Duralast Drums with same p/n but are different - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-04-2014, 05:49 PM   #1
Marde
Marde's Avatar
Fan#: 115991
What I Drive: 2004 ZTW PZEV 2.3 ATX
Points 1,791, Level 24
Points: 1,791, Level: 24 Points: 1,791, Level: 24 Points: 1,791, Level: 24
Level Up 91% Completed
Forum Activity 26%
Activity: 26% Activity: 26% Activity: 26%
FF Reputation: 11 Marde Great Standing Member
This is about Auto Zone Duralast drum part number 80112.
Had a rear bearing fail about 6 months ago and replaced the drum and shoes on passenger side only. Finally got around to replacing the other side yesterday.
I pulled off both drums because I did not paint the one I installed 6 months ago and I wanted to put new drum retaining nuts on. When I pulled off the 6 month old drum, I found the bearing was bad. Auto Zone gave me a replacement for free... but I took the last one they had on the shelf.
Now I have 2 new drums. Same part number but each drum was slightly different and the box they came in was different too. Sorry, I painted the one on the left side before the picture.
Please note that the ABS tone ring is not installed on either drum.
My question for you guys is; what is the name of the ring that the screwdriver is touching? I will call it a "guide" for now. The old OEM drums had the guide. One of the new Duralast drums has the guide, the other new Duralast drum does not have the guide. Obviously these two are from different Chinese manufactures or batches and manufactured with different specs. Ref side-by-side drums in pic above, the one on the left side (1) I painted it before the picture (2) has no guide (3) does not have the ruff orange peel protection on the outside (3) the box opens up from the top (4) I hope is the older design that Auto Zone is fazing out. I prefer the other one, the one on the right side. The one on the left side is also the same exact type that was installed on my car for 6 months and I found the bearing damaged. It had tossed out lots of clear grease and had some axial play.
Here is what they looked like just before putting the dust caps on and finishing the job. First is the one I like, the one with the guide and with orange peel texture.
Here is the one I do not like.
After running a new non-painted drum for 6 months it looked like this. Never again.
You've got to ask yourself one question: Do you feel lucky? -and could you really drive a Focus ATX Wagon?
Marde is offline
Old 05-06-2014, 12:08 AM   #2
Buildist
Buildist's Avatar
Fan#: 150994
What I Drive: 2012 Blue Focus SE
FF Reputation: 1 Buildist Good Standing Member
I am not familiar with that specific drum and the ring in question so I am sorry that I cannot help you with that.
The aftermarket drum and rotor industry was allowed to die in the US because the Federal Trade Commission only imposed an 8% tarrif on drums and rotors that were being imported from China and sold below market value. At first there were many manufacturers, then at each review there were less, and the FTC would only keep the 8% tarrif in place and do nothing to actually level the playing field. At the last review the few remaining "manufacturers" were now petitioning for the removal of the tarrif as they had now sourced their parts from China as well, and manufacturing drums and rotors for the aftermarket in the US died.
That's why you can only buy crap now. The casting surface on the outside of the drum that you do like is absolutely attrocious. That would never pass in this country as something to be sold. The material that they use is inferior, and the machining is sometimes ok, sometimes not as ok as it needs to be.
Steve
Buildist is offline
Old 05-06-2014, 01:01 AM   #3
Sniper Focus
Sniper Focus's Avatar
Fan#: 84221
What I Drive: '03 SVT EAP "Eurotrish"
Points 2,122, Level 27
Points: 2,122, Level: 27 Points: 2,122, Level: 27 Points: 2,122, Level: 27
Level Up 82% Completed
Forum Activity 15%
Activity: 15% Activity: 15% Activity: 15%
FF Reputation: 22 Sniper Focus Great Standing Member
Buy-Sell-Trade Rating: (13)
I think the ring is officially called the "water seal carrier", it makes contact on the water seal on the spindle to keep foreign matter out of the bearing.
If you still have your old drum you can carefully pry it out and reuse it.
Sniper Focus is online now
Old 05-06-2014, 01:26 PM   #4
Marde
Marde's Avatar
Fan#: 115991
Forum Activity 26%
Steve
Thanks for the insight and feedback. The drum I like... seems like a newer and better version and is designed closer to the OEM drum; largely because it has the Guide. I am not going to call that thing a guide anymore since Sniper Focus gave it a name-> water seal carrier.
The casting surface on the outside of the drum seems like it is "absolutely atrocious" but I am guessing it was done on purpose. Other surface areas are not orange peel textured. The orange peel might be casted but might also be sprayed on after casting. Similar to spray-on truck bed liners... or maybe not, -I am just guessing.
Also, maybe-just-maybe the drum without the water seal carrier is more likely to fail... my first one did after only 6 months.
Thanks. Yeah I still have the old drums. I tried to pull the seal out (only lightly tho) and it wanted to stay where it was.
Sure wish I had matching drums on the car now. Guess I am a rolling test bed for Duralast drums. Also wish I had taken the new drums, pressed in new Timkens and had water seal carriers on both. Oh well, -Meh.
Marde is offline
Old 05-13-2014, 04:52 AM   #5
amc49
Fan#: 96610
Points 3,360, Level 36
Points: 3,360, Level: 36 Points: 3,360, Level: 36 Points: 3,360, Level: 36
Level Up 7% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
A dust and rock shield, some part makers include them, others don't. The true seal is in the bearing itself behind the circlip. The mismatched parts issue is common, just like the other guys you can get as many as 10 different discs in same box or different boxes and the different ones never seem to play out to have one or the other box disappear. I saw multiple boxes for years on end, the box suppliers also change every fifteen minutes based on price quotes that move up and down every day. The big parts chains have so many suppliers for each part it's not funny, the parts change with virtually every box you open. Getting 'matched' sets were often a problem, lots of people base their ideas of quality on being able to do it.
You can go long periods without that shield, I looked for them on Tempo driveshafts back in the day and could find none on the supplied driveshafts. They didn't even list a part in the seal catalogs for them. Ford only at like $20 a pop and you guessed it, I ditched the part, the car still running now and some 20 years later. I also don't have the shields on at least 2 focus rear brake drums. More like a slinger, if you go underwater they will pass it instantly so not doing much good there. Mainly to keep dirt particles from the bearing seal itself.
amc49 is online now
Old 08-16-2014, 11:57 PM   #6
FocusSpin
Fan#: 120419
What I Drive: 2002 Blue Ford Focus
Points 16, Level 1
Points: 16, Level: 1 Points: 16, Level: 1 Points: 16, Level: 1
Level Up 31% Completed
Level up: 31% Level up: 31% Level up: 31%
FF Reputation: 1 FocusSpin Good Standing Member
What kind of paint did you use Marde ? What should I ask for at the parts shop ?
It must be some better than average paint to withstand the temperature. It's a bit late for my drums ( all rusted now ) but I am willing to give them a good wire brushing and try it since I am about to change the rear bearings!
Thanks !
FocusSpin is offline
Old 08-17-2014, 02:30 AM   #7
Marde
Marde's Avatar
Fan#: 115991
Forum Activity 26%
Paint type is called "brake drum & caliper paint". Most car parts stores have it.
Marde is offline
Old 02-27-2015, 03:17 PM   #8
Marde
Marde's Avatar
Fan#: 115991
Forum Activity 26%
Originally Posted by Marde View Post
...Guess I am a rolling test bed for Duralast drums. Also wish I had taken the new drums, pressed in new Timkens and had water seal carriers on both. Oh well, -Meh.
After less than a year, the rear drivers side brakes are now squeaking during many of my stops. I know I hit all the shoe contact points with plenty of grease, so it bums me out that I gotta pull the drum(s) off again, ugh. I got a funny feeling the Autozone (Chinese) bearing is failing again! When I did this last time, I used a new axle nut and did the torque properly.
If the bearing looks/feels bad, I will not use ANOTHER Autozone drum (bearing). Instead of getting a free replacement at Autozone again, I might (finally listen to myself) have a shop press in a reputable brand of bearing.
Maybe I will just go buy the bearings in advance, and find a shop ready to press em in, before I pull the drums off. Good idea. Thanks Marde, I appreciate the idea & your help.
This post is just me whining, sorry guys. I will post back after I get it opened up and let you know what happened. <end unnecessary rant>
$32 for ONE good bearing, uhg. Just called Autozone, they sell the same part# for $42 and said they might price match it. Update you later.
http://www.amazon.com/Timken-516007-.../dp/B000BZ6W2E
Marde is offline
