Found a good deal on a set of 06&07 FRPP shocks and megan lowering springs... - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-06-2014, 02:15 PM   #11
281Screw
281Screw's Avatar
Fan#: 158970
What I Drive: 09 Focus SE Gold and 07 F150
Points 275, Level 5
Points: 275, Level: 5 Points: 275, Level: 5 Points: 275, Level: 5
Level Up 50% Completed
FF Reputation: 1 281Screw Good Standing Member
Originally Posted by sailor View Post
Don't know what they are, mismatched & bass ackwards for sure. He might be getting rid of them because they didn't work right that way.
Do some shopping, shock/strut kits are being closed out so you can get good prices if you find them.
Those would need disassembly, order a different top bush on a guess & try it - bit of a flyer. Double check if the top bushes were the same from '08-'12, can't remember for sure.
Worry what they really are for when you see an obvious mismatch.
I looked a little more into this kit and was looking at the FRPP springs and they look like the ones in the kit just a different color.
http://www.fordracingparts.com/parts...tKeyField=9600
SO if everything checks out okay these would just be bolt on correct?
281Screw is offline
Old 05-06-2014, 02:17 PM   #12
Miztaken1312
Miztaken1312's Avatar
Fan#: 74993
What I Drive: 2008 Black Coupe SES
Points 1,431, Level 21
Points: 1,431, Level: 21 Points: 1,431, Level: 21 Points: 1,431, Level: 21
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
Forum Activity 2%
FF Reputation: 2 Miztaken1312 Good Standing Member
But what he said about them being upside down, still stands. They won't bolt in/work properly until you've flipped the springs.
FSWerks Turbo Kit @ 8psi , Stealth Exhaust, & Lower Stress Bar | Projectors w/5000K HIDs, LED Tails with Lamin-X Tint
Steeda Short Throw & Upper Strut Bar| FRPP Suspension & CFM Lower Mount |
Miztaken1312 is offline
Old 05-06-2014, 02:25 PM   #13
281Screw
281Screw's Avatar
Fan#: 158970
Points 275, Level 5
Okay got it flip the spring then they should just bolt right in?
here is this thread i dug up and the springs are set up the same way as the one i am looking at purchasing.
http://www.focusfanatics.com/forum/showthread.php?t=288878
281Screw is offline
Old 05-06-2014, 02:42 PM   #14
Miztaken1312
Fan#: 74993
Forum Activity 2%
There are two different sets of FRPP springs.
Old 05-06-2014, 03:26 PM   #15
281Screw
281Screw's Avatar
Fan#: 158970
Points 275, Level 5
From what I got looking between the two pictures the one that I am looking at buying is setup the same way as the one posted above. Bigger opening of the spring on top with the smaller opening on the bottom but then idk.
281Screw is offline
Old 05-06-2014, 04:24 PM   #16
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,412, Level 75
Points: 13,412, Level: 75 Points: 13,412, Level: 75 Points: 13,412, Level: 75
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
Forum Activity 99%
Hate indistinct (blurry) pictures....
Post 13 on the left, looks like it matches the ones you're looking at buying.
That would make them OK as is (no flip needed).
Looking at the first set of pictures (struts in box) last night, the tight end of the coils didn't look like they fit into the holders properly at the bottom. Call it "better safe than sorry", flipping between the two sets of pictures gives a better reference than seeing the first set of pics by itself.
I've seen a few odd combinations, some that worked & ones that didn't - wouldn't want to tell you they're fine & be wrong.
Good work digging up the pics for reference, compare the two pics for yourself & go for it - decent price.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 05-06-2014, 04:31 PM   #17
281Screw
281Screw's Avatar
Fan#: 158970
Points 275, Level 5
Yeah I understand thanks for all your help I think I am gonna end up getting them just gonna see if I can get some better pictures of them.
One last question if the springs are okay the way they are then they would just bolt right in right?
281Screw is offline
Old 05-06-2014, 04:57 PM   #18
sailor
Elder
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Yeah - they'll bolt right in as is.
From an angle view you'd see the spring loop around in it's seat & the end comes up against a stop - similar to what you can see at the top. You can just see a tab sticking up for a stop in the second set of pictures. That's how they stay in place & don't rotate on the holders. (top of later version is different, bent to a flat end that just sits on the bushing)
Top bushing is the bearing that turns when the strut turns BTW, one unit on the small top later ones & a bush (bearing) between the top plate & the top mount on the earlier ones.
"Rubber Side Down"
sailor is offline
Old 05-07-2014, 10:51 PM   #19
281Screw
281Screw's Avatar
Fan#: 158970
Points 275, Level 5
I went at looked at them today the kit checked out good ended up picking them up for 240 and the guy threw in a flex pipe. the center nut is loose need to straighten the springs out and tighten those what are the torque specs for those?
just need to pick up a rear sway bar and the suspension will be done for "now"
281Screw is offline
Old 05-07-2014, 10:53 PM   #20
Miztaken1312
Fan#: 74993
Forum Activity 2%
The torque specs didn't work for me. I had to tighten them down all the way to stop spring noise (from the springs hopping around). Not sure what it said. But somewhere around 35ft-lbs seems familiar
