oil in intercooler,bov,and throttle body,help! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-17-2014, 01:02 AM   #1
Walkerb7
Fan#: 158786
What I Drive: 2003 silver zx3
FF Reputation: 1 Walkerb7 Good Standing Member
Iv been noticing the joints from my intercooler to the intake side has been leaking and today my bov started blowing out oil,and oil in my throttle body ,my turbo is boosting fine and no smoke or large amounts of oil usage. Only thing I could guess was the hose from my crankcase vent leads to the air filter that sits right in front the turbo where it sucks in air could have blown oil through the system? How can I clean the intercooler and pipes ,and stop this crankcase oil from getting blown into turbo system. I'm new to turbo setup,help would be great!
Walkerb7 is offline
Old 07-17-2014, 01:30 AM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,417, Level 75
Points: 13,417, Level: 75 Points: 13,417, Level: 75 Points: 13,417, Level: 75
Level Up 42% Completed
Forum Activity 99%
Moved to the Forced Induction section for more help.
Not the turbo expert myself, most mention using a filter on the valve cover (intake) PCV system hose & a catch can on the engine (PCV outlet) hose for turbo systems.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 07-17-2014, 01:37 AM   #3
Walkerb7
Fan#: 158786
Thanks there is only one hose from the valve cover?
Walkerb7 is offline
Old 07-17-2014, 02:12 AM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
PCV hose from engine to intake is more hidden (behind intake) than the obvious one to the valve cover.
Normal PCV air flow is from the valve cover hose through the engine, then through oil separator in the side (helps direct oil droplets back to the pan) through the PCV valve to the intake.
When this is left connected to the intake, under boost there is no normal PCV flow (PCV valve sealing) and all blow by has to find it's way out the normal inlet tube at the valve cover. PCV valve could stop sealing well and then you'd be loosing boost back through the engine & out the top hose.
Either way you end up with a lot of engine gasses & oil finding their way out that top tube & into the intake.
"Rubber Side Down"
Old 07-17-2014, 09:09 AM   #5
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,536, Level 100
Points: 52,536, Level: 100 Points: 52,536, Level: 100 Points: 52,536, Level: 100
Level Up 0% Completed
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
Buy-Sell-Trade Rating: (28)
You need to vent the valve cover and PCV to atmosphere and not back into your engine
Did you just add this boost ? is it smoking ? whats your under boost WOT air fuel ?
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 07-17-2014, 09:27 AM   #6
marslog
Fan#: 176753
What I Drive: 2005 red zx3
FF Reputation: 1 marslog Good Standing Member
I was having the same issue. I put a oil catch can, with a filter on it, off the valve cover breather. I have it venting out the filter, not back into the intake. Left the pcv valve hooked up the intake manifold. Have not had an issue since.
marslog is offline
Old 07-17-2014, 12:09 PM   #7
Walkerb7
Fan#: 158786
Is there anyway I could see a picture of how yours is setup, and there is no smoke at all and my wide band air fuel gauge runs a little lean but that's how it was tuned,and how can I clean all of the oil out?
Walkerb7 is offline
Old 07-17-2014, 01:11 PM   #8
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 7,191, Level 56
Points: 7,191, Level: 56 Points: 7,191, Level: 56 Points: 7,191, Level: 56
Level Up 21% Completed
FF Reputation: 15 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (10)
^yeah, if you have your PCV system hooked up this will cause the issue you're having. Def get a catch can.
FSWerks stg2 w/ water/meth; Cossie intake.
PSUrivie is offline
Old 07-17-2014, 04:17 PM   #9
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 61%
Whats your WOT air fuel , if your running lean or to much timing this will cause excessive oil and blow by
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
