B&M Short throw shifter - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 06-10-2014, 11:30 PM   #1
NBA MotorSports
NBA MotorSports's Avatar
Fan#: 167146
What I Drive: 02 ZX3, 94 Ranger, 97 YZF750R
Points 792, Level 14
Points: 792, Level: 14 Points: 792, Level: 14 Points: 792, Level: 14
Level Up 92% Completed
Level up: 92% Level up: 92% Level up: 92%
Forum Activity 4%
FF Reputation: 2 NBA MotorSports Good Standing Member
Thumbs up B&M Short throw shifter
Has anyone installed a B&M Short throw shifter?
I just installed mine about two weeks ago. Pretty easy installation, took me about 30 mins. Like the short throw, and tight gate. The shift rod is about 4" shorter and the boot fits sloppy, so speed shifting with the arm rest down is tough. The pivot ball is slightly bigger, makes for stiff shifting. Having problems down shifting into 2 and kinda hard to get into reverse. Comes with a billet aluminum shift knob can use stock knob. Overall, worth the purchase. I paid $77 off of ebay.
Didn't get pics on install, but going to tear back down to trim reverse blocks. Will take pics then. If you have any input or pointers, or questions, please feel free to post.
GOT BOOST & JUICE?..
HAHA...I DO!
NBA MotorSports is offline
Old 06-16-2014, 10:48 PM   #2
NBA MotorSports
Fan#: 167146
Forum Activity 4%
Tore down the shifter, it was really stiff, hard to get into gears.
HAHA...I DO!
Old 06-16-2014, 10:53 PM   #3
NBA MotorSports
Fan#: 167146
Forum Activity 4%
Shifter gate has 4 27torx.
Shifter tensioner has a funky gator/spring clip
HAHA...I DO!
Old 06-16-2014, 11:06 PM   #4
NBA MotorSports
Fan#: 167146
Forum Activity 4%
Lightbulb
disconnect the ball connectors and pull the shifter out. On the bottom is the short throw B&M shifter and on the top is the stock shifter. You can see there's about a three inch difference, and the angle on the bottom ball connector is at an extreme angle.
HAHA...I DO!
Old 06-16-2014, 11:15 PM   #5
NBA MotorSports
Fan#: 167146
Forum Activity 4%
Pull the rubber boot off the pivot ball grommets, the bottom falls right off. You have to pry the top one off. Load grommets with white grease and snap the top back on then the bottom. Put rubber boot back on.
HAHA...I DO!
Old 06-16-2014, 11:21 PM   #6
NBA MotorSports
Fan#: 167146
Forum Activity 4%
CAUTION!
Put a rag around grommets before snapping back on and do not do inside of car! It makes a mess!
HAHA...I DO!
Old 06-16-2014, 11:30 PM   #7
NBA MotorSports
Fan#: 167146
Forum Activity 4%
Grease balls, link up and reinstall, install clip.
DO NOT PRY SHIFTER CABLE BACK ON!!!
IT BENDS!!
HAHA...I DO!
Old 06-16-2014, 11:37 PM   #8
NBA MotorSports
Fan#: 167146
Forum Activity 4%
Pull shifter assembly, 4 10 mm nuts and unscrew shifter cables.
i straightened the shifter cable with a ballpeen hammer. use channel to clip shifter cable onto shifter. reinstall shifter assembly, done.
New shifter nob.
don't be lazy ass like me, pull the center console and do it that way. The whole job took me an hour but if I woulda pulled the center console it would have taken me about 20 minutes.
HAHA...I DO!
Old 06-16-2014, 11:48 PM   #9
NBA MotorSports
Fan#: 167146
Forum Activity 4%
I hope this helps someone else. And you don't pull the same dumb crappie that I did!
tools needed:
Philips driver
27 torx driver
short pry bar
channel locks
10 mm socket 3" extention and driver
white grease
rags
Time;
depends on your experience...
20-90 minutes
HAHA...I DO!
Old 06-16-2014, 11:55 PM   #10
sailor
Crankshaft
sailor's Avatar
Fan#: 57268
Points 11,936, Level 71
Points: 11,936, Level: 71 Points: 11,936, Level: 71 Points: 11,936, Level: 71
Level Up 72% Completed
Forum Activity 99%
Worthwhile writeup.
Def. may help anyone else working on the shifter.
"Rubber Side Down"
S.R. #275
sailor is offline
