Installing sub and amp to stock SYNC headunit - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-07-2014, 01:32 PM   #1
Nijmatic
Fan#: 181753
What I Drive: Gunmetal Grey 2011 Ford Focus SES
FF Reputation: 1 Nijmatic Good Standing Member
I've just recently bought a 2011 Focus SES with SYNC, just wondering how I would go about installing an Alpine amp and sub to the stock head unit . Any help would be appreciated.
Nijmatic is offline
Old 08-18-2014, 04:04 AM   #2
mechanizeddeath
mechanizeddeath's Avatar
Fan#: 135913
What I Drive: 2012 Ingot Silver Metallic SE
Points 1,641, Level 23
Points: 1,641, Level: 23 Points: 1,641, Level: 23 Points: 1,641, Level: 23
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 1 mechanizeddeath Good Standing Member
I don't know about the specifics of that year, but in general when adding an amp and sub to a stock head unit, you'll need to tap into at least one pair of speaker outputs and feed that to a line output converter which then goes to your amp.
Some amps have speaker inputs built in, but the general consensus seems to be that these integrated inputs are only marginally better than a cheapo passive line output converter, and an active converter, such as an AudioControl LC2i, is a much better option.
As far as tapping into the speaker outputs, that can be either easy or hard depending on your skill level. I generally don't recommend cutting up the factory wiring unless there's no other choice, and absolutely don't recommend using wire tap connectors! What I've always done is purchased a regular harness intended for installing an aftermarket car stereo, and a "reverse" harness, which is intended for repairing a damaged stock harness. Connect the two together and you have an inline connection that you can splice into that isn't part of the actual vehicle and can be removed if needed.
mechanizeddeath is offline
