Issue with NEW rear calipers - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-05-2014, 11:09 PM   #1
Jensen_75
Fan#: 140346
What I Drive: 03 Screaming Yellow SVTF
Points 266, Level 5
Points: 266, Level: 5 Points: 266, Level: 5 Points: 266, Level: 5
Level Up 32% Completed
FF Reputation: 1 Jensen_75 Good Standing Member
The short of it is I bought new rear calipers. Installed and went about bleeding them but I did so as if it was like the front calipers. I understand now that this is not how they can be bled. From what I have read you need to apply brake force and actuate the parking brake several times to get the piston to travel out. I have tried this at least 50 times to no avail. My brake pedal travels halfway to the floor before braking and I have reduced braking force. My ebrake takes twice as much to actuate as before changing the caliper. I searched the forum and the internet and found procedures to reset the piston to change pads but nothing for first time setup or bleeding procedure. I would like to know what I need to do as a first time setup to get the piston to extend and meet the rotor. I have purchased the tool to rotate the piston if needed but If I dont have to take off the wheels and take the caliper off again that would be awesome.
Thanks in advance.
2003 Screaming Yellow SVTF aka "The Screaming Banshee" - Part out
1990 Black Chevy Suburban aka "Frank The Tank"
1990 Red Mazda MX-5, 1.6,PS,PB,5spd,VLSD
Jensen_75 is offline
Old 05-06-2014, 10:34 AM   #2
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,906, Level 74
Points: 12,906, Level: 74 Points: 12,906, Level: 74 Points: 12,906, Level: 74
Level Up 14% Completed
Forum Activity 99%
Replace or open up the brake system & you'll need to bleed the system. Do the rr & lr & then the rf & then the lf. If after bleeding & pumping the pedal, still have issues, I'd try removing the caliper & check it out. It takes a bit to get the piston to compress the pad to the rotor. I've had that issue too w/ just replacing pads & compressing= screwing in the piston.
felixthecat is offline
Old 05-06-2014, 01:49 PM   #3
Jensen_75
Fan#: 140346
Points 266, Level 5
Thanks for the response. I did bleed the system as you described. I think my best bet is to get it started with the tool and make sure the ratcheting action works.
Old 05-06-2014, 03:04 PM   #4
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 12,994, Level 74
Points: 12,994, Level: 74 Points: 12,994, Level: 74 Points: 12,994, Level: 74
Level Up 36% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "Brakes, Suspension & Chassis".
zetecDon is offline
Old 05-06-2014, 07:55 PM   #5
rexazz2
rexazz2's Avatar
Fan#: 121761
What I Drive: 2014 HB SE
Points 1,925, Level 26
Points: 1,925, Level: 26 Points: 1,925, Level: 26 Points: 1,925, Level: 26
Level Up 25% Completed
Level up: 25% Level up: 25% Level up: 25%
Forum Activity 13%
FF Reputation: 1 rexazz2 Good Standing Member
last set I did on a GM , Regal ?? with parking brake integrated into the caliper
Make sure piston is engaged with lugs/ pins on back of the pad to keep the piston from turning
Set parking brake repeatedly , I think GM said 75 or 100X
Bleed brakes as normal
rexazz2 is offline
Old 05-06-2014, 08:24 PM   #6
Jensen_75
Fan#: 140346
Points 266, Level 5
Sounds like a workout. I went under the car and I think the culprit is the left rear caliper. The parking brake is almost all the way retracted compared to the other side which is halfway. I made sure when I assembled the pads that they went in correctly. The set I pulled out hand an angle to them and the little tab was sitting on the face of the piston instead of in one of the recesses. I wonder if that was the cause of my brake vibration.
Old 05-06-2014, 11:19 PM   #7
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,705, Level 73
Points: 12,705, Level: 73 Points: 12,705, Level: 73 Points: 12,705, Level: 73
Level Up 64% Completed
Forum Activity 99%
Ooh that would be an issue for sure, and an answer to the soft pedal.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 05-06-2014, 11:43 PM   #8
Jensen_75
Fan#: 140346
Points 266, Level 5
If you mean the parking brake comment I went under there with a bright light and I was mistaken. With the ebrake up the two sides relative to each other look a little different. However when I take the cable off and try to rotate the mechanism, it is very hard to get any rotation other than the play in the mechanism. Could be deceiving but I actually believe that it is functioning correctly.
I get my lug nut tool back tomorrow. I will check everything and bleed the system again if I can find someone to help.
Old 05-06-2014, 11:54 PM   #9
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
I was thinking about this part in particular. When they don't fit together square & tight you get flex that feels like a system that still has air in it.
IF you saw them flex while someone pushed the pedal with them installed that way it would be more obvious - hope fixing that is at least a step toward getting them right.
Luck
"Rubber Side Down"
sailor is offline
Old 05-07-2014, 10:22 AM   #10
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,727, Level 58
Points: 7,727, Level: 58 Points: 7,727, Level: 58 Points: 7,727, Level: 58
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
Forum Activity 24%
FF Reputation: 23 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
Try getting a friend to press the brake pedal while you look at each rear brake. See if you can tell how the calipers are working. Then again have them work the hand brake, the hand brake is independent of the pedal, might be able to trouble shoot which is causing issues.
The parking brake line tension can be adjusted at the handle if you take off the center console, there is an adjustment screw there. I know i had to adjust mine some when i added rear discs but since you were just replacing the existing rear calipers, that shouldnt be an issue.
From the initial post, sounds like the system wasnt bled all the way. Did the reservoir ever fully drain?
rambleon84 is offline
