sporadic's Turbo Duratec build #3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-21-2014, 10:27 PM   #1
sporadic
sporadic's Avatar
Fan#: 12724
What I Drive: 06 Sonic Blue ZX5 SES turbo
Points 12,869, Level 74
Points: 12,869, Level: 74 Points: 12,869, Level: 74 Points: 12,869, Level: 74
Level Up 5% Completed
Forum Activity 4%
FF Reputation: 61 sporadic Excellent Standing Member
Buy-Sell-Trade Rating: (12)
Talking sporadic's Turbo Duratec build #3
History:
Build #1 (2007): Stock motor with custom Thunderbird IHI turbo
Build #1b: Upgraded IHI turbo to a hybrid
Build #2 (2012): Upgraded turbo to GT2871r. Switched to external wastegate.
Current build:
Same GT2871r
SuperTech 10.4:1 pistons
SuperTech rings
CXRacing forged H-beam rods
ARP head and main studs
Clevite main and rod bearings
Crower valve springs and retainers
Exedy Hyper Single clutch
Torsen LSD
Goal: 375whp+ and/or 115mph in the 1/4
The motor I'm building is the original out of my car. It suffered an overboost with the IHI turbo and damaged/broke a ring landing and began smoking like crazy. This happened a few years ago, but I'm just now getting around to rebuilding the motor. This is my first ground-up rebuild. With the exception of some very minor scratches (can't even feel it with a fingernail) the motor was fine and fully rebuild-able.
Since this motor had no significant damage and very low mileage I'm lucky enough to not need anything professionally machined. That being said I'm still measuring everything and comparing against the Haynes manual.
The cylinders were a bit shiny and I wanted to get that small scratch out of cylinder #2 so I used a 3-blade 220 grit hone to give it a new cross-hatch. I did as little honing as possible and stayed with the 87.5mm pistons.
Following SuperTech's formulas I gapped the top ring to .018" and the second ring I left at .023" as it came out of the box.
For now I'm sticking with the stock head and cams, but I did upgrade the springs and retainers to Crowers in case I want to spin it over 7K. Also if I want to swap out cams later the springs and retainers (the hard part) will already be done. I went with steel retainers vs. titanium after speaking with a representative at Crower. The steel are also significantly cheaper.
I'll be using a TurboSmart dual-stage boost controller, with a toggle switch for the second stage. First stage will probably be around 13-15psi, and second 20-24psi.
My base tune is from Tom, and I tweak it as necessary using the SCT Pro Racer Package. I plan on slowly tuning up to 24psi myself if possible. Chances are good I'll have to hit a dyno rather than street tune like I have up to now.
I'm in no particular rush with this build, so I may not be updating daily like I used to. There's a good chance I'll post a few days and then be silent for a couple months. Family time and home improvement projects tend to come before the car.
So far I've assembled the short block and just finished rebuilding the head with new valve stems seals, cleaned up the old valves, and installed the Crower springs and retainers. At this point I need to think real hard whether or not I want aftermarket cams, but I'm still leaning towards no.
2006 sonic blue zx5 GT2871r turbo.
sporadic is online now
Old 06-21-2014, 11:40 PM   #2
qweesy
qweesy's Avatar
Fan#: 12042
What I Drive: 2004 focus Duratec 2.3 RS (DEAD)
Points 3,193, Level 34
Points: 3,193, Level: 34 Points: 3,193, Level: 34 Points: 3,193, Level: 34
Level Up 96% Completed
Forum Activity 14%
FF Reputation: 4 qweesy Good Standing Member
Buy-Sell-Trade Rating: (6)
very nice
qweesy is offline
Old 06-22-2014, 01:51 AM   #3
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
I'm using the 2871r kn built block. Fast early spool to redline. No lag
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 06-24-2014, 09:28 AM   #4
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 4%
No updates, but adding photos of the clutch. I have decided to stick with the stock cams after reading negative reviews on the Crower cams, which is what I was looking at.
Old 06-29-2014, 04:11 PM   #5
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 4%
The motor is all together. Timing the cams and crank ended up being incredibly simple with some good photos. There is a youtube video out there with false information on setting the crank TDC, so I'm adding a photo below of where the crank is supposed to stop against the pin. There is no way to get the cam timing incorrect lining up the slots in the back. Find TDC, back it of some to pull the #1 piston down away from the valves, time the cams, set crank back to TDC, install chain, and done timing.
Timing tool used. The shorter "bolt" is used to set TDC.
Part numbers for crankshaft friction washers and crank bolt
Cams zeroed
Crank at TDC. (There is a youtube video that shows a different TDC point, but this is the correct location!
Timing chain on. Remember to install a new friction washer between the sprocket and crank, and another between the sprocket and crank pulley.
How I locked in the crank in order to torque the crank bolt.
Assembled and ports taped off
It will be a couple months before I get the new motor into the car. After remodeling the bathroom I'll get back to this.
Old 06-29-2014, 05:01 PM   #6
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,857, Level 74
Points: 12,857, Level: 74 Points: 12,857, Level: 74 Points: 12,857, Level: 74
Level Up 2% Completed
Forum Activity 99%
Great Pics! Those are the kind we can use for reference - Tx.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 06-30-2014, 11:09 AM   #7
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 4%
Some other goodies the car is getting along with the new motor:
15x8 Weld wheels with full slicks
More Prothane suspension bushings
Coilovers
Steeda rear sway bar
Possibly partial new exhaust
Aluminum steering rack bushings
Extended wheel studs for front wheels
Old 07-02-2014, 07:47 PM   #8
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 4%
Here is the part # for the ARP extended lug nuts that fit the Focus. 100-7708 12mm x 1.5
They say late model GM, but they certainly do fit. With a vise it only takes a few minutes to pop out the old ones and press these in.
Old 07-02-2014, 08:19 PM   #9
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,930, Level 100
Points: 51,930, Level: 100 Points: 51,930, Level: 100 Points: 51,930, Level: 100
Forum Activity 34%
Activity: 34% Activity: 34% Activity: 34%
Buy-Sell-Trade Rating: (28)
If you havent bought the wheels yet I have a nice set of bogarts front and read with good slicks and skinny rears I will sell
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 07-02-2014, 10:20 PM   #10
sporadic
sporadic's Avatar
Fan#: 12724
Forum Activity 4%
Thanks Tom, but I have a set of Welds with some slicks already. I could use the skinnies but probably won't bother to be honest.
