Rear camber setting MK1 Focus - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-30-2014, 02:59 PM   #1
a car nut
Fan#: 53615
What I Drive: 04 focus zx3, premium, liquid grey
Points 476, Level 9
Points: 476, Level: 9 Points: 476, Level: 9 Points: 476, Level: 9
Level Up 52% Completed
FF Reputation: 1 a car nut Good Standing Member
I recently put in some rear shocks for a friend, then did an alignment (had also replaced all the tires) and I though looking back at the rear that the car had too much negative camber on one side. When I finished the alignment and took the final reading after setting the toe, the rear right had 2.6 negative camber. The left side had 1.2 negative camber; I will have to install the adjustable upper arm on the right to bring in the camber at least 1.0 degree less. My question is what is the best setting to set the negative camber to, while preserving both tire wear and handling. Would you recommend replacing both rear upper arms and setting the camber to something like .5 degree negative?
I dont like a different of more than .3 degree on camber from left to right side; caster seems to be ok both in front and rear. Any thoughts on this.... Thanks for your input.
a car nut is offline
Old 04-30-2014, 07:02 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,312, Level 75
Points: 13,312, Level: 75 Points: 13,312, Level: 75 Points: 13,312, Level: 75
Level Up 16% Completed
Level up: 16% Level up: 16% Level up: 16%
Forum Activity 99%
Doing the right to bring it closer to equal with the left should be good.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 05-01-2014, 01:34 PM   #3
qweesy
qweesy's Avatar
Fan#: 12042
What I Drive: 2004 focus Duratec 2.3 RS (DEAD)
Points 3,236, Level 35
Points: 3,236, Level: 35 Points: 3,236, Level: 35 Points: 3,236, Level: 35
Level Up 24% Completed
Forum Activity 7%
FF Reputation: 4 qweesy Good Standing Member
Buy-Sell-Trade Rating: (6)
negative -1 degree for rear
qweesy is offline
Old 05-01-2014, 06:52 PM   #4
thenorm
thenorm's Avatar
Fan#: 14947
What I Drive: '04 liquid grey ZX3, built for FSP
Points 5,617, Level 48
Points: 5,617, Level: 48 Points: 5,617, Level: 48 Points: 5,617, Level: 48
Level Up 34% Completed
Forum Activity 4%
FF Reputation: 36 thenorm Great Standing Member
to get the right to match the left, you can use the camber bolts (about $30) instead of the upper arms as they grant 1 degree of change.
May 2014 ROTM
for auto-x: '04 Liquid Grey ZX3
for street: '02 Infrared SVT
thenorm is offline
