Are cams worth the money? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-18-2014, 09:26 PM   #11
GhostTribute
GhostTribute's Avatar
Fan#: 107929
What I Drive: 2001 Mazda Tribute (2.0L Zetec)
Points 375, Level 7
Points: 375, Level: 7 Points: 375, Level: 7 Points: 375, Level: 7
Level Up 50% Completed
Forum Activity 8%
FF Reputation: 1 GhostTribute Good Standing Member
Check with the camshaft manufacturer. Adjustable cam gears are not always a requirement.
The aftermarket camshafts are usually designed to run based on stock cam timing. They are usually drop and go. However, there can be some power found in adjusting them depending on engine modifications and fuel used. This is best done on a dyno where you can actually see the power gains or drops when adjusting the cam timing!
I dropped my stage 2 cams in at the stock timing and never had any issues. With my new build I will have to dial in the cams with adjustable gears on a dyno though.
GhostTribute is online now
Old 08-18-2014, 10:09 PM   #12
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,508, Level 100
Points: 52,508, Level: 100 Points: 52,508, Level: 100 Points: 52,508, Level: 100
Level Up 0% Completed
Forum Activity 59%
Activity: 59% Activity: 59% Activity: 59%
Buy-Sell-Trade Rating: (28)
Originally Posted by nboyles85737 View Post
And if I dont do adj can gears? Or am I forced to?
YES 100% ! If your not going to do adj cam gears dont do the cams wouldnt be worth it at all
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 08-18-2014, 10:12 PM   #13
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 59%
The only things I'm missing are the intake(who made it?)and injectors(if they are different than '00 stock).
Haha was it worth it? I'm in college with a limited budget. If I had spare money I'd probably do it.
The 2000 intake ( one piece ) is about a 3-4 HP gain not worth it in my opinion unless you have all supporting mods and pushing for all you can get , you dont need anything but stock Inj to do what your talking about doing
Before you do the cams you need to add the SVT header and 2.5 Exh this will be a bigger gain then cams and cam gears and will be needed to get anything from the cams you want to add
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 08-18-2014, 10:13 PM   #14
nboyles85737
nboyles85737's Avatar
Fan#: 130386
What I Drive: 2000 Autumn Orange SE
Points 6,831, Level 54
Points: 6,831, Level: 54 Points: 6,831, Level: 54 Points: 6,831, Level: 54
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
FF Reputation: 5 nboyles85737 Good Standing Member
Can I do it later if I got the right ones?
How do I find a dyno tuner?
Sedan Revolution Member #288
the Broken Focus
Autox'er
nboyles85737 is online now
Old 08-18-2014, 10:15 PM   #15
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,620, Level 62
Points: 8,620, Level: 62 Points: 8,620, Level: 62 Points: 8,620, Level: 62
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
Forum Activity 27%
Activity: 27% Activity: 27% Activity: 27%
he says he has a 2000 so he already will have the intake... or did they change the intake mid model year?
If you dont use cam gears you lose out on a lot of the gain from cams. people have gained quite a bit of power in the range they want it by just using the adjustable gears on stock cams.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 08-18-2014, 10:15 PM   #16
nboyles85737
Fan#: 130386
Forum Activity 100%
Could I get can gears for my stock cams and see improvement or not worth it?
the Broken Focus
Autox'er
Old 08-18-2014, 10:16 PM   #17
nboyles85737
Fan#: 130386
Forum Activity 100%
Ahh thanks. And 2000 intake is better that. Other years?
the Broken Focus
Autox'er
Old 08-18-2014, 10:17 PM   #18
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 27%
Get on the local board or local auto sports face book page (or yellow pages / Google) and ask around or search. I think an hour session usually runs between $100 to $150. you will want to coordinate with tom also so he can set up your data logging while they are doing the dyno runs.
you can do it later. but I would do it the other way around.. get the gears first and then down the road get the cams.
Hatch Nation #42
Old 08-18-2014, 10:18 PM   #19
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 27%
Yes, the 2000 intake was a 1 piece molded design. It flows a little bit better (i truly mean a little bit better) but the main advantage is under high boost applications the 2001 and up being a multi-piece that was then glued/welded together has shown in cases to crack.
Hatch Nation #42
Old 08-18-2014, 10:20 PM   #20
nboyles85737
Fan#: 130386
Forum Activity 100%
4100 dollars?
the Broken Focus
Autox'er
