EGR delete question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Closed Thread
Old 05-22-2014, 12:25 AM   #1
komoto123
komoto123's Avatar
Fan#: 119636
What I Drive: 2004 Ford Focus lx (Sangria Red)
Points 582, Level 11
Points: 582, Level: 11 Points: 582, Level: 11 Points: 582, Level: 11
Level Up 64% Completed
FF Reputation: 1 komoto123 Good Standing Member
EGR delete question
Anyone know if i NEED to get a tune if i do a manual egr delete? Or can i run with out the tune?
komoto123 is offline
    Quick reply to this message
Old 05-22-2014, 12:26 AM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,142, Level 100
Points: 138,142, Level: 100 Points: 138,142, Level: 100 Points: 138,142, Level: 100
Level Up 0% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Buy-Sell-Trade Rating: (11)
Yes you would need a tune or the check engine light will always be on.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 06-26-2014, 01:55 AM   #3
komoto123
komoto123's Avatar
Fan#: 119636
What if i kept rpm just above idle by adjusting the throttle body accelerator cable, so that the computer never would get the signal from the tps that its at idle? Will the check engine light come on still?
Old 06-26-2014, 11:18 AM   #4
crazy_urn
Capt. Urn
crazy_urn's Avatar
Fan#: 1986
What I Drive: 77 F-250, 10 HHR, 08 Outlook
FF Reputation: 5 crazy_urn Good Standing Member
I doubt it would prevent the check engine light. But my question is why bother? It is a mod that has practically no benefit.
From another thread:
if working correctly EGR is transparent. They often do not work correctly. The are superfluous in a performance arrangement, extra weight and complexity. If it is working correctly, nothing but loss of mid range fuel mileage will occur by removing it. (then you have to convince the DPFE not to code, if you remove w/o a flashing it out of the computer).
http://www.focusfanatics.com/forum/showthread.php?t=242676
Defending the reputation of the red-headed step-child of the focus world for far too long.
crazy_urn is offline
Old 06-26-2014, 01:16 PM   #5
komoto123
komoto123's Avatar
Fan#: 119636
The main reasons for removing it will be to clean up the engine bay a little, and i also don't like the concept of putting my dirty exhaust back into my intake. I know it is very little but i don't like it regardless. As for the mileage quote from the other thread. I am guessing it will only make a +/- 2 mpg on the city estimate, which i am not worried about at all.
Old 06-27-2014, 05:48 AM   #6
amc49
Fan#: 96610
Points 3,258, Level 35
Points: 3,258, Level: 35 Points: 3,258, Level: 35 Points: 3,258, Level: 35
Level Up 39% Completed
Forum Activity 3%
Idle speed has nothing whatsoever to do with EGR coming on or off. PCM knows when to put it on and several things feed into that. You CANNOT make it not operate without a CEL, tune only.
And, wanting to 'adjust' the throttle cable shows you have a way to go yet...............you never touch that. How you get into idle hanging issues, like 5 million other guys.
Fix the driver first, then fixing the car becomes so much easier.
amc49 is offline
Old 06-28-2014, 12:01 AM   #7
komoto123
komoto123's Avatar
Fan#: 119636
How do you think the PCM knows when to turn it on?? Rpm is one of those things. I have adjusted my throttle cable on my ranger plenty of times with no hiccup. Perhaps you could have just left out that last part and your reply would have been somewhat helpful.
Old 06-28-2014, 12:07 AM   #8
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 54%
We've seen many folks do that and the computer will bring the idle back to where it's programmed too after a few drive cycles. Then some folks start having issues since they adjusted it. You could make it idle at 2k rpms but it will try to idle down to where it's supposed to be and then it will idle like crap because of that.
Moderator for
Technical Chat
Old 06-28-2014, 12:12 AM   #9
komoto123
komoto123's Avatar
Fan#: 119636
I don't see how the computer would adjust itself back down. It would be like i am giving it gas all the time. Does the computer require a readout of a idle rpm?
Old 06-28-2014, 01:34 AM   #10
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,723, Level 73
Points: 12,723, Level: 73 Points: 12,723, Level: 73 Points: 12,723, Level: 73
Level Up 69% Completed
Forum Activity 99%
Here's a link that will take you to a listing including the info. on how the EGR is checked:http://www.focusfanatics.com/forum/showthread.php?t=214389
I'll third the comment that idle speed will eventually adjust to target, within the capabilities of the IAC to do so.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Closed Thread
