procharger install: belt problems - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 07-09-2014, 08:07 PM   #1
j_thielmann
Fan#: 56531
What I Drive: 2001 Burgundy ZX3
FF Reputation: 1 j_thielmann Good Standing Member
I just finished installing a procharger and after running for about two minutes, the belt is off on the ac pulley by one rib. It is causing it to bend the rib up over the outside of the pulley. As far as I can see, all the pulleys are lined up correctly, but maybe the procharger pulley is slightly more towards the outside? Is there any way of adjusting the procharger pulley? Or any other options?
j_thielmann is offline
Old 07-12-2014, 12:43 PM   #2
blanezx3
blanezx3's Avatar
Fan#: 764
What I Drive: 03 twi-blue zx3
Points 2,468, Level 30
Points: 2,468, Level: 30 Points: 2,468, Level: 30 Points: 2,468, Level: 30
Level Up 12% Completed
FF Reputation: 5 blanezx3 Good Standing Member
Buy-Sell-Trade Rating: (10)
Is the PC fully seated in the bracket?
performance?
FR stg 2 cams, UR cam gears, FC 65mm TB, ported 2k manifold, 50lb injectors, FC race header, Bosal flex, Borla catback, Zex, Procharger, Xcal2
blanezx3 is online now
Old 07-13-2014, 07:31 PM   #3
j_thielmann
Fan#: 56531
Yes it is. Looking at it again, the ac pulley could be the one that is off. I took a few pics to try and show what I mean as best I could
Old 07-23-2014, 02:56 AM   #4
Paladin
VEKTOR PLATE
Paladin's Avatar
Fan#: 64465
What I Drive: blue sub #6
Points 5,736, Level 48
Points: 5,736, Level: 48 Points: 5,736, Level: 48 Points: 5,736, Level: 48
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
Forum Activity 3%
FF Reputation: 10 Paladin Great Standing Member
didnt know you were in kiel!! as for your issue, the bracket that attaches to the a/c compressor has slotted holes in it to adjust this. if its at its max adjustment to get it close as possible. you may need to slot the holes a little farther and grind the spacer that bolts to teh block down a little bit as well to get it all lined up perfect should solve the issue. try loosening those three bolts and tweaking that end to get it lined up first before busting out the dremel.
MR. freaking negative
i'm not an enthusiast...... the internets told me.
Paladin is offline
