2003 Zetec on 2002 focus zx3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 08-06-2014, 03:02 PM   #1
1988ttop
Fan#: 120313
What I Drive: 2002, focus zx3, dark grey
Points 72, Level 1
Points: 72, Level: 1 Points: 72, Level: 1 Points: 72, Level: 1
Level Up 44% Completed
FF Reputation: 1 1988ttop Good Standing Member
I currently own a 2002 focus zx3, The engine in the car has seen better days and it needs to go. A friend of mine is selling me a 2003 zetec engine with 60k miles for $200. Is there any mayor difference between both engines that I should know of before I attempt the swap. I would like to do the swap over the weekend and I canít afford to run into any surprises since I need the car running on Monday. I am afraid the wire harness might have different connectors for some sensors. Any help would be appreciated.
1988ttop is offline
Old 08-06-2014, 04:18 PM   #2
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,663, Level 62
Points: 8,663, Level: 62 Points: 8,663, Level: 62 Points: 8,663, Level: 62
Level Up 72% Completed
Forum Activity 46%
Activity: 46% Activity: 46% Activity: 46%
nope. both are Zetec motors so are the same.
IIRC there was some variant on the shifter between years but think that was different years than your using and would not be touched with just a motor swap.
The motor it self only has 3 sensors...
Knock, Cam position, and oil pressure.
all the other connectors are on other parts like the Intake Manifold, TB, accessory parts, transmission, injectors/fuel rail, coil pack. to my knowledge those three connections did not change from any year of the Zetec motor.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 08-06-2014, 06:13 PM   #3
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,536, Level 100
Points: 52,536, Level: 100 Points: 52,536, Level: 100 Points: 52,536, Level: 100
Level Up 0% Completed
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
Buy-Sell-Trade Rating: (28)
You also have the crank trigger sensor , the aluminum holder that holds the crank sensor from ATX to MTX IS NOT THE SAME , make sure to change this part from your engine to make sure it is the same crank sensor holder , if it is wrong the engine will not start
You also have TPS sensor , water temp sensor , fuel rail sensor ,
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 08-06-2014, 06:22 PM   #4
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 46%
Forgot about the water temp... that's in the head. the fuel rail and TPS are not on the motor though right? He might be transferring that over from what he is replacing it on.
He did not note if the transmission was different, are they both Automatics or both Manuals? Either way watch for the little aluminum plate that Tom talked to.
Hatch Nation #42
Old 08-06-2014, 11:48 PM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,419, Level 75
Points: 13,419, Level: 75 Points: 13,419, Level: 75 Points: 13,419, Level: 75
Level Up 43% Completed
Forum Activity 99%
Yep, check them over for any differences & swap in your old sensors to the replacement engine as needed.
Doesn't hurt as you KNOW those are working right already, and the replacements are an unknown. (the ones on the replacement engine)
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
