Intake - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 04-20-2014, 09:29 PM   #1
FlexinFocus09
FlexinFocus09's Avatar
Fan#: 155946
What I Drive: 2012 Tuxedo Black SEL Sedan
Points 476, Level 9
Points: 476, Level: 9 Points: 476, Level: 9 Points: 476, Level: 9
Level Up 52% Completed
FF Reputation: 1 FlexinFocus09 Good Standing Member
Exclamation Intake
anybody reading this... Would it do damage to the engine or anything if you drive without the lid to the air box on? i took it off (just the cover) and drove around it sounds sooo good!
FlexinFocus09 is offline
Old 04-20-2014, 09:31 PM   #2
Whodatxevg
Whodatxevg's Avatar
Fan#: 109173
What I Drive: 2014 Tuxedo Black Focus ST1
Points 1,742, Level 24
Points: 1,742, Level: 24 Points: 1,742, Level: 24 Points: 1,742, Level: 24
Level Up 43% Completed
FF Reputation: 4 Whodatxevg Good Standing Member
Keep the air filter on and you'll be fine. Just make sure the filter doesn't bounce off since there's only half the airbox holding it in with the top off.
'13 Oxford White sedan 5 speed. (SOLD)
15.00x @94.3
"Spirit of John Force" driver mod
Whodatxevg is offline
Old 04-21-2014, 12:09 PM   #3
NickCornell
NickCornell's Avatar
Fan#: 97233
What I Drive: 2012 Race red Focus SEL
Points 13,782, Level 76
Points: 13,782, Level: 76 Points: 13,782, Level: 76 Points: 13,782, Level: 76
Level Up 33% Completed
Forum Activity 6%
FF Reputation: 12 NickCornell Great Standing Member
sounds good. you'll get heat soak when it's hot and lose power/mpg though. been there done that.
#SonicsMK3Crew
Follow #projectstreetdevil on IG @BBNickC
BUILD THREAD: http://www.focusfanatics.com/forum/showthread.php?t=323533
NickCornell is offline
Old 04-21-2014, 01:55 PM   #4
Sonic_HedgeHog
Sonic Mk3 Crew #00
Sonic_HedgeHog's Avatar
Fan#: 50003
What I Drive: '12 Sterling Focus SE 5dr Sport Pkg
Points 124,710, Level 100
Points: 124,710, Level: 100 Points: 124,710, Level: 100 Points: 124,710, Level: 100
Level Up 0% Completed
FF Reputation: 19 Sonic_HedgeHog Great Standing Member
Intake
I'd advise having an K&N or Green Filter on there if you're going try that
Hatch Nation #156. Sonic's Mk3 Crew Founder and #00
Moderator: DURATEC Ti-VCT Performance, ST Performance, MK3 Focus, SW Fanatics, Sonic's MK3 Crew
Sonic_HedgeHog is offline
Old 04-21-2014, 02:21 PM   #5
wavsine
wavsine's Avatar
Fan#: 118470
What I Drive: 2013 Focus SE Oxford White Hatch 5m
Points 18,771, Level 86
Points: 18,771, Level: 86 Points: 18,771, Level: 86 Points: 18,771, Level: 86
Level Up 85% Completed
Level up: 85% Level up: 85% Level up: 85%
Forum Activity 16%
Activity: 16% Activity: 16% Activity: 16%
FF Reputation: 16 wavsine Great Standing Member
Not advisable. You are now pulling warm air from under the hood into your intake which blunts power and decreases hp. If you like the sound, do the snorkel delete. You will still have a change in intake noise and you have the potential of increasing your power by up to 8 hp. if you combine the snorkel delete with a K&N filter. Read this thread by dyn085. Duane knows his stuff.
http://www.focusfanatics.com/forum/showthread.php?t=297795
Use a Motorcraft FL-400S filter to increase filtration media and oil quantity. (Drop in for FL-910S)
Synthetic oil in GDI engines
www.focusfanatics.com/forum/showthread.php?t=324396
wavsine is offline
Old 04-21-2014, 03:41 PM   #6
FlexinFocus09
Fan#: 155946
Points 476, Level 9
thx everybody.. and yea i plan on getting a K&N filter.. also looking into snorkel delete
Old 04-21-2014, 03:51 PM   #7
NickCornell
Fan#: 97233
Forum Activity 6%
Either way your just going to pull bad air into the engine. I already played the "cheap" way and I promise it doesn't cut it.
#SonicsMK3Crew
Old 04-21-2014, 04:06 PM   #8
wavsine
wavsine's Avatar
Fan#: 118470
Forum Activity 16%
The snorkel delete should not pull bad air into the intake. It simply makes the MK3 intake system shorter (with less restriction) but still pulls outside cooler air like the the ST air inlet.
wavsine is offline
Old 04-21-2014, 04:18 PM   #9
NickCornell
Fan#: 97233
Forum Activity 6%
I've done the snake oil, I mean snorkel delete. but you're exposing an unsealed box to a flaming hot engine bay, to each their own but I would recommend a proper intake setup for the coldest intake temps. I had the Steeda but it still wasn't cutting it. so I cut it. literally and did the new mission mod. which made me wish I saved 300 dollars and just did that to my factory box with a drop in filter.
#SonicsMK3Crew
Old 04-21-2014, 05:22 PM   #10
dyn085
That Guy
dyn085's Avatar
Fan#: 98047
What I Drive: 2014 FiST/FoST
Points 25,182, Level 95
Points: 25,182, Level: 95 Points: 25,182, Level: 95 Points: 25,182, Level: 95
Level Up 84% Completed
Forum Activity 4%
You are entirely correct. By removing the snorkel you are still pulling air from outside of the engine bay on the other side of the radiator. Some people don't understand a lot about automotive mechanics and having the pictures should help them to understand. In my opinion it's much better than having a stream of air blown perpendicularly across the MAF sensor, but I'm just an aircraft mechanic.
OP, keep the lid on.
FocusFest 2013: Best of Show
September '13 ROTM
2014 FiST-
dyn085 is offline
