Why no fire? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-23-2014, 12:27 PM   #1
KodyK
Fan#: 171905
What I Drive: 2002 silver se
FF Reputation: 1 KodyK Good Standing Member
Why no fire?
Ok first post here, on xterra forums for my truck but now the lady's ride is stumping me...
2002 focus with the 2.0, 100,115 miles, bought 10,000 miles ago, I got the car at an auction and I'm pretty sure the previous owner beat it up a bit (E-brake didn't work, all out of alignment, sway bar was broken!!!??), gas gauge doesn't work so she ran outta gas (she uses the odometer but somehow "forgot") put 3 gallons in it and it still wouldn't start. The fuel pump turns on and the relay is working fine... I got to the point of putting a little bit of gas/sea foam down the throttle body to see if it would fire and it wouldn't... Not getting different compressions/free spinning like a broken t-belt... Fuel filter clogged maybe?? Oh and I am getting spark??? Thanks for any help!!!!
KodyK is offline
Old 06-23-2014, 01:06 PM   #2
crazy_urn
Capt. Urn
crazy_urn's Avatar
Fan#: 1986
What I Drive: 77 F-250, 10 HHR, 08 Outlook
FF Reputation: 5 crazy_urn Good Standing Member
I know there was a recall or TSB on a lot of focus fuel filters. That may be an issue (Though I don't know if it is the issue).
The three requirements for ignition are fuel, spark, and air. most likely problem on these cars is the coil pack, or the wiring thereof, but if you are certain you are getting spark, that is probably not the issue. (I was confused with the question marks as to whether or not you are getting spark, didn't know if that was a statement or a question).
Best thing to do is start at the beginning, and be as clear as possible. what happens when you turn the key, how did you check for spark/compression/fuel pump/relay/etc... the more info you provide, the more helpful we can be.
Thanks, and good luck.
Defending the reputation of the red-headed step-child of the focus world for far too long.
crazy_urn is offline
Old 06-23-2014, 06:17 PM   #3
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,038, Level 74
Points: 13,038, Level: 74 Points: 13,038, Level: 74 Points: 13,038, Level: 74
Level Up 47% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "General Technical Chat".
zetecDon is online now
Old 06-23-2014, 06:31 PM   #4
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,865, Level 74
Points: 12,865, Level: 74 Points: 12,865, Level: 74 Points: 12,865, Level: 74
Level Up 4% Completed
Forum Activity 99%
Might have answered it in the question.
If it SOUNDS like it's just spinning over - no compression - check the belt/cam turning first. IIRC you can see if there's any movement by pulling the fill cap & having someone crank it.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 06-24-2014, 05:01 PM   #5
amc49
Fan#: 96610
Points 3,279, Level 35
Points: 3,279, Level: 35 Points: 3,279, Level: 35 Points: 3,279, Level: 35
Level Up 53% Completed
Forum Activity 13%
Run out of gas and fuel pump commonly dies from dry cranking, they fuel cool and lube, plastic impeller melts when dry. Why they emphasize in owner manual to never run out of gas...........
Fix the driver first, then fixing the car becomes so much easier.
amc49 is offline
Old 06-24-2014, 05:36 PM   #6
ramayer
ramayer's Avatar
Fan#: 113266
What I Drive: whatever is running when I gotta go
Points 147, Level 2
Points: 147, Level: 2 Points: 147, Level: 2 Points: 147, Level: 2
Level Up 94% Completed
Forum Activity 2%
FF Reputation: 1 ramayer Good Standing Member
let it sit for 2-3 days and try again...if it starts, again then find out whats wrong and let me know...wifes 2001 has been doing that every month or so.....
if I happen to figure hers out then I'll let you know if it is the same issue.
ramayer is offline
