AC pulling tons of power?... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-23-2014, 04:30 PM   #1
disturbinglee
Fan#: 136033
What I Drive: 2003, Blue, ZX3
Points 354, Level 7
Points: 354, Level: 7 Points: 354, Level: 7 Points: 354, Level: 7
Level Up 8% Completed
Forum Activity 2%
FF Reputation: 1 disturbinglee Good Standing Member
Hey guys, i know that having your ac on does affect performance but with my car it seems to make a Huge difference. I have an 03 zx3 and i wasn't sure if this was normal or not. I try to drive without ac bc it drivers better and makes a huge difference with milage but its hot in FL so I can't always do that. Basically just seeing if this was normal or not and if it isn't if you guys have any suggestions. thanks!
disturbinglee is offline
Old 08-23-2014, 04:47 PM   #2
gotta_gofast
Fan#: 178825
What I Drive: '07 Black ZX4 ST
Points 145, Level 2
Points: 145, Level: 2 Points: 145, Level: 2 Points: 145, Level: 2
Level Up 90% Completed
Forum Activity 3%
FF Reputation: 1 gotta_gofast Good Standing Member
On a small engine wrapped in a light car the AC compressor will make a noticeable impact driving. It is rather annoying.
07 Focus ST-basic bolt ons (daily commuter)
08 Fusion 2.3L-rear baby seat install (wife's daily)
06 F250 powerstroke-big injector, bigger turbo= Go without the smoke show (family hotrod and camper hauler)
gotta_gofast is offline
Old 08-23-2014, 05:21 PM   #3
disturbinglee
Fan#: 136033
Points 354, Level 7
Forum Activity 2%
Thanks, I figured but I was just checking to make sure
Old 08-23-2014, 05:48 PM   #4
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,525, Level 100
Points: 52,525, Level: 100 Points: 52,525, Level: 100 Points: 52,525, Level: 100
Level Up 0% Completed
Forum Activity 55%
Buy-Sell-Trade Rating: (28)
Things that help this a good bit is a tune , 180 deg thermostat , doing this with a Tune can turn on the fans sooner and keeps the engine cooler , this makes for more performance and by having the fans on cooler it lowers the head psi in the compressor and makes turning the compressor easier meaning takes less HP from the engine to run the AC
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 08-24-2014, 11:50 PM   #5
MineTwine45
Zetec is Best 'Tec
MineTwine45's Avatar
Fan#: 138537
What I Drive: 2003 Silver Frost ZX5
Points 23,124, Level 93
Points: 23,124, Level: 93 Points: 23,124, Level: 93 Points: 23,124, Level: 93
Level Up 78% Completed
Forum Activity 90%
Activity: 90% Activity: 90% Activity: 90%
FF Reputation: 2 MineTwine45 Good Standing Member
I can feel my A/C compressor kick in and out even when just cruising at a constant speed and RPM. Just the nature of a low-power engine getting hit with a big power draw.
2003 Focus ZX5 "Ruth" Silver Frost - 33,000 Miles - Hatch Nation #98 - TakeOver #004
MineTwine45 is offline
Old 08-25-2014, 07:53 AM   #6
amc49
Fan#: 96610
Points 3,359, Level 36
Points: 3,359, Level: 36 Points: 3,359, Level: 36 Points: 3,359, Level: 36
Level Up 6% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
Yep, I was cursing mine today. They are dead with hot day and mileage over 125K. The ring seal has dropped enough by then to show effect. A brand new engine will motor right through that condition.
I was wondering today based on the response of the engine to throttle if there wasn't more a tune might do since the throttle gets opened up a bunch but nothing really happens. Get deeper though into it to hit the open loop and at a very small bit more of throttle boy it comes on then, like a turbo just kicked in. It has something to do with still trying to run at stoichiometric at lower load.
Fix the driver first, then fixing the car becomes so much easier.
amc49 is offline
Old 08-25-2014, 08:58 AM   #7
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 55%
A tune and 180 helps a LOT
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 08-30-2014, 12:30 PM   #8
amc49
Fan#: 96610
Forum Activity 40%
I could see that happening there. Something is wonky when you can open the throttle 15-20 degrees and literally nothing happens. I realize the a/c steals power but the engine simply does not go with more throttle until you get way deep in it, then it suddenly DOES do right. That ain't right, something there in software that is correct with fresh motor is not once it gets old and less ring seal. Probably too hot and too lean for emissions, get richer and colder and boom! It goes then.
amc49 is offline
Old 11-30-2014, 12:37 PM   #9
Pauly_D
Fan#: 202745
What I Drive: 2003 BLack Focus Sedan
Points 4, Level 1
Points: 4, Level: 1 Points: 4, Level: 1 Points: 4, Level: 1
Level Up 7% Completed
FF Reputation: 1 Pauly_D Good Standing Member
some of the ac clutches have a washer behind them, but you can remove it when the clutch gets worn down.. doesnt hit as hard when it cycles.
Pauly_D is offline
Old 12-13-2014, 10:03 PM   #10
angelwolf71885
angelwolf71885's Avatar
Fan#: 107341
What I Drive: 2003 FORD Focus ZTS SDN RED
Points 114, Level 2
Points: 114, Level: 2 Points: 114, Level: 2 Points: 114, Level: 2
Level Up 28% Completed
FF Reputation: 1 angelwolf71885 Good Standing Member
if you have an A/C system leak it can cause the compressor to bog down the engine
i have a fitting leak and cant keep R134a in my car more then a month
then my engine wants to practically die with the AC on
angelwolf71885 is offline
