2003 SVT Front struts OE or Aftermarket? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-08-2014, 01:55 PM   #1
HouBexar97
Fan#: 120379
What I Drive: 2003 Pitch Black SVT ZX5
FF Reputation: 1 HouBexar97 Good Standing Member
My 2003 SVT ZX3 is in need of strut replacement.
Which strut would you recommend as a replacement for best balance between performance and comfort?
What is the cost per side?
Should I DIY or take to shop? (I am handy with tools, not a expert)
Thanks for any reply!
HouBexar97 is offline
Old 05-08-2014, 02:05 PM   #2
Marde
Marde's Avatar
Fan#: 115991
What I Drive: 2004 ZTW PZEV 2.3 ATX
Points 1,817, Level 25
Points: 1,817, Level: 25 Points: 1,817, Level: 25 Points: 1,817, Level: 25
Level Up 17% Completed
Forum Activity 31%
Activity: 31% Activity: 31% Activity: 31%
FF Reputation: 11 Marde Great Standing Member
These are the ones I will buy in the near future->
http://www.amazon.com/gp/product/B00...=ATVPDKIKX0DER
Here is a video->
http://www.youtube.com/watch?v=_3T2ynDRZ0s
Doing the job with a "complete assembly" makes it easy... As opposed to using a spring compressor tool and replacing the strut and seat/bearing individually.
Edit: I do not know if that strut (linked above) is compatible with your SVT or not.
You've got to ask yourself one question: Do you feel lucky? -and could you really drive a Focus ATX Wagon?
Marde is online now
Old 05-08-2014, 02:54 PM   #3
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,432, Level 75
Points: 13,432, Level: 75 Points: 13,432, Level: 75 Points: 13,432, Level: 75
Level Up 46% Completed
Forum Activity 99%
Moved to "Brakes, Suspension & Chassis" for a better fit & more answers.
Best value is the SVT Strut/shock kit if you can find one, they've been closed out and are becoming harder to find.
Otherwise a "basic" performance shock like Koni Orange would be a good replacement.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 05-09-2014, 10:10 PM   #4
Svteurobw
Fan#: 137529
What I Drive: 2004 screaming yellow svt zx3
FF Reputation: 2 Svteurobw Good Standing Member
The svt is a specific shock n strut there different dampening then a reg focus also the stock spring rates are different then a reg focus and the svt is .5" lower then a reg focus. If your looking for just a replacement rather then upgrading then go with a ford racing kit u can get shocks springs for rear and loaded struts for the front for around 300 or they also sell just the struts and shocks but then u need a spring compressor.
Svteurobw is offline
Old 05-09-2014, 10:54 PM   #5
shlbygt
Fan#: 23315
What I Drive: 04 SVT PWSC EAP
Points 687, Level 13
Points: 687, Level: 13 Points: 687, Level: 13 Points: 687, Level: 13
Level Up 74% Completed
Forum Activity 2%
FF Reputation: 5 shlbygt Good Standing Member
I can find plenty of M-3000-ZX3A and M-3000-ZX3 kits from Ford Racing.
Tousley Ford has them listed at $297 and $247 respectively.
shlbygt is offline
Old 05-10-2014, 06:15 AM   #6
ferret15
ferret15's Avatar
Fan#: 83494
What I Drive: 03 zx3 and a screeming yellow eap
Points 605, Level 12
Points: 605, Level: 12 Points: 605, Level: 12 Points: 605, Level: 12
Level Up 10% Completed
FF Reputation: 2 ferret15 Good Standing Member
http://www.c-f-m.com/performancepart...m#.U233hFdyqUk
This is the best bang for your buck. With the SVT you have to remember you already have the .5" lowered springs compared to the regular zx3. So any Ford racing kit that is .5" is just your stock suspension and if your springs are in decent condition you don't have to spend the money on it.
If you want to go lower, there are 1.5" spring you can get from ford racing and Steeda most of the other brands start to list 1.75-2.5" which can be more than some want.
ferret15 is offline
Old 05-12-2014, 12:27 AM   #7
Marde
Marde's Avatar
Fan#: 115991
Forum Activity 31%
I posted here in post#2. I am sorry, my bad. My remarks at that time were generic comments and I was not thinking about the SVT Focus when I posted. I made a small edit a couple minutes after my post because I saw SVT. Oh well... now waiting for my next screw up... should not be long from now.
Marde is online now
Old 05-12-2014, 12:05 PM   #8
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
Points 1,374, Level 20
Points: 1,374, Level: 20 Points: 1,374, Level: 20 Points: 1,374, Level: 20
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
Like Marde suggested, a preassembled strut is perfect for a DIY'er. It almost makes a strut job as simple as shocks. So, if you've replaced shock absorbers before, then you're qualified for this job.
A caveat: virtually all of us have had trouble getting one of the struts out of the steering knuckle; for some folks it was the passenger side, for others it was the driver's side. You can try to make life easier for yourself by soaking the strut/knuckle junction & knuckle pinch bolt in your favorite penetrating oil (taking care of course to keep it off of the rotors), but that might not help much.
Also, it makes sense to replace the rear shocks at the same time, with the same brand. The mounting nut might be tack-welded, so keep that in mind if you're tugging on it and cursing the rust.
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
