2014 Focus SE sedan Kicker speaker upgrade - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-26-2014, 11:19 PM   #1
green_plaid
Fan#: 171817
What I Drive: 2014 Oxford White Focus SE sedan
Points 362, Level 7
Points: 362, Level: 7 Points: 362, Level: 7 Points: 362, Level: 7
Level Up 24% Completed
FF Reputation: 0 green_plaid Newbie
While waiting to get my headlights ready for a HID retrofit I decided to start getting some other stuff done. So here it is...Kicker CS speakers all around; 6.75 front and 6.5 rear, Crutchfield speaker adapter brackets, and stainless hardware all around. Installed without all the additional dampening lead only to disappointment upon the first listen. So I started all over again...covered all metal that wasn't covered by plastic with GTMAT Ultra, added some to the inside of the doors, added some felt where the door panel touched the door and plastic welded all of the door panel rivets. The result...surprising deep bass and clarity that surpasses oem by a huge margin. Another plus...no more door rattles either! Pics are not that great but its something. These speakers are a great and simple OEM upgrade even when driven by the oem non Sony headunit. Next will be a sub of some sort... not sure what though.
green_plaid is offline
Old 06-26-2014, 11:23 PM   #2
green_plaid
Fan#: 171817
Points 362, Level 7
forgot to mention...also drenched all of the inside and outside seams with Fluid Film. Ill hopefully get the car complete covered soon.
Old 06-27-2014, 12:57 AM   #3
fenway1912
Fan#: 116879
What I Drive: 2013 Focus SE
Points 10,707, Level 68
Points: 10,707, Level: 68 Points: 10,707, Level: 68 Points: 10,707, Level: 68
Level Up 65% Completed
Forum Activity 4%
FF Reputation: 2 fenway1912 Good Standing Member
Nice! I would love to have a shop do this for me if I decide to buy the car - if anything to just get rid of the occasional rattles in the doors.
What does this Crutchfield speaker adapter brackets do? Is it so you don't have to cut the factory speakers out (in order to reuse the factory brackets)?
Maybe I can actually put in upgraded speakers before warranty even runs out!
fenway1912 is offline
Old 06-28-2014, 12:32 AM   #4
green_plaid
Fan#: 171817
Points 362, Level 7
The brackets from Crutchfield required two holes to be drilled. I cringed at the thought of doing this but the way they are mounted now is very solid. That is why I used stainless steel bolts and fluid film... lessen the chance of corrosion.
Old 06-30-2014, 10:46 AM   #5
BTM757
BTM757's Avatar
Fan#: 140401
What I Drive: 2014 Race Red Focus SE Hatch
Points 217, Level 4
Points: 217, Level: 4 Points: 217, Level: 4 Points: 217, Level: 4
Level Up 34% Completed
FF Reputation: 1 BTM757 Good Standing Member
They must have sent you different brackets than the ones they sent me back in March. Mine did not require any drilling.
I do like the sound deadening though. When I get the money I would like to cover as much metal as possible in the doors. This car is already really quiet and I am sure can be made a lot quieter. When I did the doors in my truck it made a huge difference.
Semper Paratus
BTM757 is online now
Old 07-28-2014, 10:39 AM   #6
green_plaid
Fan#: 171817
Points 362, Level 7
Well less than a month later a few rattles/buzzes came back so I revised how everything was installed again... added GTMAT under the speaker brackets and I think everything is good now. I have up to 3 layers in some spots now. New pics added to first post. Once I get a sub I can cut bass to the door speakers which should help even more. So if your looking for decent mid-range speakers that have more bass than the oe ones... these would be a good fit!
Old 08-08-2014, 02:25 AM   #7
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,737, Level 73
Points: 12,737, Level: 73 Points: 12,737, Level: 73 Points: 12,737, Level: 73
Level Up 72% Completed
Forum Activity 99%
Moved to the Car Audio section.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
