Brake lines?? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-29-2014, 09:08 PM   #1
disturbinglee
Fan#: 136033
What I Drive: 2003, Blue, ZX3
Points 354, Level 7
Points: 354, Level: 7 Points: 354, Level: 7 Points: 354, Level: 7
Level Up 8% Completed
Forum Activity 2%
FF Reputation: 1 disturbinglee Good Standing Member
Brake lines??
hi everyone, I'm looking into getting new break lines and wasn't sure what to get. i was thinking steel brake lines but wasn't sure which ones to get for my 2003 Ford Focus zx3. also if anyone knows a link on how to change those if you could put that in that would be great. Thanks!
disturbinglee is offline
Old 04-29-2014, 11:14 PM   #2
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,401, Level 61
Points: 8,401, Level: 61 Points: 8,401, Level: 61 Points: 8,401, Level: 61
Level Up 84% Completed
Forum Activity 30%
If you have rear drums... http://www.c-f-m.com/performancepart...m#.U2BpDPldV8E
Not sure if there is a how to... its fairly simple. you will have to fully bleed the brakes afterwards. so get a full bottle of brake fluid. Also get some Russel speed bleeders they help with the bleeding.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 04-30-2014, 12:30 AM   #3
daspazzZX3
OneOfUs
daspazzZX3's Avatar
Fan#: 133961
What I Drive: chcl gry 02 ZX3 - 5sp
Points 5,510, Level 47
Points: 5,510, Level: 47 Points: 5,510, Level: 47 Points: 5,510, Level: 47
Level Up 80% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
FF Reputation: 2 daspazzZX3 Good Standing Member
Buy-Sell-Trade Rating: (18)
The key to replacing lines is to keep the bleeder screw submerged in brake fluid. Sounds odd but its actually easy. Put some fluid in a jar and run a plastic hose from the fitting into the jar. Thai will help draw air through the system and help bleed the brakes faster.
From Zetec how tos.......,
Its in there, I promise!!!!
"You are a person, No one can forget you, even if it's Good or Bad, you make waves!" #truth #truthinadvertizing...
R.I.P. Pat :-( HN #68 - Focus Takeover #008 - principal defensor para el diablo
daspazzZX3 is online now
Old 04-30-2014, 02:35 AM   #4
amc49
Fan#: 96610
Points 3,270, Level 35
Points: 3,270, Level: 35 Points: 3,270, Level: 35 Points: 3,270, Level: 35
Level Up 47% Completed
Forum Activity 9%
...............and the quickest way to suck air in there is. The air has less resistance than fluid and will suck backwards through the bleeder threads when pedal is released. Seen it done a hundred times.
If you and your bleeder friend are competent, no need, he should be waiting for you to announce 'pump the brakes' before he ever lets up one iota on the pedal, which should be bottomed on the floor. That turns your motion into a positive one way check valve without the valve being there.
You want positive pressure pushing any time that bleeder is cracked open, that way no air can bleed back into system.
amc49 is offline
Old 04-30-2014, 11:35 AM   #5
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 30%
That is why I recommend the speed bleeders. You do the jar and hose thing but the bleeders self close when the pressure drops off.
also to the OP... why new brake lines? are you looking for just a better brake feel? or are you wanting something else?
Have you ever done a brake job?
Hatch Nation #42
Old 05-01-2014, 11:18 PM   #6
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,018, Level 74
Points: 13,018, Level: 74 Points: 13,018, Level: 74 Points: 13,018, Level: 74
Level Up 43% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (45)
Moved to "Brakes, Suspension & Chassis".
zetecDon is online now
