Go Back   Focus Fanatics > Ford Focus Discussions > Ford Focus & General Car Chat
Old 12-24-2003, 09:20 AM   #1
Focus2000
Guest
Fan#:
Posts: n/a
rear window wiper problem
i have had a problem with my rear wiper since the day i got the car and i was wondering if yall would know what i could do to get it to work right? i won't explain but i will post a picture. if anyone could help..it weould be greatly appretiated.
Name:	rear window pic.jpg
Fan#: 1
Old 12-24-2003, 09:25 AM   #2
Fabster82
Fan#: 437
What I Drive: 2003 Focus zts
FF Reputation: 1 Fabster82 Good Standing Member
have you checked to see if its damaged? it could be just placed wrong and thats why it doesnt work. dont really know what to tell you much on that since my car is not a hatch
2003 Focus zts
twilight blue
Mods: clear corners, interior under seat neons, MAC short ram, a bosal exhaust or fs exhaust to come
Fabster82 is offline
Old 12-24-2003, 09:53 AM   #3
focuszx3r
Fan#: 1060
FF Reputation: 1 focuszx3r Good Standing Member
mine started doing that when I replaced the wiper. The solution I have decided to try but havent tested yet is to trim back the the side of the wiper under the arm. It seems to me that it is hitting the arm which is pushing up on the other side just enough to keep it from wiping correctly.
focuszx3r is offline
Old 12-24-2003, 10:02 AM   #4
JoeZX3
Fan#: 434
What I Drive: 2006 Subaru Impreza 2.5i and the 1986 VW Jetta
FF Reputation: 1 JoeZX3 Good Standing Member
I have this problem as well. Mine problem also started after replacing the rear blade. I have tried replacing it 4 times now with 4 different blades with the same results. It is annoying. I was thinking of just buying one from Ford as see if that helps. $8 for replacement rear blade from Ford. If it works, I could have saved money in the long run. I would like to know as well if anyone can fix this.
My 1986 Jetta is almost road worthy
JoeZX3 is offline
Old 12-24-2003, 11:01 AM   #5
Focus2000
Guest
Fan#:
Posts: n/a
thanks guys....got it fixed!!! it helps to have the wiper on the arm the right direction.
Old 12-29-2003, 02:46 PM   #6
Hockeyman
Fan#: 955
What I Drive: 02 Focus Wagon
FF Reputation: 1 Hockeyman Good Standing Member
Also make sure you lubricate the joint where the arm pivots... road grime, salt, and everything builds up in there so if its clean and lubricate you should have no problems.
Sometimes the arm needs to be bent to put a little extra pressure on the window to wipe it clean.
Hockeyman is offline
Old 11-27-2004, 02:30 AM   #7
Kalos
Fan#: 1733
What I Drive: '04 SVT, Silver
FF Reputation: 1 Kalos Good Standing Member
Unhappy
My rear wiper's not as bad as the photo, but it does streak a lot, and leaves areas of non-wiped glass.
Is there anything can be done ? A better brand of wiper blade ? Telflon blades maybe ?
Someone suggested streaking is caused by the wax left on the car as a final step in automatic car washes. Is there a solvent that cleans wiper blades effectively without removing the blade's "natural lubricant" ?
Kalos is offline
Similar Threads
Hmmm...ordered euro wiper (aka mazda 3 rear wiper) but no splines????? R00ST650 MK1 Focus 11 06-03-2006 01:32 AM
How do you disable rear wiper? InjuredZX3 General Technical Chat 11 05-04-2006 10:07 PM
rear wiper stuff Damien019 General Technical Chat 2 05-09-2005 05:41 PM
cops and tail lights olsenkicker26 MK1 Focus 14 03-18-2005 11:53 PM
Ford Focus: Suspension & Brakes hotfocus Wheels, Tires, Brakes & Suspension - Sponsored By Tire Rack 0 02-17-2005 03:40 AM
