1st car noob has questions - Focus Fanatics
Old 04-21-2014, 04:27 PM   #1
Mk1.5
Fan#: 157738
What I Drive: 2004 gunmetal grey
FF Reputation: 1 Mk1.5 Good Standing Member
So I just bought a ford focus of my boss it's a 2004 1.6 edge with 111000 miles on it. Gun metal grey and alloys. Full service history and 4months mot and 4 tax. Bit of a dent in rear quarter panel.
Do you think it was worth 600.
Since I past my test a few month back I've only drove a few super cars at a track day thing ( Nissan gtr 35 by far fastest ;) ) so don't really now what to look for to see if it's a good motor either.
So next question is what should I check in the engine to make sure it's good. I've been reading the forum a bit lately and figured that you need to change the timing belt at 100k I'd guess it's been done already tho but not sure. So is this engine an interference one. As I read on some engines if it goes your engine does too so it made me a little worried.
Also what kind of engine is it Ive only seen mentioned duartec and zetec I'm guessing duratec.
I'm loving the car tho even if it's old it feels good pretty nippy too to say it only has 100bhp
Cheers
Mk1.5 is offline
Old 04-21-2014, 04:37 PM   #2
5speedRuby
5speedRuby's Avatar
Fan#: 119198
What I Drive: 2013 Ruby Red 5 Speed Hatchback
FF Reputation: 1 5speedRuby Good Standing Member
check the oil, trans fluid, coolant, power steering and brake fluid, make sure theyre not disgusting or infested, and if the timing belt has never been done do it. a reputable mechanic would have put a sticker under the engine bay saying if the timing belt was replaced and at what mileage, if it was done by a half rate grease monkey, and your still unsure, replace it, itll be worth it in the long run.
I Live My Life A Quarter Mile At A Time -Vin Diesel
Inked and Employed, Full Time Mechanic
Hatch Nation #94
Instagram - amu_chodie follow me!
16.8 seconds at 88.9 mph 3rd gear
5speedRuby is offline
Old 04-21-2014, 04:53 PM   #3
Mk1.5
Fan#: 157738
Thanks I'll look for a sticker tomorrow. Is changing the belt something I could do myself. I'm a plumber and I'm used to doing things for the first time and following instructions.
Mk1.5 is offline
Old 04-21-2014, 04:56 PM   #4
Mk1.5
Fan#: 157738
Sorry to add to the is the is the trans oil the the dipstick on the cams or is it called the rocker cover not sure. I seen there's the normal oil stick then another on the main engine block. Not sure what that one is
Mk1.5 is offline
Old 04-21-2014, 05:13 PM   #5
sailor
"Elder"
sailor's Avatar
Fan#: 57268
FF Reputation: 60 sailor Excellent Standing Member
Sorry Mate, can't tell much about the engine without some research, that size wasn't sold here.
Two dipsticks indicates an engine oil check & an automatic trans. check. Engine is done when it's off & the oil settles before pulling/wiping/reinserting the stick to check. Trans. is done the same way with the engine running.
Cheers
"Rubber Side Down"
S.R. #275
sailor is offline
Old 04-21-2014, 06:03 PM   #6
Mk1.5
Fan#: 157738
My bad explanation there didn't help I shouldn't of let it seem like I saw 2 dipsticks lmao I just found an online manual and the other cap I wasn't sure of is where the engine oil goes lol kicking myself right now as common sense went out the window for me. Cheers for the info. I'll be testing it tomorrow.
Is there a way to see if it's bad oil? And does bad/gone off oil kill the car?
Mk1.5 is offline
Old 04-21-2014, 08:07 PM   #7
sailor
"Elder"
sailor's Avatar
Fan#: 57268
Top cap for fill, handle for dipstick - that works.
If the Oil looks quite dark, and your service info. doesn't tell you the age/miles on it, then change the Oil & filter so you know when it was done & can figure the next change from there.
"Old" oil seldom kills one, LACK of oil (too low) can be a killer. Does need regular changes to last the best.
"Rubber Side Down"
S.R. #275
sailor is offline
