Custom 3" stainless Magnaflow exhaust - Page 7 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 05-04-2014, 04:55 PM   #61
Juicedz
Juicedz's Avatar
Fan#: 108814
What I Drive: 2013 Ford Focus Hatchback SE, 5sp
Points 2,403, Level 29
Points: 2,403, Level: 29 Points: 2,403, Level: 29 Points: 2,403, Level: 29
Level Up 69% Completed
Forum Activity 2%
FF Reputation: 3 Juicedz Good Standing Member
What size exhaust tips are on the ford Escape? I was looking at a pair yesterday wondering if it would look good tucked into the rear valence or if they would be too big. I do like the slash/rounded cut tips.
'13 Oxford White Hatch 5-speed
injected 93 tune, steeda intake, e-focus rmm
Hatch Nation#24 172whp 157wtq
Juicedz is offline
Old 05-06-2014, 10:58 PM   #62
Buildist
Buildist's Avatar
Fan#: 150994
What I Drive: 2012 Blue Focus SE
FF Reputation: 1 Buildist Good Standing Member
Originally Posted by Seminoles View Post
If this is true why did Ford use cams that put the torque @ 4450 rpm and horse power @ 6500 rpm ( if I shift @ 4450 people think I racing them, why not 2500 rpm max torque ) if you add this to comparing your two V8 engines they would be full blown race engines at these rpm's. These four banger's are high efficiency motors I believe in one of the Ford write ups about direct injection it was said cylinder salvaging was not needed as much unlike other engines as in no EGR valve.
Four cylinder engines have to rev higher to make their power (N/A) than larger engines, this is why the peak torque is at 4450 rpm. Big block V8's are known for their low end torque. This is why you have higher revs in your Focus at cruising speed compared to larger engines. Four cylinder engines only get good torque numbers down low when forced induction is used. The torque curve in our engines are pretty flat, which is good. Notice that peak torque comes in at a good rpm if accelerating onto a highway, when it is needed most, but otherwise our engines don't go there much, but there is still a very useable amount of torque.
Horsepower is a calculation, not a measurement. It peaks at 6500 again because it is a small displacement engine and relies more on revs to help make power than an engine of larger displacement. V8 engines usually peak around 5240 rpm, if I remember correctly because of the calculation method and displacement, give or take 50 rpm or so.
Engine design for the mass market, to please the widest range of their customers, is a balancing act. There needs to be sufficient power for most types of driving while also not sacrificing fuel mileage in a very competitive market. Emissions are also a factor as well as NVH.
As for the exhaust on my wife's 66 Mustang, it has no cross over pipe. I will be putting in an H-pipe, it is just low on the priority list of things that need to be done right now. I don't want the affect to the sound of the exhaust that an X-pipe gives. The other engine will not be built for a while yet.
Power and power bands are really determined by the cams and Header design and the exhaust will mostly only hinder the efforts of the headers, they can't really make it any better, unless the header design is really poor. So more exhaust flow is usually better.
You are neglecting the significance of the heads and intake (manifold). Everything works as a whole. Sure, the cam grind will set the performance parameters of the engine, but if the head design is not to the needs of the cam it is all over. So too is the significance of the intake manifold and header design to support the head and the cams. Exhaust is a trickier thing than many people think. The engine is not merely an air pump because that air changes temperature drastically and the thermal dynamics introduces additional physics elements to be considered to make the engine perform at peak performance.
You are right, the exhaust can only hinder the efforts of the headers. However, in most everything in the world, the "If some is good more must be better" mentality doesn't work, or at best only works up to a point.
Steve
Buildist is offline
Old 05-28-2014, 07:41 AM   #63
Briggs
Briggs's Avatar
Fan#: 113114
What I Drive: 2014 focus SE Hatch
FF Reputation: 1 Briggs Good Standing Member
I love how these threads go from simple exhaust pictures to comparing a V8 to a 4 cylinder.
So 2 side exhaust and no videos??
2014 Focus SE Hatch the kart hauler, owner of 8EightFabrication.
My IG @kartingginger, #8EightFabrication
Briggs is offline
Old 05-30-2014, 11:52 PM   #64
Buildist
Buildist's Avatar
Fan#: 150994
I wasn't comparing a V8 to a 4 cylinder, other than to say most V8's cannot benefit from a 3" exhaust, I don't know how people think a 4 cylinder, N/A with no building, can.
My whole contention was exhaust velocity and torque across an RPM range. A 3" exhaust will reduce both while allowing more HP at top RPM, which is not useful on the street.
Steve
Buildist is offline
Old 05-31-2014, 08:13 AM   #65
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 26,035, Level 96
Points: 26,035, Level: 96 Points: 26,035, Level: 96 Points: 26,035, Level: 96
Forum Activity 57%
Activity: 57% Activity: 57% Activity: 57%
Steve
I'm actually not forgetting about anything forward of the header, I'm simply omitting it due to the fact that this is an exhaust thread. Out of all of the dyno sheets I've seen on this forum, the only ones that showed a loss anywhere in the rpm range were due to the intake, and that loss was in comparison to another intake-not the OEM design.
Steve
A 3" exhaust will benefit the Mk3 with no other engine building. If the header remains the same then the torque curve will not move in one direction or the other. You won't give up anything anywhere in terms of power. There are no before/after dyno sheets that I am aware of, especially with 3" because I've only seen or know of two Mk3's that have had 3" installed.
Will it benefit more in any significance when compared to a 2.5" setup? If everything else is OEM, most likely not. If the intake is aftermarket, probably a little. Add a tune, probably a little more. But no matter what is or isn't added (outside of the header), it will not hurt power at all anywhere.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is online now
