1999 Focus 2.0l, idle issue - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-07-2014, 06:30 PM   #1
Mitch2.0
Fan#: 181809
What I Drive: E46 M3
Points 109, Level 2
Points: 109, Level: 2 Points: 109, Level: 2 Points: 109, Level: 2
Level Up 18% Completed
FF Reputation: 1 Mitch2.0 Good Standing Member
Hi, I've just got a dirt cheap 2.0l Mk1 focus for my girlfriend, it has a little issue, the idle is very slightly rough, and also it sometimes cuts out when you come to a stop.
I've read this is either the Idle Control Valve, or the Vehicle Speed Sensor.
I've ordered the ICV first since it's only 23 and easy to fit, and if that doesn't work I'll replace the VSS, however does anyone know of anything else it might be?
Many thanks.
Mitch2.0 is offline
Old 08-08-2014, 12:43 AM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,863, Level 74
Points: 12,863, Level: 74 Points: 12,863, Level: 74 Points: 12,863, Level: 74
Level Up 4% Completed
Forum Activity 99%
Moved to General Tech Chat - Welcome to FF
Getting back to this one, rough running isn't going to be fixed by replacing the IAC valve even if that helps the stalling (and it's not the first thing to check/replace).
I'd want to know the compression is good with a test, spark plugs are likely due as well as fuel filter & maybe air filter. Plug wires & even Coil/coil wiring is suspect depending how bad the rough running symptoms are.
Zx3WV has mentioned the vacuum leak possibility, PCV hose is the most common for rough running/stalling there.
Needs some thorough checking over & maint. to be dependable.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 08-08-2014, 12:58 AM   #3
Zx3WV
Fan#: 180905
What I Drive: 2003 silver ZX3
FF Reputation: 1 Zx3WV Good Standing Member
It sounds to me like it could be a vacuum leak. get a can of carb cleaner and spray around the intake mani and around vacuum lines while the car is running and see if there is any idle change.
03 zx3 5 speed
Zx3WV is offline
Old 08-08-2014, 04:33 AM   #4
Mitch2.0
Fan#: 181809
Points 109, Level 2
It's a very mild roughness, you can just hear a slight uneveness, if you weren't a car guy you wouldn't even notice.
Vacuum leak is posible, it does have those types of sympthoms, I'm going to replace that PCV hose when I do the ICV, I imagine a little bit of hose is only a few quid.
Mitch2.0 is offline
Old 08-08-2014, 05:11 AM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
That's a plus, doesn't change the list of possibilities but it tends toward the simple/minor maint. type as the more likely ones for a fix.
We see so MANY that have problems in this section, when "cheap/used/problems" are seen in a description there's a tendency to cringe a little.
Luck getting it in good nick.
Cheers
"Rubber Side Down"
sailor is offline
Old 08-08-2014, 08:03 AM   #6
amc49
Fan#: 96610
Points 3,279, Level 35
Points: 3,279, Level: 35 Points: 3,279, Level: 35 Points: 3,279, Level: 35
Level Up 53% Completed
Forum Activity 13%
Vehicle speed sensor will have nothing to do with any of that, its' output is zero when car sitting idling.
While Idle control valve does control idle speed, it has no effect at all on 'rough' idle or cylinders dropping out irregularly to speed up/slow down the engine momentarily. That happens so fast the ICV cannot respond quick enough to correct it.
Fix the driver first, then fixing the car becomes so much easier.
amc49 is online now
Old 08-11-2014, 02:49 PM   #7
Mitch2.0
Fan#: 181809
Points 109, Level 2
I think I've figured the issue.
Installing a new ICV valve did actually improve things completely when cold, now there is just an issue when hot.
The problem I think lies with the PCV hose as mentioned above, it's not split, however the rubber near the bend that goes into the inlet manifold is very soft. As the engine gets hot it softens it even more and then under the suction it closes causing the engine to stall.
I've ordered a new hose for 14 delivered, fingers crossed!
Has anyone had this fault before?
Mitch2.0 is offline
Old 08-11-2014, 10:37 PM   #8
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
That's a common fault, the softness can cause a collapse when warm as you noticed.
Rough running/stalling being caused by a bad PCV hose is seen often here.
"Rubber Side Down"
sailor is offline
Old 08-11-2014, 11:47 PM   #9
amc49
Fan#: 96610
Forum Activity 13%
When soft enough they can suck a pinhole that reseals to drive you crazy too, the engine runs like crap then cures itself till next time. Next time may not be for a month.
amc49 is online now
Old 08-13-2014, 11:13 AM   #10
Mitch2.0
Fan#: 181809
Points 109, Level 2
http://www.gomog.com/allmorgan/ZetecIdleIssue.htm
This is a useful link.
If it isn't the PCV pipe, I guess I should try the Crankcase Breather Valve, it's lucky all these things are cheap, although that does look like a pain the change.
Mitch2.0 is offline
