help with rear drum/wheel bearing replacement - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-29-2014, 09:16 AM   #1
Focuslu86
Fan#: 109201
What I Drive: 2001,yellow, zx3
FF Reputation: 1 Focuslu86 Good Standing Member
So my ford focus 2001 zx3 2.0 DOHC started to have some wobbling noise coming from the rear left side, which seems to be a bad wheel bearing. Since replacing just the bearing its a pain in the ass, I was going to get the drum with the bearing already pressed. When replacing a rear drum, do I have to put a new Centric Spindle Nut/Disc or use the old one? what about the spindle stub shaft? I would really appreciate your help
Focuslu86 is offline
Old 04-29-2014, 11:38 AM   #2
Marde
Marde's Avatar
Fan#: 115991
What I Drive: 2004 ZTW PZEV 2.3 ATX
Points 1,787, Level 24
Points: 1,787, Level: 24 Points: 1,787, Level: 24 Points: 1,787, Level: 24
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
Forum Activity 24%
FF Reputation: 11 Marde Great Standing Member
Retaining nut can be re-used 3 or 4 times... New nuts are almost $20 each. Spindle does not need to be replaced unless corroded/damaged.
You've got to ask yourself one question: Do you feel lucky? -and could you really drive a Focus ATX Wagon?
Marde is online now
Old 04-30-2014, 10:02 AM   #3
Snelski
Snelski's Avatar
Fan#: 15816
What I Drive: 2001 Yellow Street Edition Wagon
Points 324, Level 6
Points: 324, Level: 6 Points: 324, Level: 6 Points: 324, Level: 6
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
FF Reputation: 1 Snelski Good Standing Member
Marde said it all - word.
Snelski is online now
Old 04-30-2014, 11:25 PM   #4
SkiToLive
Fan#: 117149
What I Drive: 2005 ZXW SE Red
Points 80, Level 1
Points: 80, Level: 1 Points: 80, Level: 1 Points: 80, Level: 1
Level Up 60% Completed
FF Reputation: 1 SkiToLive Good Standing Member
Replaced my rear drums, brakes and spindles last summer. My vehicle was upwards of 185 000 kms at that point. After years of potholes in the spring, rust and salt corrosion and general use, I decided to just bite the bullet and replaced everything.
I used the drums with the pre-pressed bearings which made the job faster and easier overall. HOWEVER, even though the spindles were fresh out of the box, one of them was slightly oversized. The leading edge of the spindle would not insert into the bearing. If you do decide to replace the spindles, make sure to dry fit them first into the new bearings.
Don't know your level of mechanical experience but hope this little tip helps.
SkiToLive is offline
Old 05-02-2014, 02:20 PM   #5
Marde
Marde's Avatar
Fan#: 115991
Forum Activity 24%
Last time I did the drums I used a torque wrench that maxed out at 150 ft lbs. Happy to report that Auto Zone had a bigger one in the "tool loan program". $100.00 deposit required. Now I can get an accurate 175 ft lb torque on my brand new retaining nuts.
Marde is online now
