question regarding rear drum/bearing replacemennt - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-02-2014, 10:33 PM   #1
Focuslu86
Fan#: 109201
What I Drive: 2001,yellow, zx3
FF Reputation: 1 Focuslu86 Good Standing Member
So I have noticed a wobbling noise coming from the left rear side, and I suspect to be a bad wheel bearing. When replacing one, do I have to replace the other one as well? Do the wheel bearings (both) needs to be replaced at the same time?
Focuslu86 is offline
Old 05-02-2014, 10:37 PM   #2
Buildist
Buildist's Avatar
Fan#: 150994
What I Drive: 2012 Blue Focus SE
FF Reputation: 1 Buildist Good Standing Member
Check the lug nuts first to see if they are loose. If it is a bad wheel bearing it is best to do both sides at the same time as they were both installed at the same time and if they are bad on one side then the other side will have the same amount of wear and not be far behind it.
Steve
Buildist is offline
Old 05-02-2014, 10:55 PM   #3
Focuslu86
Fan#: 109201
Steve
Thanks steve! Another thing too. Is it necessary to install a dust cap? I mean, does it protect the axle nut retainer, in some way?
Old 05-02-2014, 11:05 PM   #4
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,488, Level 100
Points: 138,488, Level: 100 Points: 138,488, Level: 100 Points: 138,488, Level: 100
Level Up 0% Completed
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Buy-Sell-Trade Rating: (11)
Also keeps dirt and water from getting to the bearing and causing premature wear, so yes use the dust cap. You may mess up the one on there trying to get it off, it happens, just go to the autoparts store and pick up a new one. They were only a few bucks the last time I checked.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 05-04-2014, 01:11 PM   #5
Focuslu86
Fan#: 109201
I have another question? Do I have to clean the new rear drum with brake cleaner? what about the spindle? and when connecting the rear drum, do I have to put any grease or something on the sides?
Old 05-04-2014, 03:19 PM   #6
Marde
Marde's Avatar
Fan#: 115991
What I Drive: 2004 ZTW PZEV 2.3 ATX
Points 1,690, Level 23
Points: 1,690, Level: 23 Points: 1,690, Level: 23 Points: 1,690, Level: 23
Level Up 90% Completed
Forum Activity 10%
FF Reputation: 11 Marde Great Standing Member
I do not know what the pros do, but here is what I did yesterday. Cleaned outside top of new drums with soap/de-greaser and water. Painted new drums with black caliper paint. Lightly sand-papered the inside of the drums. Used compressed air to clean out the dust around the brake shoes. Placed a very light coat of wheel/bearing grease on the spindle.
If you have ABS, make sure you snap-off the tone ring and press it on the new drum.
You've got to ask yourself one question: Do you feel lucky? -and could you really drive a Focus ATX Wagon?
Marde is offline
Old 05-04-2014, 05:00 PM   #7
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,807, Level 73
Points: 12,807, Level: 73 Points: 12,807, Level: 73 Points: 12,807, Level: 73
Forum Activity 99%
Sounds good, remember that NEW drums or rotors are coated with a preservative that needs to be removed with brake cleaner. You want them absolutely clean, no greasy fingerprints allowed. Clean rag and/or brake cleaner is all you want touching the friction surfaces, handle by the outside edges only.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
