Bolt broken off into head! Man! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-07-2005, 04:11 AM   #1
ampedout
ampedout's Avatar
Fan#: 16956
What I Drive: White 00 SE Sedan Zetec
Points 5,085, Level 45
Points: 5,085, Level: 45 Points: 5,085, Level: 45 Points: 5,085, Level: 45
Level Up 68% Completed
FF Reputation: 1 ampedout Good Standing Member
Buy-Sell-Trade Rating: (8)
Angry Bolt broken off into head! Man!
I was re installing my valve cover after installing a cam belt and I decided to check out the torque rating of the valve cover bolts in the trusty Chilton. I seen 60 and thought, boy.. ive done this a few times and everytime I thought it seemed to much. Sure enough, I put it to 45 lbs and start to torque in a star pattern. On the top middle one right below the throttle body, I hear a SNAP. God I was pissed! Still am.. I am sure its been broken off but didnt extract whats left because I wanted to get to sleep.. Perhaps wake up and have it all been a dream.
Has anyone done this? Did anyone successfuly extract it via an easy-out? Those bolts are so damn tiny.
Roush Turbo kit
ampedout is offline
Old 05-07-2005, 11:06 AM   #2
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 236,661, Level 100
Points: 236,661, Level: 100 Points: 236,661, Level: 100 Points: 236,661, Level: 100
Level Up 0% Completed
Forum Activity 3%
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Heres the easy way ... Pull the valve cover back off and with a little luck you will still have some stud sticking up... Then grip it with a GOOD pair of vice grips ( WOW this is actually what vice grips are intended for !! ) and take it out.... If it is flush with the head, repost and I'll tell you the next trick..
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 05-07-2005, 12:08 PM   #3
liquid01
Fan#: 252
What I Drive: ZX3 S2 modded--Just a touch
FF Reputation: 3 liquid01 Good Standing Member
Hey Amped..If it`s broken flush I have a set of easy outs if viney doesn`t have a better way..I`ll be home sunday in the afternoon.
For Sale (sleeper)
liquid01 is offline
Old 05-07-2005, 01:55 PM   #4
zslaton
zslaton's Avatar
Fan#: 11347
What I Drive: 2002 Yellow Power Premium ZX5
FF Reputation: 1 zslaton Good Standing Member
what are easy outs?
... still plays with cars ...
zslaton is offline
Old 05-07-2005, 02:20 PM   #5
BornAgainFordOwner
Fan#: 9408
What I Drive: 2004 Liquid Grey ZX3 PZEV 5Sp.
FF Reputation: 7 BornAgainFordOwner Good Standing Member
When you're ready to retighten the cylinder head cover (cam/valve cover) bolts, my '04 Ford Shop Manual lists the final torque as 7 Nm, which is about 5 ft-lbs. 60 would be about right for INCH-pounds. With a mix of metric and SAE bolts on many cars, be careful of which scale is being used.
BornAgainFordOwner is offline
Old 05-07-2005, 03:26 PM   #6
ampedout
ampedout's Avatar
Fan#: 16956
Sometimes I think a torque is too much. So, I do a double take to see if it was inches instaed of ft.
I will pull it off in an hour or two..
But you know, When it snapped I took off the wrench and jiggled it with my fingers. No play to it. If it had broken off above the head I would of felt some play. Im sure its broken off and still threaded a lil.
ampedout is offline
Old 05-07-2005, 04:18 PM   #7
ampedout
ampedout's Avatar
Fan#: 16956
Man, thank god! It didnt break off. Sure the hell sounded like it snapped! Its about to though.. a whole two threads are completely bent to hell. I hope I did no harm to the head.. Im gonna have to get some new bolts to use.
ampedout is offline
Old 05-07-2005, 04:26 PM   #8
blacksunshine
Fan#: 4254
What I Drive: 02 Black ZTS
FF Reputation: 1 blacksunshine Good Standing Member
zslaton, easy outs are like a drill bit designed to remove broken bolts or screws
blacksunshine is offline
Old 05-07-2005, 04:39 PM   #9
viney266
viney266's Avatar
Fan#: 93
Forum Activity 3%
They look like a backwards thread screw.. The go in and twist inward pulling the bolt out.. ONLY buy good easy outs cheap ones are USELESS.. Always try another way first if possible
viney266 is offline
Old 05-07-2005, 05:12 PM   #10
ampedout
ampedout's Avatar
Fan#: 16956
Indeed. We once used cheap easy outs to try to remove a head bolt from a 280ZX Datson. Short story, cheap made the problem worse. Machine shop couldnt even remove it. Had to get a new block.
My bolt came out.. Just about broke off, thank god these are grade 8 bolts. I craked two sides of the bolt..
Roush Turbo kit
ampedout is offline
