BAP question - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-27-2014, 11:09 PM   #1
SVTFOOCUS
SVTFOOCUS's Avatar
Fan#: 39017
What I Drive: TurboL'd 03 SVT FOCUS ZX5
Points 1,750, Level 24
Points: 1,750, Level: 24 Points: 1,750, Level: 24 Points: 1,750, Level: 24
Level Up 50% Completed
FF Reputation: 4 SVTFOOCUS Good Standing Member
BAP question
Just installed a boost a pump in my 03 SVT, everything is hooked up correct according to a really nice thread from a fellow FF. I don't have the pressure switch wired connected, other than that, everything looks good. Thing is I have the same voltage coming out of the BAP as I do going in (no raise in voltage) and my fuel gage on my rail is at a steady 34psi with or without the BAP connected. Also moving the dial on the remote has no affect. Any ideas?
2003 SONIC BLUE SVT ZX5 #0258...
Turbo Charged, RC injectors, Stage 4 Clutch, 3" Exhaust from DP back, throttle body, Torsen Differential, A/F & Boost gauges in dash, Diablo Tune, J&S Safeguard, Custom powder-coated wheels
SVTFOOCUS is offline
Old 04-27-2014, 11:40 PM   #2
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,153, Level 74
Points: 13,153, Level: 74 Points: 13,153, Level: 74 Points: 13,153, Level: 74
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 30%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (46)
Moved this to "SVT Performance" for you because I think you will get more help here than you would in the General Technical Chat area.
zetecDon is offline
Old 04-28-2014, 09:04 AM   #3
SVTFOOCUS
SVTFOOCUS's Avatar
Fan#: 39017
Thanks
Old 04-28-2014, 10:01 AM   #4
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 52,496, Level 100
Points: 52,496, Level: 100 Points: 52,496, Level: 100 Points: 52,496, Level: 100
Level Up 0% Completed
Forum Activity 55%
Buy-Sell-Trade Rating: (28)
You have to connect the psi switch thats what activates the B-A-P , twist them together and you should see a change
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
Old 04-28-2014, 11:40 AM   #5
SVTFOOCUS
SVTFOOCUS's Avatar
Fan#: 39017
Yeah I did that... blew the fuze, and the shorted out the pump, pulled them apart and the fuze didnt pop but the pump was already shot. Replaced those last night, dont really wanna connect those two again lol Any idea why it would pop the fuze/pump?
Old 04-28-2014, 11:42 AM   #6
SVTFOOCUS
SVTFOOCUS's Avatar
Fan#: 39017
unless it was a coincidence that the pump shorted out, popping the fuse at the same time I had those connected together. But I did try another fuse before looking at anything else, and it popped that one too. Then disconnected the two leads, and the fuse did not pop.
Old 04-29-2014, 11:02 PM   #7
SVTFOOCUS
SVTFOOCUS's Avatar
Fan#: 39017
Anything? Im a littke hesitant to touch those switch ends together again.
Old 04-30-2014, 07:56 AM   #8
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 55%
Those wires that go to the psi switch will be connected when you make boost anyway so at some point if your going to use it they will get connected
I never use the psi switch and connect them then use the dial to adjust , some use a micro switch so when they go full throttle it turns on the pump
Whats your power goals ?
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 04-30-2014, 10:53 AM   #9
SVTFOOCUS
SVTFOOCUS's Avatar
Fan#: 39017
Not much, at most 320 if even that. Im just wanting to get as much fuel as I can to the injectors. Ill check all my connections again then connect those two again and see what happens. Maybe the pump happen to burn out coincidentally.
