Battery relocation - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-24-2014, 06:38 PM   #1
popwarhomie
popwarhomie's Avatar
Fan#: 94974
What I Drive: 10 Focus coupe / 94 Lightning
Points 1,267, Level 19
Points: 1,267, Level: 19 Points: 1,267, Level: 19 Points: 1,267, Level: 19
Level Up 67% Completed
Forum Activity 4%
FF Reputation: 1 popwarhomie Good Standing Member
Battery relocation
Front battery is done for. I flipped the breaker to my rear batteries and the front wouldn't even start the car.
I really don't want to spend $150 on a front AGM battery and would like to just use my rear batteries. Keeping the dead front one in is causing a drain on my rear batts.
I know I've seen a few pics of relocated batteries in 08-11 focus.
What do I need to do with wiring up front? Maybe I'm just over thinking this..
2010 Focus SE coupe 5 speed
Pioneer 80prs/(2)AQ2200D/BK800.4/6 SQ pro mids/4 SQ supertweets/AlphaDamp/Projector retrofit/LED tails/ Walled with 2 SQ HDC3 18s.
94 Lightning
A lot of mods.
popwarhomie is online now
Old 04-24-2014, 09:59 PM   #2
sailor
Elder
sailor's Avatar
Fan#: 57268
Points 12,874, Level 74
Points: 12,874, Level: 74 Points: 12,874, Level: 74 Points: 12,874, Level: 74
Level Up 6% Completed
Forum Activity 99%
You'd need a rear with heavy cables hooked direct to the front cables.
Sounds like your sound system batteries may have been helping the front out a bit, but sometimes when one dies it won't work even with another jumped to it (internal short sucks power).
Battery disconnect switch is the only "breaker" good enough to carry starting power to the front.
"Rubber Side Down"
S.R. #275 Focus Takeover #003
sailor is offline
Old 04-25-2014, 02:14 PM   #3
Miztaken1312
Miztaken1312's Avatar
Fan#: 74993
What I Drive: 2008 Black Coupe SES
Points 1,389, Level 20
Points: 1,389, Level: 20 Points: 1,389, Level: 20 Points: 1,389, Level: 20
Level Up 89% Completed
Level up: 89% Level up: 89% Level up: 89%
FF Reputation: 2 Miztaken1312 Good Standing Member
I believe a couple of the turbo'd Mk2 guys have relocated batteries. They'd be the ones to ask. They used that area for the turbo and I guess moved the battery to the rear.
FSWerks Turbo Kit @ 8psi , Stealth Exhaust, & Lower Stress Bar | Projectors w/5000K HIDs, LED Tails with Lamin-X Tint
Steeda Short Throw & Upper Strut Bar| FRPP Suspension & CFM Lower Mount |
Miztaken1312 is offline
Old 04-27-2014, 12:36 AM   #4
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 7,117, Level 55
Points: 7,117, Level: 55 Points: 7,117, Level: 55 Points: 7,117, Level: 55
Level Up 84% Completed
FF Reputation: 15 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (10)
The issue with the battery relocation is the ECU. The ECU uses the battery box as a mounting location. So when you move the battery the ECU is just kinda hanging out. This is something that is on my TO-DO list also. I've just been having trouble figuring out a nice way to mount the ECU.
Some guys kind of zip tie them down, but it's not very clean.
FSWerks stg2 w/ water/meth; Cossie intake.
PSUrivie is offline
Old 05-04-2014, 08:15 PM   #5
popwarhomie
Fan#: 94974
Forum Activity 4%
Pulled the front battery out the other day. Just have to clean up the wiring when I get a chance. Works great though.
94 Lightning
A lot of mods.
