Quick PCV swap question. - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-18-2014, 03:10 PM   #1
motcher41
Fan#: 151842
What I Drive: 01 Focus ZTS & 92 Ranger XLT
Points 330, Level 6
Points: 330, Level: 6 Points: 330, Level: 6 Points: 330, Level: 6
Level Up 60% Completed
FF Reputation: 1 motcher41 Good Standing Member
I know where its at...as far as changing is it as easy as I think. Pull the elbow off valve and tube then pull out and install pcv valve then shove the new elbow on both?
01 ZTS Zetec DOHC
motcher41 is offline
Old 08-18-2014, 06:54 PM   #2
GhostTribute
GhostTribute's Avatar
Fan#: 107929
What I Drive: 2001 Mazda Tribute (2.0L Zetec)
Points 376, Level 7
Points: 376, Level: 7 Points: 376, Level: 7 Points: 376, Level: 7
Level Up 52% Completed
Forum Activity 8%
FF Reputation: 1 GhostTribute Good Standing Member
Yes it is that simple.... Just an FYI, A lot of times you can avoid having to by a new one simply by cleaning your existing one. Remove the PCV valve and elbow and clean/soak them with carb/throttle body cleaner then rinse with hot soapy water. You should be able to shake it and hear the ball/plug rattling inside the valve.
GhostTribute is online now
Old 08-18-2014, 07:05 PM   #3
motcher41
Fan#: 151842
Points 330, Level 6
Thanks. I learned from my 2nd gen Escort that cleaned usually won't past as long as new. Plus its cheap. Existing elbow looks extremely hard and brittle.
Off topic question. My escort had an known problem with thermostat housing bolts snapping off. Since my very minor leak is a near future fix does the DOHC have the same issue or did they use good bolts.
Old 08-18-2014, 08:58 PM   #4
GhostTribute
Fan#: 107929
Points 376, Level 7
Forum Activity 8%
The bolts are usually pretty good, it's the crappy housings that are the issue on these ones!
Old 08-18-2014, 09:04 PM   #5
motcher41
Fan#: 151842
Points 330, Level 6
Thanks for the info man. Had a hell of a disaster when mine broke on the scort.
Old 08-18-2014, 09:18 PM   #6
GhostTribute
Fan#: 107929
Points 376, Level 7
Forum Activity 8%
I hear ya! It's never fun having to get out the stud puller/extractor, or even worse yet, the drill and tap. Not always much room in the engine bay to do that sort of operation.
Old 08-18-2014, 09:25 PM   #7
motcher41
Fan#: 151842
Points 330, Level 6
Ignore
Old 08-18-2014, 09:25 PM   #8
motcher41
Fan#: 151842
Points 330, Level 6
http://www.feoa.net/threads/what-to-...s-wrong.83459/ lol
Old 08-18-2014, 09:27 PM   #9
GhostTribute
Fan#: 107929
Points 376, Level 7
Forum Activity 8%
Been there done that! I've had to use time-serts a few times. Once or twice on Ford spark plug blow outs.
Old 08-19-2014, 02:12 PM   #10
motcher41
Fan#: 151842
Points 330, Level 6
Got it swapped. Boy that was fun. I tried to pul on it and it was so hard and brittle it tore apart lol. Managed to slowly chip off the rubber piece by piece and got it changed. It helped my idle and especially power a lot.
