Wheel hop and banging noise - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus ST > Focus ST
Focus ST The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK3 2013-Current Focus ST.
Old 04-27-2014, 11:52 PM   #1
Burns098356GX
Burns098356GX's Avatar
Fan#: 94777
What I Drive: 2013 Focus ST
FF Reputation: 1 Burns098356GX Good Standing Member
I'm encountering a odd noise coming from the front end of my ST when I attempt to spin my wheels. It seems on wet pavement I can spin them no problem, but on dry surfaces the fronts seem to hop and results in a rather alarming banging noise like something is going to bust though the firewall. Any ideas what's going on? Im sure what happening isn't good for the motor, or axle.
Burns098356GX is offline
Old 04-27-2014, 11:59 PM   #2
suss6052
suss6052's Avatar
Fan#: 95752
FF Reputation: 23 suss6052 Great Standing Member
Originally Posted by suss6052 View Post
TSB 13-6-10
Looking at the messages, it is pretty involved. Looking at the parts list for the TSB, it is several mounts and such that will need replacement. See below
Printable View (2357 KB)
TSB
13-6-10 BANG NOISE HEARD AND/OR BUMP FELT FROM FRONT OF VEHICLE DURING A QUICK 1-2 AND/OR 2-3 SHIFT - UNDER MODERATE TO AGGRESSIVE ACCELERATION
Publication Date: June 10, 2013
FORD: 2013 Focus
ISSUE:
Some 2013 Focus ST vehicles may exhibit a bang noise and/or bump felt from front of vehicle during a quick 1-2 and/or 2-3 shift under moderate to aggressive acceleration.
ACTION:
Perform the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Raise the vehicle on a hoist. Refer to Workshop Manual (WSM), Section 100-02.
Remove the lower air deflector by removing the three (3) fasteners. (Figure 1)
Remove the engine compartment splash shield by removing the eight (8) fasteners. (Figure 1)
Lower the vehicle.
Remove battery and battery tray. Refer to WSM, Section 414-01.
Position hydraulic floor jack with a wood block under transmission and raise only enough to support weight of transmission.
Do not attempt to lift the transmission or damage will occur.
Figure 1 - Article 13-6-10
Remove battery tray reinforcement by removing the four (4) fasteners. (Figure 2)
Figure 2 - Article 13-6-10
Remove and discard the center fastener securing the transmission support insulator and remove the insulator.
Install revised service transmission support insulator and torque new center fastener to 148 N-m (109 lb-ft).
Replace the clutch slave cylinder hydraulic tube with revised service part. (Figure 3 - Item 12)
Bleed the clutch system. Refer to WSM, Section 308-02, general procedures, 6 speed manual transmissions.
Remove floor jack.
Install battery tray reinforcement with the four (4) fasteners and torque to 48 N-m (35 lb-ft). (Figure 2)
Install battery and battery tray, refer to WSM, Section 414-01.
Replace engine mount with revised service part. Refer to WSM, Section 303-01B
If the three (3) engine mount studs loosen during engine mount removal, torque the three (3) engine mount studs to 17.5 N-m (13 lb-ft)
Figure 3 - Article 13-6-10
Replace roll restrictor with revised service part. Refer to WSM, Section 308-03.
When installing the engine compartment splash shield and lower air deflector, do not over tighten the fasteners or threads may be damaged.
PART NUMBER PART NAME CM5Z-6068-A Roll Restrictor
DV6Z-7A512-B Clutch Line PTL
DV6Z-6038-B Engine Mount
DV6Z-6068-A Transmission Mount
W500361-S442 Bolt - Transmission Mount
W716238-S442 Bolt - Roll Restrictor
PM-20 Motorcraft® DOT 4 LV High Performance Motor Vehicle Brake Fluid
WARRANTY STATUS:
Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT: Warranty/ESP coverage limits/policies/prior approvals are not altered by a TSB. Warranty/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
OPERATION DESCRIPTION TIME
130610A 2013 Focus ST 2.0L GTDI: Replace Mounts And Clutch Hydraulic Cylinder Tube Following The Service Procedure (Do Not Use With Any Other Labor Operations) 1.8 Hrs
DEALER CODING
BASIC PART NO. CONDITION CODE
6068 42
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supercede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Copyright © 2013 Ford Motor Company
TSB 13-6-10 which has been superseded to include some 2014 models as well replaces the motor mounts with improved units and changes a clutch hydraulic tube in order to help reduce or eliminate the shift bang between 1-2 and 2-3
suss6052 is offline
Old 04-28-2014, 12:06 AM   #3
Burns098356GX
Fan#: 94777
I'm driving a 2013. How can I tell if my car is supposed to receive those recalls?
Old 04-28-2014, 12:14 AM   #4
suss6052
suss6052's Avatar
Fan#: 95752
It's not a recall, rather a technical service bulletin, but in reality every 2013 build Focus ST should qualify. Proving it to the dealer might be a different story.
suss6052 is offline
Old 04-28-2014, 12:17 AM   #5
Burns098356GX
Fan#: 94777
Great so I need to go in and show these guys the problem, even though Ford recognizes the problem?
Old 04-28-2014, 12:33 AM   #6
suss6052
suss6052's Avatar
Fan#: 95752
Depending on the dealership yes. It's required that they experience the problem in order for them to then follow the prescribed service procedure for the given issue.
suss6052 is offline
