Go Back   Focus Fanatics > Ford Focus Tech Discussions > General Forced Induction
Old 05-12-2005, 06:41 PM   #1
Duffman2686
Fan#: 21784
What I Drive: 2001 Silver ZX3
FF Reputation: 1 Duffman2686 Good Standing Member
Worth buying a lightened flywheel when turboing?
Is there really any effect, doesn't it create more backpressure or something and cause more harm than good?
Duffman2686 is offline
Old 05-12-2005, 06:56 PM   #2
gump1114
DTF
gump1114's Avatar
Fan#: 13164
What I Drive: 04 Neon SRT-4, '96 Eagle Talon
FF Reputation: 6 gump1114 Good Standing Member
Buy-Sell-Trade Rating: (6)
um taking a wild guess her but im pretty sure your flywheel has nothing to do with backpressure
435 HP & 438 TQ - Tuned by Turbo666
12.1 @ 124mph
Former Focus Owner.
gump1114 is offline
Old 05-12-2005, 06:59 PM   #3
QuickSilverSVT
Fan#: 16430
What I Drive: 2004 Cd Silver SVT focus zx3
FF Reputation: 1 QuickSilverSVT Good Standing Member
and if toms did it.... it cant be bad
QuickSilverSVT is offline
Old 05-12-2005, 09:21 PM   #4
Duffman2686
Fan#: 21784
w/e is it worthi t or not
Old 05-12-2005, 09:26 PM   #5
Foci_Fosho
Foci_Fosho's Avatar
Fan#: 5736
What I Drive: 2003 White zx3 2.3L
FF Reputation: 16 Foci_Fosho Great Standing Member
for the cost of a light weight flywheel, I think the money would be better spent for dyno-time to tweak out ecu parameters.... data-logging software... But that's just what I would invest in if my car was getting a turbo kit installed.
I think if your going to go with the light-weight fly-wheel, you might as well throw in the extra cash and have gears and or a limited slip differential installed.
Foci_Fosho is offline
Old 05-13-2005, 09:27 AM   #6
finalley
Fan#: 386
What I Drive: 04SVTF, 03SVTF,08F150 4x4, 2013ST3
FF Reputation: 5 finalley Good Standing Member
I think so
...Success or Failure is not an Event, It is a Process... 04SVT custom pressurized intake,@20lbs..340HP/338TQ, by Tom...
..............ridden Hard and put away Wet...
finalley is offline
Old 05-13-2005, 09:31 AM   #7
crazymechanic
Fan#: 12900
What I Drive: 2003 SVT Focus
FF Reputation: 1 crazymechanic Good Standing Member
using a light weight flywheel will increase your turbo lag a very slight amount. a heavier flywheel puts more load on an engine, causing it create more exhaust which spools the turbo up faster. of course the extra revvability of the engine will overcome most of that extra lag and get you up to spool a bit quicker, so like I said, it'll be a VERY slighty difference. personally I'd go for the light flywheel because the it'll actually relieve some of the stress on the engine, increasing its longevity.
crazymechanic is offline
Old 05-13-2005, 11:31 AM   #8
finalley
Fan#: 386
less rotational mass every rpm to spool up,allowing the POWER of the engine to drive the wheel as opposed to the stock
finalley is offline
Old 05-13-2005, 11:14 PM   #9
belacyrf
Fan#: 6919
What I Drive: Blue 2002 SVT Focus
FF Reputation: 1 belacyrf Good Standing Member
Correct, but then you contradicted yourself. The extra revability will not overcome the slower spool-up.
You were accurate the decreased load thanks to the lighter flywheel will delay boost a little bit, that's it end of story. The increased revability will mean the car revs faster when the clutch is depressed, but with the clutch engaged the lightened flywheel is nothing but a cog in gear set. Yes less rotating mass, and quicker acceleration given the same horsepower, but you will still see slower turbo spool up. It's not a huge difference, but it is definately a bit slower.
Is it worth it?? Depends. What are you looking to do?
If I were just daily driving and doing drag racing, then I wouldnt' do it. If wanted to use my car on a road course where the heel-toe technique comes into play, then definately do it!
belacyrf is offline
Old 05-14-2005, 01:44 PM   #10
Duffman2686
Fan#: 21784
no heel-toe'ing...just a daily driver. so you think they $$ would be better spent on say...the svt suspension? or clutch and lsd
