Help for Focus audio system - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-28-2014, 01:36 PM   #1
CubisticDrop668
Fan#: 186225
What I Drive: 2005 Medium Dark Blue 3 door Hatch
Points 62, Level 1
Points: 62, Level: 1 Points: 62, Level: 1 Points: 62, Level: 1
Level Up 24% Completed
FF Reputation: 1 CubisticDrop668 Good Standing Member
Hi...
I have an 05 Focus Mk2 3 door, with the standard audio system in. I'm not 100% sure whether or not it has the factory fitted subwoofer, but I don't think so. I'm looking to get a Pioneer AVH X7500 BT head unit for the car, and I'd like to get some speakers to go with it, can you give me some advice on Amps and Speakers that I'd need, and what sizes etc?
Thanks
CD668
CubisticDrop668 is offline
Old 08-28-2014, 09:49 PM   #2
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,606, Level 53
Points: 6,606, Level: 53 Points: 6,606, Level: 53 Points: 6,606, Level: 53
Level Up 28% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
What is your budget. That's the best place to start.
Then what are your goals of your system?
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 09-09-2014, 10:34 AM   #3
CubisticDrop668
Fan#: 186225
Points 62, Level 1
Hi, sorry it took so long to reply... I've a budget of about 200 (I'm not sure what is in $), and I want as good quality sound for that budget, and as easy fit as possible.
Thanks
CD668
Old 09-09-2014, 02:41 PM   #4
firebirdude
Fan#: 48824
What I Drive: 2013 Race Red SE Hatchback
Points 256, Level 5
Points: 256, Level: 5 Points: 256, Level: 5 Points: 256, Level: 5
Level Up 12% Completed
Forum Activity 3%
FF Reputation: 2 firebirdude Good Standing Member
200 pounds is $322 American dollars. Obviously this budget does not include the Pioneer headunit? Does it include all the parts you'll need for installation of the Pioneer? Professional labor to install the Pioneer or speakers?
$322 isn't really enough to replace the door speakers AND add a subwoofer. So best to just get some quality speakers and add the subwoofer at a later date. You have 6x8" speakers all the way around. I don't know what brands are available to you in the UK or what website ship to the UK at a reasonable rate, but, the Alpine SPR-68, Kicker 41KSC68, Infinity 682.9cf and even the Kenwood KFC-P680C plate component set is worth a look. All easy fits. Most all of those are going to put you over the $200 mark with shipping and all. If you can swing it, add in the Alpine KTP-445U amplifier to kick those new speakers into high gear. Hides up in the dash. Easy to install without having to run power wire through the firewall and to the battery. You'll be all over that $350 total mark though.
firebirdude is offline
Old 09-09-2014, 04:36 PM   #5
CubisticDrop668
Fan#: 186225
Points 62, Level 1
No, the budget was just for speakers, Head unit and parts are all sorted.
Ideally, I'd like to fit the speakers etc... myself, just because I kinda like that sort of thing, and professional fit may be a bit costly. I was thinking about full range speakers, and I've heard a subwoofer takes up a good bit of space, so I may leave that...
The availability here is pretty decent, amazon usually is the best, so I shouldn't worry about that.
The output of the head unit is apparently 50W 4 channel, so would that be enough for those speakers? I will have a look at those speakers though, thank you very much!
Old 09-09-2014, 04:42 PM   #6
CubisticDrop668
Fan#: 186225
Points 62, Level 1
I've just had a browse at the speakers, it seems I can only find the alpines in the UK, under these model names/numbers. I will keep looking, because, like the head unit, some EU models are named differently...
Old 09-09-2014, 04:54 PM   #7
CubisticDrop668
Fan#: 186225
Points 62, Level 1
I could find what I think are the Kicker and Kenwood UK equivalents:
http://www.kenwood-electronics.co.uk...om/KFC-S6894C/
http://www.kicker.uk.com/products
(Kicker don't have a specific link, but they are the KSC68)
Old 09-09-2014, 04:57 PM   #8
firebirdude
Fan#: 48824
Points 256, Level 5
Forum Activity 3%
The Pioneer head unit outputs 50W PEAK or MAX. All aftermarket head units output 15-20W RMS. The sound quality will be heads and shoulder better than the factory setup. But if you listen loud, then you'll want to add the amp.
And yes, some EU models have different model numbers. Donno what they are. Check out the manufacturer's UK website I suppose?
Old 09-09-2014, 04:59 PM   #9
CubisticDrop668
Fan#: 186225
Points 62, Level 1
http://www.pioneer.eu/eur/products/2...0BT/specs.html
Maximum power output 50W, it says
Old 09-09-2014, 05:07 PM   #10
CubisticDrop668
Fan#: 186225
Points 62, Level 1
I found that amp on amazon, and it says it is 45W RMS, does this mean I'll have to be careful with the volume as to not damage the speakers?
