Ford Focus SVT SCCA T4 Build - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Road Racing & Rally
Road Racing & Rally The place to discuss information about road/rally racing stats, tips and events. Track sanctioned events only.
Old 07-15-2014, 04:19 PM   #1
golfitup
golfitup's Avatar
Fan#: 81087
What I Drive: #93 H-Street 2002 Focus SVT
Points 809, Level 15
Points: 809, Level: 15 Points: 809, Level: 15 Points: 809, Level: 15
Level Up 9% Completed
Forum Activity 12%
FF Reputation: 1 golfitup Good Standing Member
Hi,
I am looking at doing an SCCA T4 class race build this fall/winter in my 2002 3-door.
1st question is about coilovers. We are allowed a non-adjustable shock with threaded coilovers. Spring rates can be up to 500lbs front and 800lbs rear. Stock front bar and aftermarket rear bar allowed up to 32mm.
What options does this leave me for coilovers other than the custom route? I have been looking at a few racing companies for custom setups but wow they are expensive!
Thanks!
Duane
golfitup is offline
Old 07-16-2014, 03:17 AM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,363, Level 75
Points: 13,363, Level: 75 Points: 13,363, Level: 75 Points: 13,363, Level: 75
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 99%
Here's a link to a thread including comments by two experienced SCCA racers :http://www.focusfanatics.com/forum/showthread.php?t=391962
They would have better info. as they've been involved for a while.
When I googled for a little info. I found an SCCA question thread of yours, so it was a bit circular (grin).
I'd guess that you could use any shocks/struts you wanted, as long as the adjustment capability was defeated on race day. Set adjustments as desired, then remove knobs/epoxy over screws,adjusters so it can't be adjusted at the track/during a race. I wouldn't think a permanent defeat would be needed, but it couldn't be a method easily reversible at the track (just removing a knob wouldn't be adequate).
Racing can be expensive, picking a car & class to run it in has the largest effect on what you'd need to budget both to compete & to try to be competitive.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 07-16-2014, 02:43 PM   #3
ecugrad
Fan#: 99968
What I Drive: 2002 Sonic Blue Ford Focus SVT
Points 459, Level 9
Points: 459, Level: 9 Points: 459, Level: 9 Points: 459, Level: 9
Level Up 18% Completed
FF Reputation: 1 ecugrad Good Standing Member
Thanks!
Duane
Anything of quality is going to have to be custom I'd suggest looking at Bilsteins since they are easy to re-valve. I keep getting evil ideas of putting together some custom strut housings for the R36-5022 3000GT/Stealth front struts for my SVT.
2003 Sonic Blue SVT Focus- Prepped for STF
Going slower than no man has gone before....
ecugrad is offline
Old 07-16-2014, 02:54 PM   #4
Schroeder02
Moderator
Schroeder02's Avatar
Fan#: 53191
What I Drive: 2013 Red ST & 2009 Focus Race Car
Points 5,488, Level 47
Points: 5,488, Level: 47 Points: 5,488, Level: 47 Points: 5,488, Level: 47
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 62 Schroeder02 Excellent Standing Member
Buy-Sell-Trade Rating: (7)
You could try contacting KW and see if they could custom valve a set of V1's I know they offer a rebuilding service. So it may possible they could custom valve a set of shocks for you.
My rides a 2002 SVT track car, & Boosted 2007 ST with the SAP.
The helmet has a special meaning for many drivers. How important is it to you? - It protects my head.
Do you have any special rituals when the helmet is concerned like many have? - I wipe it so that I can see better.
Schroeder02 is offline
Old 07-16-2014, 07:21 PM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Reading over the rules later, they're wide open as to fitting different springs with adjusters to make them work or even helper springs to take up a difference at full droop. That would allow coilovers or struts modified to work as coilovers with shocks/struts being open.
Non-adjustable shocks/struts is also very clear, so even though any shock/valving that's non-adjustable is OK I can imagine a protest over adjustable shocks modified to make them non-adjustable. It's B.S. protest, but you'd need to know how prev. decisions went to know if it would be a likely problem.
Having heard how nit-picky things can get, unless you knew that kind of modification was common & accepted you'll have to bite the bullet & go with something that never had adjustable capability.
"Rubber Side Down"
sailor is offline
Old 07-17-2014, 11:02 AM   #6
golfitup
golfitup's Avatar
Fan#: 81087
Forum Activity 12%
What about ground control sleeves with revalved Bilstein shocks to race specs? Anyone use the GC sleeves now?
golfitup is offline
Old 07-17-2014, 01:33 PM   #7
ecugrad
Fan#: 99968
Points 459, Level 9
Ground Control does not make kits for our car anymore.
ecugrad is offline
Old 07-17-2014, 01:38 PM   #8
golfitup
golfitup's Avatar
Fan#: 81087
Forum Activity 12%
Finding a set (used or new) cant be impossible lol
golfitup is offline
Old 07-17-2014, 01:57 PM   #9
ecugrad
Fan#: 99968
Points 459, Level 9
I still haven't found a set of actual GC's, settled on a set of OBX's after looking for 2 years
I'm telling ya', shocks/coilovers are going to be the biggest PITA of your build.
ecugrad is offline
Old 07-17-2014, 02:15 PM   #10
golfitup
golfitup's Avatar
Fan#: 81087
Forum Activity 12%
Anyone ever bought from here? http://www.shox.com/
They claim to have access to some GC sleeves if you put in 99 and up Focus. Maybe from overseas?
The cheapest decent custom race setup is gonna be around $2900. Im pretty sure I can do it for less than that if I could find some GC sleeves.
golfitup is offline
