Boost hose how too - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-28-2014, 08:44 PM   #1
imfocused03
imfocused03's Avatar
Fan#: 787
What I Drive: 03 svt
Points 2,148, Level 27
Points: 2,148, Level: 27 Points: 2,148, Level: 27 Points: 2,148, Level: 27
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 1 imfocused03 Good Standing Member
Boost hose how too
I have a turbo with the turbo nipple a turbonetics wastegate a Manual boost controller and a boost gauge. My question is in what sequences do I run the boost hose lines to all these different items
imfocused03 is offline
Old 07-29-2014, 12:40 PM   #2
sporadic
sporadic's Avatar
Fan#: 12724
What I Drive: 06 Sonic Blue ZX5 SES turbo
Points 12,999, Level 74
Points: 12,999, Level: 74 Points: 12,999, Level: 74 Points: 12,999, Level: 74
Level Up 38% Completed
Forum Activity 4%
FF Reputation: 61 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
I personally like using a vacuum block to simplify house routing, like this one.
First, cap off that nipple on the turbo. Use your intake manifold for a better boost/vac signal.
Manifold -> vac block
vac block -> boost gauge
vac block -> boost controller -> wastegate
vac block -> BOV
Each arrow is a hose.
Here is my vac block with outlets to boost gauge, meth injection controller, BOV, and wastegate.
2006 sonic blue zx5 GT2871r turbo.
sporadic is online now
Old 07-29-2014, 11:33 PM   #3
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2012 Mazdaspeed 3, TURBO ZX3
Points 51,036, Level 100
Points: 51,036, Level: 100 Points: 51,036, Level: 100 Points: 51,036, Level: 100
Level Up 0% Completed
Forum Activity 2%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
I need a vac block like that. I have so many tee coming off my intake
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 07-30-2014, 12:01 AM   #4
Mother Focus
Mother Focus's Avatar
Fan#: 73292
What I Drive: 2001 Money Pit
Points 4,667, Level 43
Points: 4,667, Level: 43 Points: 4,667, Level: 43 Points: 4,667, Level: 43
Level Up 59% Completed
FF Reputation: 13 Mother Focus Great Standing Member
Buy-Sell-Trade Rating: (9)
Or have an intake manifold with the ports welded in ;)
PTE 6262CEA
Pump Gas 385whp 319wtq
Race Gas 551whp 439wtq
Tuned by Fernando@RacingPartsSolution.com
Mother Focus is offline
Old 09-03-2014, 03:20 PM   #5
inkedfireman
inkedfireman's Avatar
Fan#: 21193
What I Drive: 2002 Yellow ZX3
Points 107, Level 2
Points: 107, Level: 2 Points: 107, Level: 2 Points: 107, Level: 2
Level Up 14% Completed
FF Reputation: 1 inkedfireman Good Standing Member
Interesting. The instructions that came with the eBoost2 specifically say to route off between the turbo and the intercooler, preferably right off of the turbo housing. I had a port for it on my intake, and capped it because of what the directions said.
inkedfireman is offline
Old 09-03-2014, 03:29 PM   #6
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
I can't use that manifold. Idk how to set up the iacv on that and different pipe. Be nice if I didn't need diff pipe for that manifold.
FF MODERATOR
RIFF CREW
Old 09-03-2014, 03:36 PM   #7
inkedfireman
Fan#: 21193
Points 107, Level 2
As for the boost controller routing, you would want the boost controller between the boost source (turbo housing or IM) and the wastegate. I would tee the boost gauge to show what you are seeing as the selected boost level, so it too would go after the boost controller, or on its own source at the IM.
I'm going to thread-jack a little bit, anyone know if you need to put in one-way valves in the vacuum lines that go to the intake manifold when you go turbo, like the vapor recovery system, or any of the other lines that come off the intake? Only the brake booster comes with one in it. I'm not sure what will happen if you expose the vapor recovery system to boost.
Old 09-03-2014, 03:48 PM   #8
inkedfireman
Fan#: 21193
Points 107, Level 2
Because you brought it up, here's how I'm getting around the IAC and the vacuum port sources with an aftermarket intake. Keep in mind that it has not run yet, so my remote IAC is as of now untested.
I'm using -10 AN fittings, the top one is welded to my intake piping from the intercooler, just before the throttle body. The bottom one is welded on the intake just after the throttle body. My hope is by keeping these lines very short, I will minimize idle speed hunting.
Here is the remote IAC mounting plate, resting on the intake runners for the pic. I had aluminum -10 socketless hose barbs welded to it, the stock IAC screws on the opposite side. I'm going to run just enough hose to bridge between the two fittings shown earlier.
Here are the vacuum ports I had welded into my Jay Racing IM, in lieu of running a vacuum manifold. I can't say that a vacuum manifold won't work, or that you'd definately see a difference doing it this way, but I can't see where each thing needing a vacuum source would be hurt by having it's own port. Certain things, like the BOV, specifically say not to share with another item on a tee.
Old 09-03-2014, 05:20 PM   #9
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 2%
What about the sensor for it thou? Doesn't that throw a CEL. Or brake booster. How's that set up?
FF MODERATOR
RIFF CREW
Old 09-03-2014, 09:27 PM   #10
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,496, Level 100
Points: 52,496, Level: 100 Points: 52,496, Level: 100 Points: 52,496, Level: 100
Forum Activity 55%
Buy-Sell-Trade Rating: (28)
You dont need the BAP switch , use the manifold for the boost ref to the WG and to the BC and keep them short
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
