2014 6 Speaker System Sound Upgrade - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-06-2014, 05:40 PM   #1
Sitdownpro
Fan#: 162818
What I Drive: 2014 Sparkle Gray Ford Focus SE
Points 419, Level 8
Points: 419, Level: 8 Points: 419, Level: 8 Points: 419, Level: 8
Level Up 38% Completed
Forum Activity 4%
FF Reputation: 1 Sitdownpro Good Standing Member
Wink 2014 6 Speaker System Sound Upgrade
Hey guys, I am building my sound system in my car within the next month or two. I will update pictures when stuff arrives and when I put it all in. This is going to run me about 3,000 (Edit: 4000)(edit the edit: 2500~). Below is all the links of materials I will be using. Enjoy and feel free to ask questions and give suggestions!
I am running about 1550RMS=124amps
Good information for people wanting to upgrade your system:
My factory alternator is 150amps @ 12.5v
150x12.5= 1875watts of RMS power.
Sub: Rockford Fosgate P3-2X12 12-Inch 2400W Dual Loaded Subwoofer Enclosure
http://www.vminnovations.com/Product...cpSRoCd3jw_wcB
Amp: Rockford Fosgate T1500-1bdCP
http://www.onlinecarstereo.com/CarAu...500-1bdCP.aspx
Bass Knob: Rockford Fosgate PPB1
http://www.onlinecarstereo.com/CarAu...urJhoCn5_w_wcB
Speakers:
-Front: Focal Performance PC 165
http://www.crutchfield.com/p_091PC16...65.html?tp=105
-Rear: JL Audio C2-650X
http://www.crutchfield.com/p_136C265...50X.html?tp=94
Speaker Baffles: Boom Mat 6-3/4" Speaker Baffles
http://www.crutchfield.com/S-TX1PAR7...e-3-depth.html
Speaker Wire: T-Spec 12 Gauge & 16 Gauge (100ft each)
http://www.crutchfield.com/p_120SW12...e.html?tp=2917
http://www.crutchfield.com/p_120SW16...e.html?tp=2917
Speaker Connectors: Metra Female Quick Slides
http://www.crutchfield.com/p_120FQS1...s.html?tp=2610
Wire Clamps: Metra Crimp Caps
http://www.crutchfield.com/p_120CCL1...s.html?tp=2610
Amp wirring kit: Kicker PKD1Dual 1/0 Gauge Power Amplifier Installation Kit
http://www.sonicelectronix.com/item_...cker-PKD1.html
RCA Cables: AudioQuest Sydney (3 of them =/ )
http://www.crutchfield.com/p_703SDRR...t.html?tp=1904
"Big 3" kit: XS Power BIG3XS XP FLEX 1/0 AWG Big 3 Upgrade Kit with 100% OFC Wire for Audio Sytems up to 350 Amps
http://www.sonicelectronix.com/item_...er-BIG3XS.html
Battery: XS Power D1200 XS Series 12V 2600 Amp AGM High Output Battery with M6 Terminal Bolt
http://www.amazon.com/XS-Power-D1200.../dp/B005FYJCPA
Line output controller: LC7i White - AudioControl 6-Channel Line Output Converter With Bass Restoration
http://www.valuefind.us/p/Lc7i-White...-17117978.html
LC7i is no longer needed since I found a dash kit and aftermarket headunit. Use this if you are not using an aftermarket HU.
(I don't need this for the amp I will be using)
A Little more to add to the list. 8-8-14
Dash kit:
-Vents: Metra VP-5827S 2012-UP Ford Focus Vent Panels (Silver)
http://www.sonicelectronix.com/item_...-VP-5827S.html
-Dash Kit: Metra 99-5827B Double/Single DIN Radio Installation Kit For 2012-Up Ford Focus
http://www.sonicelectronix.com/item_...ckId=991228177
(Ugh, I won't be putting in a headunit because I would rather put 2k to my car than the audio...)
Headunit: Alpine INE-W957HD
http://www.crutchfield.com/p_500W957....html?tp=20212
Steering Wheel Controls: Axxess ASWC-1
http://www.crutchfield.com/p_120ASWC...1.html?tp=3405
Speaker Amp: Alpine MRP-F300
http://www.crutchfield.com/S-VcgZ1Mn...-MRP-F300.html
Last edited by Sitdownpro; 08-27-2014 at 05:43 PM. Reason: Updated items, grammar, updated items... again.
Sitdownpro is offline
Old 08-07-2014, 09:27 AM   #2
HAL9001
HAL9001's Avatar
Fan#: 113056
What I Drive: 2013 Ingot Silver Focus Trend
Points 99, Level 1
Points: 99, Level: 1 Points: 99, Level: 1 Points: 99, Level: 1
Level Up 98% Completed
FF Reputation: 1 HAL9001 Good Standing Member
Look forward to seeing it. Subbed.
HAL9001 is offline
Old 08-08-2014, 02:20 AM   #3
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,326, Level 75
Points: 13,326, Level: 75 Points: 13,326, Level: 75 Points: 13,326, Level: 75
Level Up 19% Completed
Forum Activity 99%
Moved to the Car Audio section.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 08-08-2014, 10:21 PM   #4
Jeffrosilver07
Jeffrosilver07's Avatar
Fan#: 104592
What I Drive: 2007 Silver Focus SE
Points 527, Level 10
Points: 527, Level: 10 Points: 527, Level: 10 Points: 527, Level: 10
Level Up 54% Completed
Level up: 54% Level up: 54% Level up: 54%
FF Reputation: 3 Jeffrosilver07 Good Standing Member
Looks to me like you have a good list going on and one helluva project coming up. If I may I would like to make a suggestion.
You list that you will be using Focal coax front speakers and JL Audio coax rear speakers. I would suggest keeping the brands the same when it comes to fronts and rears. Only because the materials that the speakers are made of are completely different and it might mess with your sound staging. Focal tweeters are aluminum which are generally brighter then say the JL tweeter which is silk. It is going to be very hard to balance out the sound from front to rear because certain instruments will sound different between the two brands.
I would recommend either doing JL C2 coaxes up front as well or even step up to the JL C3 convertible speakers. That way the materials will be the same and the sound staging will be a lot more manageable.
Also why are you doing coax speakers up front? Correct me if I'm wrong but I thought all of the new Focus's had components up front. If you want to do coax's instead of components the JL C3 can be mounted either way.
Just my 2 cents. Good luck with the project I look forward to seeing the build.
Jeffrosilver07 is offline
Old 08-11-2014, 02:22 PM   #5
Sitdownpro
Fan#: 162818
Points 419, Level 8
Forum Activity 4%
Trouble with keeping the brands is that I don't want to have to change the brackets in my doors and I only went off of the speakers that crutchfield has listed, and the focals said they wouldn't fit. If there is a pair that will fit I would gladly use them.
COaxle vs component. I have never messed with them before. Would I need to screw into the door for the tweeter or would it fit in the current location? I wouldn't mind getting component if they fit easily. I do have stock tweeters there.
Old 08-11-2014, 10:01 PM   #6
Jeffrosilver07
Fan#: 104592
If your car has stock tweeter locations then you should be able to use the stock hole. To mount the tweeter either make a bracket to mount from behind or you can use hot glue to hold the tweeter in place.
Old 08-27-2014, 05:44 PM   #7
Sitdownpro
Fan#: 162818
Points 419, Level 8
Forum Activity 4%
Is that a custom box in your trunk? Do you have a build thread?
Old 08-27-2014, 07:48 PM   #8
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,772, Level 54
Points: 6,772, Level: 54 Points: 6,772, Level: 54 Points: 6,772, Level: 54
Level Up 11% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
There is no soundproofing on your list
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 08-28-2014, 10:13 PM   #9
Jeffrosilver07
Fan#: 104592
Yes and Yes. I have the whole system build in these forums somewhere.
Freemind is right... there needs to be sound proofing in your budget somewhere. You can make a inexpensive speaker sound so much better with it.
Old 08-29-2014, 11:07 AM   #10
Sitdownpro
Fan#: 162818
Points 419, Level 8
Forum Activity 4%
Well I can soundproof my doors, but that's about it I would think. Any threads on someone soundproofing the hatch?
