Wobble - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-28-2014, 04:46 AM   #1
StevieBhoy11
Fan#: 147418
FF Reputation: 1 StevieBhoy11 Good Standing Member
Wobble
Hi everyone, when driving my Focus over 30mph and going straight car feels as if rear wheels are running on ice, told my near side rear wheel bearing was bust, fixed it then took it for a drive and same problem but slightly worse, any ideas..
using FF Mobile
StevieBhoy11 is offline
Old 04-28-2014, 06:08 AM   #2
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,786, Level 54
Points: 6,786, Level: 54 Points: 6,786, Level: 54 Points: 6,786, Level: 54
Level Up 18% Completed
Forum Activity 56%
Activity: 56% Activity: 56% Activity: 56%
Buy-Sell-Trade Rating: (23)
What year is the car and are you 100% sure that the bearing was torqued to 173 ft.lbs.?
Is it a feeling or noise? Which side was replaced?
I know that the 2000-2011's must be torqued at 173 ft.lbs. exactly or they go bad very quickly.
Also, the bearings should be timken or, SKF. The rest are crap IMO(outside of something from Ford directly).
Have you had the car aligned? How long have you owned the car? How many miles are on the car?
Hatch Nation #140
Caeci caecos ducentes
freemind is online now
Old 04-29-2014, 11:17 AM   #3
Leora83
Fan#: 69136
What I Drive: 2003 ZX5 chrome yellow
Points 520, Level 10
Points: 520, Level: 10 Points: 520, Level: 10 Points: 520, Level: 10
Level Up 40% Completed
Forum Activity 10%
FF Reputation: 1 Leora83 Good Standing Member
^^I second the choice of bearing. I put in cheapie white box rear bearings and ended up redoing them two months later with SKFs.
That said, unless the installation was really bad, it seems weird that the problem would be worse. And usually the noise gets you before the road feel does--they howl like banshees when they start to go and just get louder.
Bad rear shocks, maybe?
Leora83 is offline
Old 04-29-2014, 11:24 AM   #4
crazy_urn
Capt. Urn
crazy_urn's Avatar
Fan#: 1986
What I Drive: 77 F-250, 10 HHR, 08 Outlook
FF Reputation: 5 crazy_urn Good Standing Member
Not nearly enough information for anyone to actually help you. While good suggestions have been offered, all we can do is shoot in the dark.
what year, what model, milage, when did the problem start, etc. etc. etc. etc.
I know the old wagons were known for rear suspension problems, but don't have first hand experience with what the symptoms are....
my only advice. take it to a different mechanic. anyone who is willing to waste your money while they shotgun parts is a thief.
Defending the reputation of the red-headed step-child of the focus world for far too long.
crazy_urn is offline
Old 04-29-2014, 01:03 PM   #5
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 13,412, Level 75
Points: 13,412, Level: 75 Points: 13,412, Level: 75 Points: 13,412, Level: 75
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
Forum Activity 99%
IF bearings are OK, Feeling "loose" in the rear is often a suspension bushing issue.
I'll move this to the "Brakes, Suspension & Chassis" area where you can find more info. on the possibilities.
Cheers
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is online now
Old 05-01-2014, 03:31 AM   #6
amc49
Fan#: 96610
Points 3,375, Level 36
Points: 3,375, Level: 36 Points: 3,375, Level: 36 Points: 3,375, Level: 36
Level Up 17% Completed
Forum Activity 59%
Activity: 59% Activity: 59% Activity: 59%
Gotta say more like they say, wobble and being like on ice make no sense together at all. Two totally different things.
If noise increases to like a rrr, rrr, rrr, rrr noise at faster speed then jack up tire to spin free in the air and spin it as fast as you can by hand. Look at the tread surface and see how out of round it is, if you can see it visibly then tire out of round and needs new tire. Common on FWD vehicles when you don't rotate tires. Bearing can be good but wheel still acts like dead bearing. The noise is not constant, rather changes as the different high/low of tire comes around.
amc49 is online now
Old 05-03-2014, 09:46 PM   #7
Justin svt
Justin svt's Avatar
Fan#: 58325
What I Drive: 2002 CD Silver SVT
Points 2,615, Level 31
Points: 2,615, Level: 31 Points: 2,615, Level: 31 Points: 2,615, Level: 31
Level Up 10% Completed
FF Reputation: 2 Justin svt Good Standing Member
It's your little dog bone looking rear toe links (control arms)
2002 silver ZX3 SVT #2318: Tom's Tune, 8.2mm Taylor Thundervolt wires, Custom ORP, Full Prothane bushing swap
"I buy things I don't need, with money I don't have, to impress people I don't know"
Justin svt is offline
Old 05-11-2014, 06:00 PM   #8
yomanwill
Fan#: 61429
What I Drive: 2009 Black SES Coupe
FF Reputation: 1 yomanwill Good Standing Member
I third the bearing recc. Used "PG bearing" from Autovalue went bad under 10k (on the front end). Using SKF with no problems. Have had a rear shock go bad. Handing should be off / should see some leakage on the shock.
I have seen wobble with bad aliment (toe out of spec), but if the alignment is off substantially off that usually means there is a suspension component that is worn. If things are bad enough typically putting the car up on jack stands and grabbing and shaking suspension links points me in the right direction.
yomanwill is offline
