spi ticking noise - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-27-2014, 02:05 PM   #1
fastflyer
Fan#: 85385
What I Drive: 2000 focus 2.0 spi
Points 153, Level 3
Points: 153, Level: 3 Points: 153, Level: 3 Points: 153, Level: 3
Level Up 6% Completed
FF Reputation: 1 fastflyer Good Standing Member
spi ticking noise
I have a 2000 focus, spi, 75000 original miles. Its developed a ticking noise that seems to be coming from the timing belt/motor mount area. Did a compression test fearing the valve drop issue and the compressions all are the same, appx 140 all the way across. The car runs well with no issues. The noise is engine rpm related, faster or slower depending on engine speed. I removed the drive belt thinking I may have a pulley or tensioner issue and the noise remains. Anybody have any ideas? Any help would be appreciated..
fastflyer is offline
Old 05-27-2014, 02:20 PM   #2
wv rider
wv rider's Avatar
Fan#: 125497
What I Drive: 2010 grey s
Points 1,369, Level 20
Points: 1,369, Level: 20 Points: 1,369, Level: 20 Points: 1,369, Level: 20
Level Up 69% Completed
Forum Activity 8%
FF Reputation: 1 wv rider Good Standing Member
flat/semi-collapsed lifter perhaps?
The Focus formerly known as Gandalfthegreyfocus
wv rider is offline
Old 05-28-2014, 04:01 PM   #3
crazy_urn
Capt. Urn
crazy_urn's Avatar
Fan#: 1986
What I Drive: 77 F-250, 10 HHR, 08 Outlook
FF Reputation: 5 crazy_urn Good Standing Member
The SPI has a pretty common ticking/knocking noise. A search will of the SPI forum will bring up a ton of info. IIRC correctly, because of the design of the engine, some do tick. Mine didn't before I sold it, but many do.
But do your own research. See if your tick is the same as the one described in the other threads, it could be a problem, but I would guess it is the standard SPI noise.
Defending the reputation of the red-headed step-child of the focus world for far too long.
crazy_urn is offline
Old 05-29-2014, 05:43 PM   #4
fastflyer
Fan#: 85385
Points 153, Level 3
Thanks for the replies. My engine has never been quiet but this particular ticking noise just started thats why it concerns me. I think Ill pull the timing cover off and take a look in there. As far as I know the timing belt has never been changed so it may be a good time to do that.
Old 06-06-2014, 07:52 AM   #5
amc49
Fan#: 96610
Points 3,390, Level 36
Points: 3,390, Level: 36 Points: 3,390, Level: 36 Points: 3,390, Level: 36
Level Up 27% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
You can run the valves hot and look for a loose one, simple matter to shorten the rocker stand a bit to tighten up to shut up or the lifter is dead. I used to shut up noisy lifters all the time at the shop doing that. Modern engines have no provision for taking up wear there any more. They'd rather you take the car in to dealer for service.
amc49 is online now
Old 06-10-2014, 03:06 AM   #6
Mandroid
Mandroid's Avatar
Fan#: 150610
What I Drive: 2003 light tundra metalic SE 5spd
Points 1,108, Level 18
Points: 1,108, Level: 18 Points: 1,108, Level: 18 Points: 1,108, Level: 18
Level Up 8% Completed
FF Reputation: 1 Mandroid Good Standing Member
The spi is a finicky little engine. Keep us posted on your finds. I have 72k on mine and no problems yet. Mine is pretty quiet but then again the 2003 model year had some changes.
Mandroid is offline
Old 10-20-2014, 07:03 AM   #7
fastflyer
Fan#: 85385
Points 153, Level 3
Ok guys. Heres what I found out about the ticking noise in my 2000 spi. I tore into it and removed the timing belt and tensioner. The tensioner was completely worn out. Very loose with lots of internal play. Replaced the timing belt and tensioner and the engine is nice and quiet again. Nice easy fix. So if you guys start to get a noisy engine, especially on the belt side thats a good place to start looking. I used a Gates belt and tensioner, good quality stuff so it should last a long time.
Old 10-20-2014, 11:11 AM   #8
FreeFocus
∫P ة∫
FreeFocus's Avatar
Fan#: 112674
What I Drive: 2002 SPI Focus
Points 21,634, Level 92
Points: 21,634, Level: 92 Points: 21,634, Level: 92 Points: 21,634, Level: 92
Level Up 29% Completed
Level up: 29% Level up: 29% Level up: 29%
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
FF Reputation: 3 FreeFocus Good Standing Member
Thanks for posting what was wrong. I have an SPI as well. Will remember to check that if I hear it.
MY FOCUS HAS A HEMI IN IT
Focus TakeOver#001 Co-Founder
Sedan Revolution #289
FOCUS XTREME
FreeFocus is online now
