How to paint your old plastic Valve cover and give it a new look - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus First Generation > MK1 Interior Mods & Upgrades
Old 05-09-2014, 09:36 AM   #1
daspazzZX3
LoveRawx
daspazzZX3's Avatar
Fan#: 133961
What I Drive: chcl gry 02 ZX3 - 5sp
Points 6,183, Level 51
Points: 6,183, Level: 51 Points: 6,183, Level: 51 Points: 6,183, Level: 51
Level Up 17% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
FF Reputation: 2 daspazzZX3 Good Standing Member
Buy-Sell-Trade Rating: (18)
Hey all, daspazzZX3 here,
Whether your cover is stock black or painted by some else, if you just want to give your engine bay a new look here is what I did;
I got my '02 used and it had a red valve cover in it. I liked the color but it was getting a bit rough around the edges. While my car was apart in the shop for an engine rebuild I decides to repaint the plastic Zetec Cover. I am going with red as the secondary color in my overall scheme for DP. Most of my engine compartment items will be red and the engine should come back red. My suspension hardware is already half red and more red is coming.
Red is my favorite color, I didn't want a red car, because cops love red!
I was going with red again so I picked up the following products to make it sing! Here are some of the things you might need;
  • Paint Stripper
  • Steel wool
  • Adhesion promoter (BulllDog) Helps paint stick better to plastic
  • Possibly a adhesion promoting primer
  • You paint color (High heat paint may work better, but adhesion primer my reduce paint flaking)
  • An after coat, I used an anodizing cover paint, you may want to clear coat
  • Plastic brush for stripping paint
  • Masking tape to mask areas you dont want painted.
The old cover looked like this! Ewwww!
So first things first I needed to strip the paint. I was worried about damaging the cover since it is plastic. I was going to use aircraft paint stripper, but I was worried as to how caustic that might be. I asked around and the O'riely's guy suggested brake parts cleaner. I gave that a try. Turned out that it wasn't really enough to totally strip the old paint, although it did make for a good start. I ended up using a milder paint stripper and let it sit for about 15 minutes per the can instructions. Then I used a water hose and brush to clean away the excess goo.
When I was done the old cover looked to be in good shape. I then masked off the stem on the side, all the bolt holes (by stuffing rolled up paper towels into them, the center holes from the bottom so they would get good coverage into the holes and the filler hole.
After I let it dry I prepped it with the Adhesion promoter, waiting as per instructions about 5 to 10 minutes between coats.
First Coat
Second Coat
Third and final Coat
So now I tried to just spray it with the Anodizing paint and I found out that wouldn't work. It started turning the letters on the cover pink but wasn't covering the black at all. I then used a primer that also promoted plastic adhesion. I know it's double duty, but I'm trying to learn as I go, so maybe you can skip the first step when you try, OK? These coats were about 30 minutes apart. And this did a great job of covering the black!
First Coat
Second Coat
I let the primer dry for about an hour and a half. Now its on to Cherry Red the actual paint! I went with 3 or 4 coats and let them dry per can instructions between coats.
First Coat
Second Coat
I let it cure for about 36 hours and then peeled off the masking. I can't install it yet because the car is still in pieces at the shop, but I have topped it off with a billet anodized cap like this from sick speed.
And here it is with a few coats of the Anodizer sprayed on.
I'm really happy with the way it turned out! I look pretty bad ass! I do want to get some DOHC and maybe some Zetec stickers and put them on the cover just for grins! Once the car is done I will add more pictures of the finished product.
And now a special BONUS!!!
Just in case you were wondering how to get rid of stickers that were on a car you bought, you might want to try this! I will be using it when I get DP Back!
Aircraft Decal and Adhesive remover!
"You are a person, No one can forget you, even if it's Good or Bad, you make waves!" #truth #truthinadvertizing...
R.I.P. Pat :-( HN #68 - FTO #008 - principal defensor para el diablo
daspazzZX3 is online now
Old 06-05-2014, 04:23 PM   #2
Twilighter33
Fan#: 167018
What I Drive: 2001 silver zx3
Points 203, Level 4
Points: 203, Level: 4 Points: 203, Level: 4 Points: 203, Level: 4
Level Up 6% Completed
FF Reputation: 1 Twilighter33 Good Standing Member
Looks nice
Twilighter33 is offline
Old 06-05-2014, 04:52 PM   #3
volcomstone1966
RIP 02 SVT 0209
volcomstone1966's Avatar
Fan#: 35104
What I Drive: 04 PWSC EAP SVT - 04 Kawasaki ZX6R
Points 16,708, Level 82
Points: 16,708, Level: 82 Points: 16,708, Level: 82 Points: 16,708, Level: 82
Level Up 72% Completed
FF Reputation: 15 volcomstone1966 Great Standing Member
Buy-Sell-Trade Rating: (45)
idk how well that red paint is going to hold up on a valve cover i always used motor paints or high temp
04 SVT EAP #1131 -POWERWORKS-Torsen-Clutch Masters-Top Speed-Massive-Brembo-Fifteen52-Steeda-UNDER CONSTRUCTION
2K14 Turbo Veloster
04 Kawasaki ZX6R
volcomstone1966 is offline
Old 06-05-2014, 05:13 PM   #4
ferret15
ferret15's Avatar
Fan#: 83494
What I Drive: 03 zx3 and a screeming yellow eap
Points 605, Level 12
Points: 605, Level: 12 Points: 605, Level: 12 Points: 605, Level: 12
Level Up 10% Completed
FF Reputation: 2 ferret15 Good Standing Member
Cheap paint is fine, if anything the valve cover heat will help it cure if you install it asap when you can touch it.
The down side is plastic is near impossible to clean and it will probably need to be redone much sooner than a metal one with the same paint. Maybe you get lucky but I'd rather use a cheap paint and re do it once a year to keep looking fresh.
I've done only metal valve covers, but clear coat is a must if you want to keep it for a while. I did one white one time and constantly needs to be wiped down .
There is nothing wrong with a high temp paint, it will probably last longer if your looking for a permanent solution. I sprayed my svt in VHT wrinkle black so I shouldn't ever have to really worry about again, but its not exactly for that show look I'm going for either.
http://www.focusfanatics.com/forum/showthread.php?t=325968&page=3
ferret15 is offline
Old 06-05-2014, 08:51 PM   #5
daspazzZX3
LoveRawx
daspazzZX3's Avatar
Fan#: 133961
Forum Activity 100%
Thanks guys, I don't mind redoing it to keep it fresh. It was kinda fun to "get my hands dirty" for the first time in a while.
Old 06-10-2014, 08:16 PM   #6
ferret15
ferret15's Avatar
Fan#: 83494
looks good. any chance an engine bay shot?
ferret15 is offline
Old 06-11-2014, 02:29 PM   #7
daspazzZX3
LoveRawx
daspazzZX3's Avatar
Fan#: 133961
Forum Activity 100%
As soon as I get DP back I will be adding those!
Old 06-11-2014, 11:27 PM   #8
NBA MotorSports
NBA MotorSports's Avatar
Fan#: 167146
What I Drive: 02 ZX3, 94 Ranger, 97 YZF750R
Points 1,165, Level 18
Points: 1,165, Level: 18 Points: 1,165, Level: 18 Points: 1,165, Level: 18
Level Up 65% Completed
Forum Activity 5%
FF Reputation: 2 NBA MotorSports Good Standing Member
Looks good!
i dont know what you have invested, $100+?
Have you looked at this?
http://www.massivespeedsystem.com/_m.../i-407460.aspx
GOT BOOST & JUICE?..
HAHA...I DO!
NBA MotorSports is offline
Old 06-11-2014, 11:37 PM   #9
daspazzZX3
LoveRawx
daspazzZX3's Avatar
Fan#: 133961
Forum Activity 100%
30 bux and a few hours. Thanks. This was a learning expereince and an update. I've seen those, but I kinda think they are more ricey......
I just found out about hydographic painting and I'm going to get several parts including (inside pull handle inserts, coolant tank cover, metal valve cover, and a few other pieces covered in Red with Black Skullz once I get my car back.
Old 06-12-2014, 07:33 AM   #10
NBA MotorSports
Fan#: 167146
Forum Activity 5%
hydographic painting, I'm going to get my AR done in camo.
Wow... your one of those... jk
ricey - tuner, it's all the same to me. I'm just look at the aluminum cover and the ease of keeping it clean.
HAHA...I DO!
