07 SE Hatch, pulled the trigger on FRPP springs/shocks/struts - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Tech Discussions > Brakes, Suspension & Body Chassis
Old 04-28-2014, 04:50 PM   #1
ADKFOCUS
ADKFOCUS's Avatar
Fan#: 101858
What I Drive: 2007 Silver SE Hatch
FF Reputation: 1 ADKFOCUS Good Standing Member
So I recently bought an 07 SE Hatch. The ride height is simply painful...
So after a lot of research and realizing I wanted every day drivability, I went with these FRPP parts :
http://www.massivespeedsystem.com/fo...i-1893239.aspx
http://www.massivespeedsystem.com/fo...i-1893234.aspx
http://massivespeedsystem.com/_massi...i-1829779.aspx
So theoretically I should have everything coming to me ready to go.
However, I have never done this before. I may try to attempt it myself, I may have someone help me, but I wanted to know any tricks/tips/important info other than the basic procedure before I started. Any info is appreciated.
EDIT: Found this video on an 05...what's different on mine?
https://www.youtube.com/watch?v=_3T2ynDRZ0s
Thanks
Adirondack Car Club member/co-founder
MECP Advanced Certified Mobile Electronics Technician CEA#212703
518/ 'Daks for lyfe yo.
I have unpopular opinions and express them loudly.
ADKFOCUS is offline
Old 04-30-2014, 03:58 PM   #2
ADKFOCUS
ADKFOCUS's Avatar
Fan#: 101858
Bueller? Bueller?
ADKFOCUS is offline
Old 04-30-2014, 05:57 PM   #3
sailor
"Elder"
sailor's Avatar
Fan#: 57268
FF Reputation: 64 sailor Excellent Standing Member
Spray penetrant on the front strut bolts a couple times a week before the job at least, get it down the split in the knuckle on the bolt.
Pull shock to drop rear arms for spring removal/install. You can lever out the old springs with that droop. Center bolt spring compressor is easiest for install, can't get outside ones quite on opposite sides & space is limited. FRPP might go in easier, SVT's I did drop less. With shock removed you can lever arm even lower than it droops.
I avoided dropping arm to avoid dealing with bolt thru bushing that's likely seized.
When removing front struts, leaving the top nuts on loose lets you lever the knuckle down off the strut, only the one bottom bolt to remove. Chisel/screwdriver wedged in split helps free the old struts.
"Rubber Side Down"
S.R. #275
sailor is online now
Old 04-30-2014, 06:01 PM   #4
Corvairkid
Fan#: 154746
What I Drive: 2007 red zx3
FF Reputation: 1 Corvairkid Good Standing Member
Let us know how the install goes, I am hoping to do this setup on my car this summer.
Best of luck
Corvairkid is offline
Old 05-02-2014, 12:15 PM   #5
ADKFOCUS
ADKFOCUS's Avatar
Fan#: 101858
Is the video I posted accurate? I wouldn't think THAT much changed from 05 to 06-07.
ADKFOCUS is offline
Old 07-07-2014, 12:31 AM   #6
ADKFOCUS
ADKFOCUS's Avatar
Fan#: 101858
Going to attempt this with a friend Tuesday. Any last words of advice?
ADKFOCUS is offline
Old 07-07-2014, 05:36 AM   #7
Nmarzoli04
Nmarzoli04's Avatar
Fan#: 119995
What I Drive: Liquid Gray 2007 ZX4 ST
FF Reputation: 1 Nmarzoli04 Good Standing Member
Let me know how it goes, I will also be doing this over the summer.
2007 Liquid Gray ZX4 ST
S.R. #303
"Live free or die"
Nmarzoli04 is offline
Old 07-07-2014, 01:23 PM   #8
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
FF Reputation: 23 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (14)
Follow Sailor's advice. Rent an internal spring compressor from the part store for easier rear spring removal/installation and be very careful when compressing springs, never point towards yourself. If your new front strut is not preassembled with the springs, you will also need to rent a spring compressor for that, an external style one.
The install from 00-11 is all the same for suspension, so your guide should be fine. You can also use this as a reference as well, would be the same process: http://www.fordracingparts.com/downl...m-3000-zx3.pdf
I'd also suggest an alignment afterwards to ensure good handling and tire wear
rambleon84 is online now
Old 07-09-2014, 05:39 PM   #9
Sith Akeyn
Sith Akeyn's Avatar
Fan#: 152986
What I Drive: 2006 Liquid Gray ZX4 ST
FF Reputation: 1 Sith Akeyn Good Standing Member
Those part will be are the same that i was looking for =D
Sith Akeyn is offline
Old 07-24-2014, 10:28 PM   #10
BowerR64
BowerR64's Avatar
Fan#: 78699
What I Drive: 2007 ZX3 SE
FF Reputation: 12 BowerR64 Great Standing Member
A little off topic but in the links you posted your shocks and struts are blue?
Did yours come blue like this? Mine are black im just wondering if i got the wrong kit or of the images are for a different kit on the massive site?
I was thinking that ford came out with 2 kits for the 06-11 one is slightly more firm and one set is really agressive and the agressive kit is blue?
It's not important to win, it's important to make the other guy lose.
BowerR64 is offline
