Tried out the CG-Lock - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Racing Discussions > Autocross Racing
Autocross Racing The place to discuss information about autocross stats, tips and events. Track sanctioned events only.
Old 04-20-2005, 07:22 PM   #1
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Post Tried out the CG-Lock
Just got one of these for AutoCrossing, and put it to the test on Sunday at our first event of the season.
Here's the website. http://www.cg-lock.com/index.html
I just ordered directly from them online, though you can find them at other suppliers if you search.
But, with their free shipping offer this month, it was more economical to get it from them anyway.
Worked very well if I do say so myself.
The added restraint and resultant control of the car is very noticable.
I'm not ready to slap in a full race harness at the moment, so this was a great alternative.
Install took about 3 minutes.
I've been driving with it back and forth to work, but I finally took it back off last night.
It was just a bit awkward to use for everday driving, even with the lock-clip removed.
Mainly, the extra weight won't let the belt retract quickly enough when you take it off.
I kept whacking the door and window with it.
No problem, as I mentioned, it installs quickly.
Any questions, just ask.
IMHO, well worth it.
WD40 is offline
Old 04-21-2005, 08:44 AM   #2
fucos
Fan#: 20442
FF Reputation: 1 fucos Good Standing Member
But it doesn't lock the shoulder belt.
With the svt stock belt, you can lock the shoulder belt and lap belt. Just give it a quick tug right above your shoulder, then rotate your seat forward. Helps if you rotated it backwards to start.
I did this for awhile with great success then I bought the schroth rally 3.
fucos is offline
Old 04-21-2005, 11:40 AM   #3
MISVTfocus
MISVTfocus's Avatar
Fan#: 13841
What I Drive: 08 Fusion SEL, Focus ST on order
FF Reputation: 1 MISVTfocus Good Standing Member
Whoa I thought we had the double fold seat belts...hmm might be a good investment for the track its kind of expensive though...
Oh yeah!
MISVTfocus is offline
Old 04-21-2005, 03:55 PM   #4
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Tried that. Doesn't work on mine. Only makes it looser.
As soon as I rolled the car forward, the seatbelt would loosen right back up.
What I was doing, that worked semi-effectively, (though not very safe),
is to buckle the belt, then while holding both lap and shoulder portions tight at the buckle,
un-buckle it, give it a full twist, and buckle it back up again.
If you hit something with the belt twisted like that though...ouch.
WD40 is offline
Old 04-22-2005, 03:28 PM   #5
WD40
The Librarian
WD40's Avatar
Fan#: 5157
bump....
Well I'll be danged, fucos...
I had tried what you explained before, but it didn't work.
Well, tried again last night on the way home, and voila, mega hold from the seatbelt.
I was probably not pulling hard enough, or didn't have the seat back far enough to start with.
Man, that works great!
I will probably still keep the CG-Lock though, and make sure I've locked the shoulder portion as well.
Cool. Thanks!
WD40 is offline
Old 04-22-2005, 03:52 PM   #6
W~Phoenix~{RC}
FF Bouncer
W~Phoenix~{RC}'s Avatar
Fan#: 11450
What I Drive: 2003 Silver Frost Sport Edition ATX
FF Reputation: 1 W~Phoenix~{RC} Good Standing Member
Buy-Sell-Trade Rating: (29)
^^^ I'll have to give that a try at my next Autocross event. At my first event, I just tried to pull the seatbelt as tight as I could make it. I didn't think about tugging on it to make it lock in place then moving my seat forward. We'll see how much it makes a difference for me on the track
Cheers!
W~Phoenix~{RC} is offline
Old 04-22-2005, 06:20 PM   #7
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Just to clarify...
The seat bottom stays in place.
You tilt the seat back way down-rearwards,
give the belt a HARD tug, keep holding the belt in tension,
then crank the seat back up to your desired driving position.
It took me a few tries to get it exactly where I wanted once tightened.
As mentioned, I do still like that CG-Lock, but this is sure a less expensive alternative.
WD40 is offline
Old 04-24-2005, 02:00 PM   #8
fucos
Fan#: 20442
Hey, I never said it was easy. The quicker the tug the better. Also, if you find yourself riding shotgun, pull the seatbelt all the way out and then let it retract.
fucos is offline
Old 04-25-2005, 12:01 AM   #9
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 238,851, Level 100
Points: 238,851, Level: 100 Points: 238,851, Level: 100 Points: 238,851, Level: 100
Level Up 0% Completed
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
I played with one of those out at SEMA and thought it was a neat idea...it worked pretty well..
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 11-18-2005, 10:59 AM   #10
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Back from the dead...
Well, the CG-LOCK only lasted me 5 events, and then the little "thumb" lever popped off,
and little parts went flying all over the place.
I found them all, and tried fixing it myself, but it's hosed.
I'll add, out of the 4-6 people that have used them in our Region, 1/2 have had the same problem I did.
I give it a 10 for holding power....and a 1 for engineering.
And, a 1 for customer service.
I've had it sitting on the dining room table for months because it's far too much hassle to send it back.
Too much paperwork, and they never even sent me a receipt...
which is required for a replacement or refund.
I think I'll just chalk it up to a $40 "lesson learned".
WD40 is offline
