focus zx3 vs. svt - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-04-2005, 07:35 PM   #1
02focusfan
02focusfan's Avatar
Fan#: 16110
What I Drive: 2002 ford focus zx3 green
FF Reputation: 1 02focusfan Good Standing Member
Buy-Sell-Trade Rating: (9)
focus zx3 vs. svt
hi my name is jonathan and i want to know what are the differences between the zx3 and the svt zx3 engine wise?
02focusfan is offline
Old 04-04-2005, 07:39 PM   #2
fokuzx3
teh tranny killer
fokuzx3's Avatar
Fan#: 15685
What I Drive: r.i.p. liquid grey zx3....now 300zx
FF Reputation: 1 fokuzx3 Good Standing Member
6speed tranny on the svt...
the svt is pretty much just a suped up zetec engine with all the goodies..i mean yea its got different compression n exhaust n stuff like that but its still a 2.0..it might run a second faster than you but you can get more outa the zetec. ooh did i just say that heh ( only cuz more is out for the zetec) different final gear ratio as well...OH and theres variable intake cam timing.
zetec crew #23
zetec R.I.P. best standing 1/4 time= 15.260 @88.08 mph (2.275 60‘)
Originally Posted by warneej View Post
it takes a minute to get used to, kinda like shaving your balls.. haha
fokuzx3 is offline
Old 04-04-2005, 07:41 PM   #3
dgualtie
dgualtie's Avatar
Fan#: 15238
What I Drive: 03 IR SVT
FF Reputation: 1 dgualtie Good Standing Member
there are a bunth of threads talking about this and i am sure if you search you will find a bunch of information about how the zx3 and the svt vary. but a few of the differances are higher compression, variable intake, and different internals
SVT squad #7
dgualtie is offline
Old 04-04-2005, 08:01 PM   #4
SVT4ME
Fan#: 61
FF Reputation: 4 SVT4ME Good Standing Member
You might wanna try Googling to find one of the bazillion reviews that magazines/websites wrote about the SVT Focus, where they usually would describe in detail exactly what you're asking...
SVT4ME is offline
Old 04-04-2005, 08:08 PM   #5
blackandgold
blackandgold's Avatar
Fan#: 495
What I Drive: 2008 VW GTI 2006 Ford Explorer LTD
FF Reputation: 1 blackandgold Good Standing Member
This could get nasty. Hopefully it doesn't. If you are hoping to get your ZX3 to be like an SVT...stop trying. Go one step further and cutstomize your ZX3 to be a tuner car. Some parts from the SVT are excellent to use though (especially the suspension). All this can be found out by searching though.
ae86
Originally posted by focusfreak03
^ what the hell is that supposed to mean, you quote me and then put down some american eagle sh**
blackandgold is offline
Old 04-04-2005, 08:52 PM   #6
WD40
The Librarian
WD40's Avatar
Fan#: 5157
Moving to “SVT Owners Lounge”....
A quick search netted these threads:
SVT or ZX3
SVTF Vs. Non SVTF
SVT exclusivity
SVT or ZX3
svt versus zx3
As far as the SVTF engine:
1) Stronger (high nodular content) crank.
2) Forged steel connecting rods with 20mm wrist pins.
3) 10.2 compression ratio.
4) Variable cam timing on the intake cam.
5) Dual stage intake manifold. (long runners for low rpm, and short runners for high rpm)
6) Larger intake ports and valves.
7) Stiffer valve springs.
Oh, and.....
WD40 is offline
Old 04-04-2005, 09:00 PM   #7
SVT4ME
Fan#: 61
Alright jeez I'll just do the legwork myself like WD40 did...
From here: http://www.sportcompactcarweb.com/ro...2scc_svtfocus/
Engine
According to SVT, its Focus 2.0 Zetec engine is the most technologically advanced engine it has ever produced. Working with Cosworth, accomplished wizards of small-displacement, high-horsepower engines from years of rally, F1 and general racing experience, SVT has given the 2.0-liter a fat, useable powerband.
SVT uses VCT, or variable cam timing, on the intake cam and a dual-stage intake manifold to greatly increase torque at low rpm. Below 6000 rpm, the intake charge is directed through the longest runner length possible. Above 6000 rpm, the lower half of the runners pivot, giving the charge an almost direct shot into the intake ports. The ZX3 exhaust manifold features a close-coupled cat, which is effective in attaining low emissions figures, but chokes performance. SVT placed both converters under the car, allowing for a tuned 4-2-1 stainless-steel header.
Under stress, ZX3 connecting rods are known to shatter like plastic champagne glasses, which is why they were replaced with forged steel units. Lightweight, cast-aluminum pistons bump compression from 9.6:1 to 10.2:1. SVT used a completely new casting with noticeably larger intake ports. Intake valves are 1.5mm larger than those in a standard Zetec. Intake and exhaust springs were made stiffer by 27 and 19 percent respectively, allowing the SVT valvetrain to safely spin to 7200 rpm rather than the standard 6750. All of the engineers' efforts are worth an increase of 40 hp and 10 lb-ft of torque.
Exclusive to the SVT Focus is a dual-mass flywheel, which is divided into two sections, one bolted to the crank and the second to the pressure plate. A dual mass flywheel might do wonders for NVH and in controlling driveline lash, but its heavier weight makes throttle response a bit muted. Drag racers will also have a beef with this mechanism because it denies quick shifting. It makes for very smooth engagement when operated normally, but row it hard and clutch engagement is jerky.
SVT4ME is offline
Old 04-05-2005, 11:17 AM   #8
Gwizzy
Gwizzy's Avatar
Fan#: 758
What I Drive: 2009 White Pontiac G8 GT
Points 5,730, Level 48
Points: 5,730, Level: 48 Points: 5,730, Level: 48 Points: 5,730, Level: 48
Level Up 90% Completed
FF Reputation: 9 Gwizzy Good Standing Member
SVT FO' LIFE!
2009 Pontiac G8 GT - V8 POWER BABY!
*SOLD*
2003 Pitch Black SVT Focus
#61 of 3985 built
(1 of only 63 blue/black 3 door)
Gwizzy is offline
Old 04-05-2005, 09:03 PM   #9
popecruz
popecruz's Avatar
Fan#: 17124
What I Drive: 2002 Pitch Black SVT
FF Reputation: 1 popecruz Good Standing Member
You get a certificate.. and "respect... to some people thats more important"
*Response to WD40*
Originally posted by munkyv22
All your hard work and training for AutoX and you get sliding off the road and jacking your suspension named after you. That sucks.
popecruz is offline
Old 04-06-2005, 02:59 PM   #10
Fordson
Fan#: 13118
What I Drive: 2003 InfraRed SVT 5-door, loaded -
FF Reputation: 1 Fordson Good Standing Member
SVTF engine also has oil jets that spray onto the bottoms of the pistons to cool them. And it's not strictly speaking the engine, but it has a larger diameter exhaust, too. Fuel pump I know is different, with higher capacity.
And the entire ECU setup is different.
Fordson is offline
