Found a good deal on a set of 06&07 FRPP shocks and megan lowering springs... - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-05-2014, 03:08 PM   #1
281Screw
281Screw's Avatar
Fan#: 158970
What I Drive: 09 Focus SE Gold and 07 F150
Points 275, Level 5
Points: 275, Level: 5 Points: 275, Level: 5 Points: 275, Level: 5
Level Up 50% Completed
FF Reputation: 1 281Screw Good Standing Member
Exclamation Found a good deal on a set of 06&07 FRPP shocks and megan lowering springs...
and I have and 09 focus Sedan was reading that they will work; with the 06-07 mounting hardware what all does that entail. The price is right and they look brand new. was wondering what all I would need and if it would be worth it thanks.
281Screw is offline
Old 05-05-2014, 05:19 PM   #2
sailor
Crankshaft
sailor's Avatar
Fan#: 57268
Points 11,816, Level 71
Points: 11,816, Level: 71 Points: 11,816, Level: 71 Points: 11,816, Level: 71
Level Up 42% Completed
Forum Activity 99%
Look up on FordParts.Com, strut mount/bushing/plate & you should just get new bump stops & cover tube as well. Then you can assemble the new ones complete without having to re-use anything.
"Rubber Side Down"
S.R. #275
sailor is offline
Old 05-05-2014, 06:25 PM   #3
281Screw
281Screw's Avatar
Fan#: 158970
Points 275, Level 5
Here is a picture of the kit. I think I have found everything you listed but I'm not sure on what plate you are talking about.
[IMG][/IMG]
281Screw is offline
Old 05-05-2014, 06:57 PM   #4
sailor
Crankshaft
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Someone already assembled the struts, and didn't take them apart to sell them.
All the pieces are there already, just need installation.
Second Glance - those springs don't look like they match the struts. Notice how the springs fit the holders on top (plate I mentioned) and don't fit the same on the bottom? I'd guess those springs might be for your year, turned upside down for use on the earlier assemblies. Later model springs had the small tops & went with a one piece top plate & bearing (called a bushing in the listings).
Mis-Matched pieces from different years - at a GUESS the top bushings for your year might fit those springs when they are turned right side up again. Confirming what year those springs were made for would be the only way to know. Heck, I can't tell from the picture if they'd even work that way.
Pig in a Poke - don't know what those are for sure.
"Rubber Side Down"
S.R. #275
sailor is offline
Old 05-05-2014, 09:41 PM   #5
281Screw
281Screw's Avatar
Fan#: 158970
Points 275, Level 5
The guy wants 250 for then you thinks it's worth it. He bought them then decided on coil overs. Called to get
P/N's but he didn't have the off hand.
281Screw is offline
Old 05-05-2014, 10:12 PM   #6
sailor
Crankshaft
sailor's Avatar
Fan#: 57268
Forum Activity 99%
Don't know what they are, mismatched & bass ackwards for sure. He might be getting rid of them because they didn't work right that way.
Do some shopping, shock/strut kits are being closed out so you can get good prices if you find them.
Those would need disassembly, order a different top bush on a guess & try it - bit of a flyer. Double check if the top bushes were the same from '08-'12, can't remember for sure.
Worry what they really are for when you see an obvious mismatch.
"Rubber Side Down"
S.R. #275
sailor is offline
Old 05-05-2014, 10:14 PM   #7
Miztaken1312
Miztaken1312's Avatar
Fan#: 74993
What I Drive: 2008 Black Coupe SES
Points 1,377, Level 20
Points: 1,377, Level: 20 Points: 1,377, Level: 20 Points: 1,377, Level: 20
Level Up 77% Completed
Forum Activity 5%
FF Reputation: 2 Miztaken1312 Good Standing Member
There's a guy in the FocalJet buy/sell/trade group selling an FRPP kit that's properly assembled for your model year. He also has an 09.
https://www.facebook.com/groups/4010...30154763674393
FSWerks Turbo Kit @ 8psi , Stealth Exhaust, & Lower Stress Bar | Projectors w/5000K HIDs, LED Tails with Lamin-X Tint
Steeda Short Throw & Upper Strut Bar| FRPP Suspension & CFM Lower Mount |
Miztaken1312 is offline
Old 05-05-2014, 10:55 PM   #8
281Screw
281Screw's Avatar
Fan#: 158970
Points 275, Level 5
Then there is also shipping was just looking for something local.
281Screw is offline
Old 05-05-2014, 10:56 PM   #9
Miztaken1312
Fan#: 74993
Forum Activity 5%
Not sure if you'd be switching the springs yourself or paying someone else to do it, but if it's the latter option, you're still spending the same amount roughly.
But that's just my .02 cents.
Old 05-05-2014, 11:14 PM   #10
281Screw
281Screw's Avatar
Fan#: 158970
Points 275, Level 5
I have all the the stuff to do the install either way. I messaged him to see what shipping would be.
281Screw is offline
