Quick PCV swap question. - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-19-2014, 02:22 PM   #11
pappy60
pappy60's Avatar
Fan#: 171689
What I Drive: 2002 gold focus
Points 347, Level 6
Points: 347, Level: 6 Points: 347, Level: 6 Points: 347, Level: 6
Level Up 94% Completed
FF Reputation: 1 pappy60 Good Standing Member
Make sure to check both hoses. Just replaced the rubber hose in the back of motor (it collapse) And the elbow it was dry rotted.
pappy60 is offline
Old 08-19-2014, 02:45 PM   #12
motcher41
Fan#: 151842
What I Drive: 01 Focus ZTS & 92 Ranger XLT
Points 330, Level 6
Points: 330, Level: 6 Points: 330, Level: 6 Points: 330, Level: 6
Level Up 60% Completed
FF Reputation: 1 motcher41 Good Standing Member
I got two hoses with it the elbow for the pcv and a longer breather tube hose with silver heat wrap on it. I think it was from the valve cover to the air box
motcher41 is offline
Old 08-19-2014, 03:02 PM   #13
GhostTribute
GhostTribute's Avatar
Fan#: 107929
What I Drive: 2001 Mazda Tribute (2.0L Zetec)
Points 378, Level 7
Points: 378, Level: 7 Points: 378, Level: 7 Points: 378, Level: 7
Level Up 56% Completed
Forum Activity 8%
FF Reputation: 1 GhostTribute Good Standing Member
On mine that long tube with the thermal wrap goes from the end of steel PCV tube to the back of the intake manifold. There should be a metal tube that goes the width of the cylinder head. That is the one that the PCV & elbow plug into. Then on the other end that wrapped tube continues onto the lower part of the intake manifold in the back.
GhostTribute is offline
Old 08-19-2014, 03:49 PM   #14
motcher41
Fan#: 151842
Points 330, Level 6
I see that. On break i went out and removed the airbox hose and compare. I will be able to get under it in a few days and take a look. I imagine it needs to be accessed from the bottom. Thanks for the tip!
Old 08-19-2014, 08:11 PM   #15
pappy60
pappy60's Avatar
Fan#: 171689
Points 347, Level 6
GhostTribute is right. But you will have better luck from underneath The hose going into the intake has a clamp on it.
pappy60 is offline
Old 08-20-2014, 01:45 AM   #16
motcher41
Fan#: 151842
Points 330, Level 6
Probably one last question for a while...in regards to the thermostat housing is there an upgrade to the plastic one that is used on it such as metal or is it just the same old plastic one Ford has used for a long time? Everything I seem to find is old and outdated as far as the thread goes. Thanks guys.
Old 08-20-2014, 08:07 AM   #17
GhostTribute
Fan#: 107929
Points 378, Level 7
Forum Activity 8%
There is an aluminum replacement that they are selling, if I remember correctly it costs somewhere around $250-$300.
I remember reading an article stating that there is a certain range of years that the thermostat housing is better. If memory serves me correctly it is the 00-02 but I'm not 100%.
Old 08-20-2014, 08:09 AM   #18
motcher41
Fan#: 151842
Points 330, Level 6
Must not be the 01 lol maybe I'll get my quarter inch ratchet out and just see if any of the bolts are loose. Snug them up a little if they are.
Old 08-20-2014, 08:15 AM   #19
motcher41
Fan#: 151842
Points 330, Level 6
I can seel it on the tranny belhousing and smell it but it is not enough to drip on the ground
Old 08-23-2014, 07:11 PM   #20
motcher41
Fan#: 151842
Points 330, Level 6
Any quick tips on how exactly the intake manifold pcv hose clip works?
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Audi S3, Mazda MX-5 Miata and Acura TLX. You can find all Ford Focus, Focus ST and Focus RS related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
