How does the SVT VCT work? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-30-2005, 07:53 AM   #1
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,536, Level 100
Points: 52,536, Level: 100 Points: 52,536, Level: 100 Points: 52,536, Level: 100
Level Up 0% Completed
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
Buy-Sell-Trade Rating: (28)
There seems to be a ? on how the SVT VCT works or what it is that is does
I have had the chance to play with the VCT on many SVT and have Elim it on 3 SVT now , If the VCT truely changed(Retard) the cam angle to where you had better performance in the lower end and (Advance) it in the top than going to the VCT Elim we would see a less bottom end HP/TQ and more upper end HP/TQ
With what i have seen installing a VCT Elim there was a 5 to 6 HP/TQ loss at 1000 2,3.4.5.6.7000 Rpms , There was NO loss of HP/TQ more in the bottom or top as there should of been IF the VCT is truely changing the cam angle for performance , Keep in mind that there has yet to be any tuning done to this car to see if the loss of HP/TQ can be brought back
I have played with the settings in the software and got a small gain from changine the VCT setting from factory -45 to -60 and a few others only to show some surging issues , I have only seen this to be a gain on about 6 of the 50 or 60 cars i have dynoed
I feel that the SVT VCT is there for emmissions as in the case of the VCT on the ZX2
I will be playing more with this because i see so many of them not working properly and the parts to repair them are costly when the warranty runs out
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 04-30-2005, 12:55 PM   #2
davlafont
davlafont's Avatar
Fan#: 16413
What I Drive: 2002 SVT Focus
FF Reputation: 1 davlafont Good Standing Member
Re: How does the SVT VCT work?
Originally posted by 1turbofocus
I feel that the SVT VCT is there for emmissions as in the case of the VCT on the ZX2...
Judging by your own observations, it seems that the VCT is there to provide 5-6 hp/tq across the entire operating range .
What RPM is your replacement optimized for? The VCT should equal a fixed cam at what ever RPM the fixed cam was designed for but show improvements elsewhere in the powerband. That presumes the VCT cam is worth a damn of course, but it's a reasonable assumption. Given your results, I would say SVT gets a pat on the back.
BTW, this comes from someone whose sole engineering credential is that I read a lot of Car&Driver (etc.) during my misspent youth. Thanks for looking into the issue of what becomes of these sophisticated engines once the warranty runs out.
Dave
2002 SVTFocus #2629
SVT Squad #106
Visit Dave's Daily Driver
davlafont is offline
Old 04-30-2005, 01:15 PM   #3
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Interesting...
That's completely opposite of how pushrod single cam V8s respond.
Advancing the cam increases low end power, while retarding increases top end.
I'm sure part of the reasoning, is both intake and exhaust are controlled by one cam.
Keep us tuned (pun intended) Tom!
Thanks for the write up.
WD40 is offline
Old 04-30-2005, 02:09 PM   #4
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 61%
No with the VCT Elim installed i can add to the bottom end or add to the top end depending on if i advance the cam or retard the cam
What im saying is if the ECU is truely controling the Adv. Ret, then installing the VCT Elim and it not being VC there should of been more of a loss in the bottom or in the top and it was all the same
Like i said the loss of HP has yet to me checked to see if changing the tuning will bring it back
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 05-02-2005, 09:07 AM   #5
finalley
Fan#: 386
What I Drive: 04SVTF, 03SVTF,08F150 4x4, 2013ST3
Points 1,316, Level 20
Points: 1,316, Level: 20 Points: 1,316, Level: 20 Points: 1,316, Level: 20
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
FF Reputation: 5 finalley Good Standing Member
Quick side question Tom. When you eliminate the gear, and it's controlled by oil press, is the overall pressure affected??I mean is the oil opening filled back in with the VCT elim??
I ask because I noticed a pressure drop at idle.
...Success or Failure is not an Event, It is a Process... 04SVT custom pressurized intake,@20lbs..340HP/338TQ, by Tom...
..............ridden Hard and put away Wet...
finalley is offline
