Ford Powershift/DCT Transmission Info & Use Guide (New Owners Look Here!)
438K views 731 replies 195 participants last post by  stuart s
#1 ·
I am writing this as a general knowledge and use guide regarding the Ford Powershift transmission, available in all North American (and other areas, of course) Focuses. For this guide I will only be focusing on what is available in North America as it is what I am familiar with. The purpose of this is to inform drivers of what they are buying, and to help with any driveability issues (jerkiness, etc.) related to the operation of this transmission. For this guide, I will not be considering the ST model at all, so any reference to the Focus is in reference to the other models (S - Titanium).
Jump straight to post #2 for my recommendations on driving with this transmission and reducing low speed jerkiness.
First I will explain why the Powershift is different then most other gearboxes. Here is a Wiki article on the powershift, for anyone looking for a bit more information on it: http://en.wikipedia.org/wiki/Ford_PowerShift_transmission
To start, the North American Focus is available with two gearboxes, a 5 speed manual and 6 speed "automatic" (the Powershift). The 5 speed manual is a typical manual gearbox. The 6 speed automatic, however, is not a typical automatic transmission. If you bought a Focus in North America, and it was equipped with an automatic transmission, it has the Powershift dual clutch transmission. The powershift is what is called a "dual clutch transmission". It's called this because...it use two clutches between it and the engine. For those unfamiliar with how transmission work, here is a very brief explanation of the differences between a manual and (normal) automatic, and how the Powershift is different then either:
- A manual transmission and automatic transmission are designed differently, and transmit power to the drive wheels in different ways. How each gearbox works is mostly irrelevant, but what is relevant is how each gearbox is connected to the engine. With a manual transmission, something called a clutch is used, which operates similar to a disc brake system. What this means is that when the clutch is pressed against the engine, the entire drivetrain (engine to drive wheels) is "locked up". Generally speaking no slipping of any parts happens during this, so any power generated by the engine is transmitted directly to the rest of the drivetrain.
- A "traditional" automatic uses something called a torque converter between the engine and transmission. This is a device filled with fluids, and simply put, several fans (turbines, really). The torque converter allows the engine to revolve without allowing that motion to be transferred to the transmission, and also allows for the engine speed and transmission input speed to be different, even while the vehicle is moving. What this means is that when you are are driving your vehicle, the transmission is not physically connected to the engine (the torque converter does "lock up" at higher speeds though, but that's irrelevant here). What this means is that any changes in engine speed are not directly applied to the transmission (and thus drive wheels), which allows for nice, smooth operation. Think of it like stirring a big pot of water with a spoon. When you first start stirring, the water doesn't really move much, but as you keep going it will start to spin with the spoon and speed up. That is what is happening here, so there is a buffer stopping any jolts from the engine being transmitted to the wheels.
That is important to know as it relates to how the vehicle operates at low speeds. Normal automatic transmissions are notoriously smooth at low speeds because of the torque converter. Manual transmissions often aren't because the clutch does not allow for such forgiveness, and smoothness is directly related to how good the driver is (and how they are able to slip the clutch to keep things smooth). How does this related to the Powershift transmission?:
The Ford Powershift transmission is, in design and general operation, a manual gearbox. It uses a clutch between the motor and transmission (two of them, actually...hence calling it a "dual clutch transmission"), and the transmission itself is designed internally much like a manual transmission. The differences are in that it has several computer controlled electronic servos (electric motors, basically) that do all the shifting and engaging/disengaging of the clutch. Why does this matter? It matters because it uses a clutch to connect it to the motor, which generally speaking means a bit more of a jerky ride, especially at low speeds (regardless of how good the computer is at operating it).
Why would Ford use such a transmission? Mostly because it offers improved gas mileage over traditional automatic transmissions. Because those transmissions use a torque converter, some of the energy produced by the engine is lost in the torque converter. Meanwhile, a transmission using a clutch transmits all of its power through the clutch so less power is lost overall. This means more power to the wheels, and better fuel economy.
#2 ·
Part 2: how to drive your Powershift equipped Focus to reduce low speed jerkiness, and general poor driving. I am listing here a number of guidelines to help folks in getting a better experience out of their Powershift transmission. I owned a Powershift equipped Focus for three years, and was quite good at making it behave. Do realize that due to the nature of it's design, it will never be as smooth as an automatic. Also be aware that some transmissions do have issues, and these guidelines will not fix that.
- At low speeds, be very deliberate with the throttle and avoid being on and off it too much. Smooth, deliberate throttle motions will equate to smooth driving at any speed. What happens with erratic throttle input is that the gearbox is trying to do too many things at once. It may have just upshifted into a higher gear, but now you are giving it more throttle so it wants to downshift again, then if you lift off the throttle while it's doing that it's now in the middle of a shift and has to put you back into a gear and release the clutch at the appropriate RPM so it doesn't buck and jerk. What ultimately happens is that the computer cannot keep up with erratic throttle inputs. Plan ahead only give it throttle when you know you won't have to come off it right away.
- Realize that at low speeds, the clutch will always be engaged (that is, connecting the engine and transmission) until very low RPMs, generally around 1000 or so it will disengage. This means that when you release the throttle after just having accelerated, you are still in gear and are engine braking. The vehicle will generally try and upshift as much as possible to smooth this out, so it's not felt as much by the driver. Try to avoid changing speed too much at very low speeds (under 5-10 mph) as the transmission will generally not be able to keep up quickly enough, and it may get caught between shifts.
- In heavy traffic, don't let the car "creep" forward by just letting your foot off the brake too much. It's OK in small doses, but can overheat the clutch if you do it too much. The clutch overheating can cause a warning to appear, and can cause the gearbox to not operate correctly until it has cooled. Additionally, in heavy traffic like this try and keep a bit more distance between you and the vehicle in front, so you can accelerate steadily, which can help with clutch temperatures and will also be a bit smoother for you.
- If equipped, try using SelectShift to shift at lower speeds. This will keep the transmission locked in the gear of your choosing. I used this very often at low speeds as it keeps the gearbox from shifting too much. Do note that, as stated above, this uses a clutch so when engine braking you will feel the engine slowing you down much more then you would with an automatic. If you keep it in too low of a gear it can still be quite jerky (again, very smooth throttle inputs will help). It's easy to notice this if you keep the gearbox in first, and accelerate to 5-10 mph. Let your foot off the throttle and notice how much the car slows, then give it more throttle again and it'll be pretty jerky. It's best to try and upshift into second pretty quick.
- At any speed, commit to your throttle inputs. Complaints of the transmission "banging into gear" are usually just the clutch being engaged when the RPMs aren't matched well. This will cause a sudden surge as the engine is suddenly changing RPM. This often happens because the accelerator is pressed enough to cause the transmission to downshift, then the throttle is lifted for whatever reason, then it is pressed in again, all before the transmission can shift into a gear. Try to avoid this.
**The biggest thing for any Powershift equipped Focus driver to realize is that this is NOT an automatic transmission, and cannot be driven like one. Once that is realized many folks have a easier time driving it. It may take some time to adapt to how it operates, but once you do you will generally have a better experience with it.
#3 ·
Just writing this for folks who are unaware of why their Powershift transmission is giving them a poor driving experience, and to help those who may not realize the differences between it and a typical automatic transmission. While such experiences seem to be reducing recently, it still seems some folks are coming here complaining of issues that can be fixed by driving the vehicle differently.
#13 ·
This is an excellent primer on driving this transmission. it occurred to me that the transmission's "self-training" cycle is also a foot-training exercise for the driver although what you describe as appropriate technique is pretty much what I've always done - peddle technique for driving manual shift cars.
#5 ·
I have noticed that when I am driving at slow speeds in stop and go traffic, if I just BARELY put my foot on the gas until the car starts to apply power, accelerating from rolling at about 5mph will be much smoother. If I'm coasting at 5mph and put my foot on the gas quickly, the car will get jerky.
I've just made it a rule to gently press on the gas until the car starts accelerating, then giving it all I want.
#15 ·
This is fantastic. I have been driving my 2013 for over a year and always felt the transmission was "crappy", but didn't really take the time to understand why it was behaving differently from a normal automatic. Now I realize that I was driving it completely wrong, gunning the throttle, pulling back, then gunning it again. No wonder the transmission was so jerky!
It's really cool, the car really feels unique now, and I think I will be able to get even better performance out of it now that I know how to drive! I am just going to take it for a drive around the neighborhood to practice what you showed me!
#16 ·
This is a really good description of how to drive in essence a computer operated manual transmission. You just have to be so much more mindful with the pedals because there isn't a torque converter to dampen the stresses. The BMW world I've been in went multiple rounds with its version, the SMG, and the debate and diatribes are so similar. Computer technology has taken over from the pure machinery aspect of cars and then add trying to make a profit by the brands and the dealers (and the tensions between them) and we have a classic perfect storm scenario.
My questions (to anyone who might know) is about the so called adaptive strategies the computer develops in the early miles of use. In the first 1000+ miles on my 2014 I have noticed the trans learning what to do in order to accomodate for speed, RPMs, load, and so forth. It's getting better and better at handling the various situations once its has seen them a few times. But if you confuse it in the learning phase, can you ever get that 100% undone and blank slate or are you forever patching over maladaption? Does it stop learning at some point (brain just gets full) or is it continuous (like average MPG calc)? Whats going on inside that black box??
#20 ·
You can disconnect the battery for 10-15 minutes to reset that.
I think I have the secondary roads figured out with respect to the DCT. Not 100% on highway acceleration though. As in how to get the DCT to downshift without punching the RPMs suddenly past 4k. Any tips?
I don't understand what you're getting at. It's supposed to go up in RPM when you downshift, are you just trying to get it to downshift, but not accelerate as quickly?
#17 ·
FWIW, Felix, you can have the shop restart the process if you don't like where it's gone.
I've got 29k miles on my 2013 and except for some uncertainty at very low speeds it does just what I would have done if i was shifting. I seem to be able to humor it with the accelerator - coax it to upshift when i want. I think it's really slick.
#19 ·
Excellent writeup here. Although I haven't personally experienced the typical DCT driving issues that your narrative addresses. I'd done a bunch of research on the DCT and how it really works before buying my 2012, so I knew what I was getting into beforehand. Since I bought the car, I've also relearned some nearly forgotten techniques I was taught when attempting to learn manual shift back in the early 1980s (the car I attempted to learn on was my brother's 1978 Chevy Monza that easily had the world's deepest clutch, which is a big part of the reason I never quite got comfortable enough with manual shift to buy a car with one for myself).
#21 ·
I guess I didn't explain very well. If I want to pass at highway speeds I push in the pedal and as I do nothing... nothing... sudden down shift of 2? 3? gears enough for the RPMs to jump from, say 2.5 to over 4k.
It just seems to me that I could get a better, smoother response. I learned something from this thread and it improved my enjoyment of the car. Just don't feel like I have this one aspect under control.
#22 ·
Well, it is what it is. I don't know how rough the transition is for you, but it's got to raise the RPMs to downshift, and this engine doesn't have a whole lot of power below 3500 rpms, especially for overtaking at highway speeds.
If you have the selectshift option for the transmission you can manually downshift to whatever gear you want.
#25 ·
How common in the shudder? Even with the lightest of toe curling accelerations at red lights and stops it's pretty much without fail it will shudder - starting to get annoying and almost seems like it's getting worse.
I'll have my dealership check it out but I'm afraid of the runaround I've read on other horror stories about trying to get issues fixed.
#26 ·
"To Joeywhat or whom it may concern"
Great article Joeywhat, My question to you is I use to own a 2010 Focus SES did it have the DCT tranny? If not, Ford shouldn't have "In my opinion" stop using that tranny because I got 28-34 mpg all the time for 38K miles. Why did Ford waste everybody's time and heart ache for 3 more mpg's.
#30 ·
... Why did Ford waste everybody's time and heart ache for 3 more mpg's.
A. Consumer demand. Some buyers will choose one car over another for even less than a 3 mpg difference.
B. Government regulation. Carmakers have to meet the Corporate Average Fuel Economy (CAFE) standards or pay big fines.
Otherwise I'm sure Ford would have loved to continue using older technology rather than spend so much effort and money developing something new. Another thing is that all the little fuel economy improvements add up. Maybe the DCT only gets 1 mpg better than the manual, but TiVCT, direct injection, and so on each do their part, too. The combined effect is significant.
#28 ·
Bit of an exaggeration to say "everybody's time". Understand how the gear box works, which includes acknowledging that it is neither an MT nor an AT, makes a difference. Ford dealers would do well to point that out to potential buyers. I prefer the DCT driving experience in my Focus over the AT experience in my wife's Escape. Personal preference.
#31 ·
Good writeup
I realized that the car changed my driving behavior as i subconsciously adapted to driving the car by 'massaging' the throttle. Being a former manual transmission driver, i could 'feel' when the car wanted to shift and could make it shift by easing off the throttle or push down further. Nowadays it's a rarity when it shifts into a gear i wasn't expecting.
The car was built to be fuel efficient and seems to drive best when you are trying to keep the green leafs all leafy. But you can still have a lot of fun with it when you open it up.
I have noticed one peculiar thing about the throttle. My car seems to behave a tad different depending on how lazy my foot is and where it's pressing on the gas peddle.
If i have the majority of the surface area of the pedal covered with my foot, the car drives 'smooth' for the most part. If i have most of my foot on the floor and just the tip of my toes pushing the bottom of the pedal, still exerting the same amount of force to move the car at the same speed, i will get the jutter/stutter more often.
I have no clue why this is. Believe me when i say i can massage the throttle just as well with my tippy toes as i can using my whole foot. It almost seems as tho the pedal is extremely sensitive to where the pressure of the input comes from.
The one area im still working on is tight corners. I find i have to brake hard into the turn so that i can start applying gas while going into the turn to keep the revs low while accelerating. If i don't brake quick enough, the act of turning (torque vectoring?) makes my revs flare up way into the 3-4k range just to maintain the exit velocity.
Basically i need to be on the gas before i go into the turn to keep the revs from shooting up.
As for my driving style, i call it 'torque' driving. I hate high revs unless i need to overtake someone, so my style is to try apply enough pressure on the throttle to speed up quickly without crossing 3k rpms , ease off the gas enough to trigger the next shift and immediately reapply pressure on the throttle to continue acceleration.. rinse repeat. It feels exactly like driving a manual without the clutch/stickshift play. Pressing down hard on the gas is like dropping from 5th to 2nd gear in a stickshift.
While i'm sure the shuddering i still feel on the odd occasion (especially after the car has warmed up) is related to one of the TSB's regarding the clutch, the OP is right. Simply learning how to drive the car by understanding it as a manual transmission that's computer controlled brings about a most pleasant driving experience. [twothumbs]
