlock itself, the lock feature works a treat but when i try to unlock all i manage to do is unlock the boot release, i know that the door unlock and trunk are both using the same wire (black/Yellow) so i assume i might need a relay or somthing, anyone had this poblem and overcome?? any ideas appreciated, i have tried for days now!!! HELP HELP HELP! danny.hathaway@ntlworld.com ford replies direct please thanks in advance
ukscarface is offline
Old 11-24-2012, 05:34 AM   #16
Ladybugg
Fan#: 105380
What I Drive: 2003 charcoal focus zx5
FF Reputation: 1 Ladybugg Good Standing Member
Hi! Where exactly do I find a "how to" on remote start/alarms?
I have a viper system that I am interested in installing myself
Thanks!
Ladybugg is offline
