SCT Pro Racer help - Page 10 - Ford Focus Forum, Ford Focus ST Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum > Exclusive Vendor Discussions > Focus-Power Tuning
Focus-Power Tuning Discuss about forced induction upgrades and performance tuning for your Ford Focus.
Sponsored By: Focus-Power
Old 11-25-2007, 12:15 AM   #91
Metal
Metal's Avatar
Fan#: 14271
What I Drive: 2003 Sonic Blue SVT
FF Reputation: 3 Metal Good Standing Member
Two questions...my borderline knock table only goes up to 1.0 load...even after I modify the normalizers. The other tables (octane plug spark, spark adder after load, etc) scale up but not the BKT...am I adjusting the wrong normalizers for this? I'm changing the values in the table "Ynorm Borderline Knock 09"
Second is, since I'm using a J&S I want to turn down the stock knock sensor and let the J&S do the timing pulling correct? So I would subtract from the values in the tables under the Knock Sensor category? "Maximum amount of spark retard" and "Maximum value of slow correction".
'03 Sonic Blue SVT:
Custom turbo kit, T3/T4 50 trim, 3" turbo back exhaust, all 3 VF Motor mounts, 65mm TB, tuning with PRP, etc...
Metal is offline
Old 11-25-2007, 07:00 AM   #92
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 50,457, Level 100
Points: 50,457, Level: 100 Points: 50,457, Level: 100 Points: 50,457, Level: 100
Level Up 0% Completed
Forum Activity 25%
Activity: 25% Activity: 25% Activity: 25%
Buy-Sell-Trade Rating: (28)
If you give me a call Monday I will walk you through changing the norms to make sure you dont have a software issue
As for the J&S you want to just turn off the KS all the way and set all valuse in the KS to 0 before turning it off
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 11-25-2007, 09:33 AM   #93
Metal
Metal's Avatar
Fan#: 14271
Ah I figured out the BKT normalization. the BKT itself uses the normalizer from the MBT, by adjusting this I was able to get the BKT to be where I wanted it. Thanks for the info on the J&S Tom!
One more thing...I'm having an issue with it hunting at idle the spark goes all over from 7-14 with some spikes to 23 and you can feel it in the idle. The spark source is 9 so it's in control and everything else seems to be in check ISC hovers right around 0, stft are within 2-3% of 1.00..but it just doesn't want to stay in check with the spark. What could be possible causes of this?
'03 Sonic Blue SVT:
Metal is offline
Old 11-25-2007, 09:37 AM   #94
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 25%
That is a common issue with the SVT and SCT has no answer for it you will see your timing very low at idle and part throttle much lower then your Borderline tables command it to be. John is having the same issues
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 11-25-2007, 10:00 AM   #95
Metal
Metal's Avatar
Fan#: 14271
Hm well that kind of sucks...have you guys figured out any work arounds for it? In my case it's making my idle pretty rough.
Edit: I figured out my rough idle...it turned out to be the 65mm throttle body when I was n/a I never had a problem so I didn't look but I did just now and saw that the stop screw was backed all the way out...so I disconnected the IAC and set the idle using the screw, reconnected it and readjusted the ISC neutral air and the idle is much smoother and the spark values aren't going all over. :)
'03 Sonic Blue SVT:
Metal is offline
Old 12-26-2007, 03:27 PM   #96
hypnoticracing
Fan#: 51709
What I Drive: 2003 Focus Sedan Zetec 5 Spd
FF Reputation: 13 hypnoticracing Great Standing Member
Buy-Sell-Trade Rating: (19)
hi tom my name is bob i bought the prp off of you a while ago as well as some wiseco pistons and stuff, you loaded a turbo tune on but i changed my mind and didnt go turbo. we ahd teh rebuild the motor a couple weeks ago and shaved teh head .020 as well as installed an aluminum flywheel i was wondering if you could set me up with a base tune so i could drive the car to the dyno without harming the engine thank you tom you have been a ton of help
hypnoticracing is offline
Old 02-21-2008, 04:44 PM   #97
ROC
Fan#: 13218
What I Drive: 2000 focus zetec 2.0 automatic
FF Reputation: 1 ROC Good Standing Member
SCT Program Then They Do Expired? Is This Gadget I Got From Mcnews Automotive A Fews Years Ago Needs To Be Reprogramed???? 1 Turbofocus What Do You Expertize In? I Will Be Needing A Few Extra Mods For My 2000 Zetec Sedan. Mcnews Automotive Performed Some Work On My Focus A Few Years Ago Ford Racing Camshaft-Esslinger Cam Gears-SCT-Random Tech Cat-Borla Full Cat Back- True Bend Flex Pipe-JDM Headers-65mm Throttle Body- Gotta Send My Focus Over Sea's To Puerto Rico In July 08. Tell Me Dude" I Get This Code P0705 Transmission Range Sensor Cicuit Malfunction. Tired Of It! Would Like To Get Some Extra Power On My Tranny And Some Torque.., DO You Know Of Anyone In NEw Jersey That Can Be Of Help To Me. Tired Of This Stock Tranny, Im Not Into Racing Just Need Extra Power,
ROC is offline
Old 02-21-2008, 04:45 PM   #98
ROC
Fan#: 13218
SCT Program Then They Do Expired? Is This Gadget I Got From Mcnews Automotive A Fews Years Ago Needs To Be Reprogramed???? 1 Turbofocus What Do You Expertize In? I Will Be Needing A Few Extra Mods For My 2000 Zetec Sedan. Mcnews Automotive Performed Some Work On My Focus A Few Years Ago Ford Racing Camshaft-Esslinger Cam Gears-SCT-Random Tech Cat-Borla Full Cat Back- True Bend Flex Pipe-JDM Headers-65mm Throttle Body- Gotta Send My Focus Over Sea's To Puerto Rico In July 08. Tell Me Dude" I Get This Code P0705 Transmission Range Sensor Cicuit Malfunction. Tired Of It! Would Like To Get Some Extra Power On My Tranny And Some Torque.., DO You Know Of Anyone In NEw Jersey That Can Be Of Help To Me. Tired Of This Stock Tranny, Im Not Into Racing Just Need Extra Power, I Can Also Be Reached At tmroc@yahoo.com 973-704-3069
ROC is offline
Old 04-06-2008, 04:26 PM   #99
FocusRacingAustrali
FocusRacingAustrali's Avatar
Fan#: 45865
What I Drive: 2003 ZX4 & 2004 ZX5
Points 4,947, Level 44
Points: 4,947, Level: 44 Points: 4,947, Level: 44 Points: 4,947, Level: 44
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 6 FocusRacingAustrali Good Standing Member
Buy-Sell-Trade Rating: (13)
Originally Posted by CatMostFeared View Post
anyone get the new Live Wire
http://www.sctlivewire.com/lwmain.php
  • Pre-Loaded or Custom Tuned!
  • Data Log Info that Matter!
  • Displays estimated HP, TQ, 1/4 Mile ET's & 0-60MPH
  • Built-In High Intensity LED Shift Light
http://www.sctflash.com/shop/product...products_id=37
is this the same 1?
Will this work on 03-04 Zetec at all?
Is it plug and play or do you have to wire it in?
My ECU code is WYl1
Cheers
Rob
I only worthship the HP gods []
A false Hp god: Foolish are those who always have wild claim and know fear nothing, yet claim to know everything.
FocusRacingAustrali is offline
Old 04-07-2008, 03:51 AM   #100
FocusRacingAustrali
Fan#: 45865
Bump
