Car Wont Start :( - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-12-2005, 01:07 AM   #1
2001zx3kid07
Fan#: 21743
What I Drive: 2001 infra red zx3
FF Reputation: 1 2001zx3kid07 Good Standing Member
Unhappy Car Wont Start :(
ok one day my car wouldnt start. out of no where. so i tapped the ignition cable in the engine bay with a wire so i could bypass it to a push start button. i need this fixed. anyone know whats wrong? when i turn the key, it doesnt do anything. just a tiny click i hear. checked fuse in engine bay. looks good. someone please help. i cant keep using a push start button :(
i tried searching but i found nothing :(
2001zx3kid07 is offline
Old 04-12-2005, 01:28 AM   #2
2001zx3kid07
Fan#: 21743
i have an 2001 zx3. also with only 50k miles. its not the motor. my wipers, radio/cd, subs, every thing works. motor wont turn on. unless i use the f------ing push button.
Old 04-12-2005, 01:35 AM   #3
viney266
viney266's Avatar
Fan#: 93
What I Drive: focus ztw ,zx3,mustang, motorcycles
Points 235,775, Level 100
Points: 235,775, Level: 100 Points: 235,775, Level: 100 Points: 235,775, Level: 100
Level Up 0% Completed
FF Reputation: 112 viney266 Excellent Standing Member viney266 Excellent Standing Member
Buy-Sell-Trade Rating: (4)
Push button ??? I'm confused..
Sounds like either a weak battery or a bad starter solenoid... What do you mean by "push button??
Speed is only a matter of money; how fast do you want to go?
viney266 is offline
Old 04-12-2005, 02:23 AM   #4
Foci_Fosho
Foci_Fosho's Avatar
Fan#: 5736
What I Drive: 2003 White zx3 2.3L
FF Reputation: 16 Foci_Fosho Great Standing Member
Buy-Sell-Trade Rating: (6)
I believe he has the engine start button, But turning the key over gets a click sound, prolly from an overworked replay, or ignition switch.
the starter doesn't sound like the problem if the button is able to make the car function.
Foci_Fosho is offline
Old 04-12-2005, 02:28 AM   #5
2001zx3kid07
Fan#: 21743
i wired the button up to the battery, then put another wire from the button running into the ignition wire. hence when i push the button the ignition is bypassed to the push button to start the key by me turning the key to where i would to start the car leaving it there, then holding the button till my car starts
Old 04-12-2005, 10:15 AM   #6
viney266
viney266's Avatar
Fan#: 93
Sounds like you have a bad ignition tumbler ( the one on my ranger failed ), there are small contacts inside of the ignition switch that can get damaged ... Better to let a shop replace them unless you have previous experience.. Yeah, the starter is obviously good and so is the battery from your description.
viney266 is offline
Old 04-12-2005, 08:00 PM   #7
steedazts
steedazts's Avatar
Fan#: 5244
What I Drive: 2001 Black ZTS
FF Reputation: 1 steedazts Good Standing Member
i dont know haow its called, but under the steering wheel theres a small key (like a chip) if you take that out your car wont start, try to see if its in its place. Or in the fuse box under the hood chek all the big fuses the green ones and the orange (i believe its 30 an 40) if one is burned it wont start. Hope that helps!
steedazts is offline
Old 04-13-2005, 02:43 AM   #8
2001zx3kid07
Fan#: 21743
how do i get to the steering wheel key?
Old 04-13-2005, 07:36 AM   #9
steedazts
steedazts's Avatar
Fan#: 5244
This is what im talking about, if this chip is removed your car wont start at all.
clik on image[IMG][/IMG]
Old 04-13-2005, 10:05 PM   #10
suep6
Fan#: 21839
What I Drive: 2001 white focus
FF Reputation: 1 suep6 Good Standing Member
focus not starting
Our car has had problems [off and on] with starting.
we had the ignition replace in the fall - then the starter - now it is back to not starting again. the mechanic is stumped.
Our original key had a chip in it - the new one does not - he says the chip is located in the bottom of the iginition...is cheaper to do.
I will take the picture to him and what the replies have said - does anyone else have more info?
Thanks, suep6
suep6 is offline
