SVT Focus Rear End Link Install question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-11-2014, 12:29 PM   #1
nelson914
Fan#: 53037
What I Drive: 2002 Black Svt Focus
FF Reputation: 1 nelson914 Good Standing Member
Just have a question about installing the sway bar rear end link,
do you install this with weight on wheels or do you do it with the car jacked up?
its rather hard to install it jacked up and get all the rubber bushings to fit on the bolt.
nelson914 is offline
Old 05-11-2014, 06:38 PM   #2
iminhell
C2H5OH
iminhell's Avatar
Fan#: 36222
Points 18,868, Level 87
Points: 18,868, Level: 87 Points: 18,868, Level: 87 Points: 18,868, Level: 87
Level Up 4% Completed
Forum Activity 13%
Buy-Sell-Trade Rating: (4)
With weight on the tires, on the ground.
If you can't fit under the car, drive both front and rear on ramps.
121,000 members and still no sponsored racing.
iminhell is offline
Old 05-11-2014, 11:41 PM   #3
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,338, Level 75
Points: 13,338, Level: 75 Points: 13,338, Level: 75 Points: 13,338, Level: 75
Level Up 22% Completed
Forum Activity 99%
Moved to "Brakes, Suspension & Chassis".
Backing onto ramps sounds good for easier access.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 05-12-2014, 12:37 PM   #4
nelson914
Fan#: 53037
Thank you for your reply
Old 05-12-2014, 09:11 PM   #5
ShadowFocus603
ShadowFocus603's Avatar
Fan#: 118448
What I Drive: 2004 Pitch Black SVT EAP 2Dr #1878
Points 575, Level 11
Points: 575, Level: 11 Points: 575, Level: 11 Points: 575, Level: 11
Level Up 50% Completed
FF Reputation: 1 ShadowFocus603 Good Standing Member
I did mine by jacking each side up and using jack stands to hold the car up. I did the links with no weight on them at all and haven't had an issue at all in over 2 months. I agree though that ramps would be the best bet. When you do them you will have to undo both sides, swing the bar down, install them in the arms then swing the bar back up over them both at the same time. I found that if I completely installed one side and tightened it down there wasn't enough space to get the other side in.
2004 Ford Focus SVT #1878
ShadowFocus603 is offline
